24th September 2009, 02:47 | #381 | Link |
NV beta 10: optional D3D for cards with older Nvidia drivers
Here you go, Inspector. Read the Readme to see how to enable D3D. Let me know if anything is amiss and I'll get right on it.
http://neuron2.net/dgavcdecnv/NVbeta10.zip EDIT: Open each indexer and then close it right away to create the new INI file entry. Then edit it as described in the Readme. Last edited by Guest; 24th September 2009 at 02:50. |
24th September 2009, 17:56 | #383 | Link |
Hello there. I have some newbie questions to neuron2.
1. Do you have any plans on supporting Radeons in future? 2. What about SLI support? 3. Is it possible to have Radeon and Geforce cards on one computer? Like Radeon HD 5870 for games and geforce 8600 for decoding? Thanks. |
24th September 2009, 19:35 | #386 | Link |
it dosnt work like that firebird. I got a Nvidia GTX 260 and when I test my max frames in DGAVCIndexNV (disable display and press F5 for Preview), it gives med around 52 fps. I think a GTX 260 can do alot more then that, because its only 4 fps more then my 'old' Nvidia Geforce 9500 GT, so I think the driver is limit to only use a small part of the GFX card. So SLI will give you nothing, not even sure the driver even support it.
25th September 2009, 06:23 | #387 | Link |
I finally had an opportunity to test the version that relies on D3D. The MPEG-2 and AVC tools work with no apparent issues, and I'll have to hunt down some 1080i AVC samples from the mplayer samples bin to round out the tests. DGVC1IndexNV, though, pops up the "Error 100: Failed to create video decoder" warning when opening (so far) 1080i or 1080p VC1 content. I've modified the .ini file per your instructions. Maybe I'm missing something...thanks!
25th September 2009, 13:08 | #389 | Link | |
25th September 2009, 13:21 | #390 | Link |
Way back at the start of development is was stated by a nvidia engineer that the VP is clocked at the same speed on all cards. Hence why all cards have virtually the same speed.
http://www.7-zip.org/ |
25th September 2009, 15:41 | #393 | Link |
OK, so after extensive attempts to check all variables, I've found that when loading a 1920x1080i VC1 stream (in the original Blu-ray M2TS container) with no other options than DGSource() generates the green line mentioned in the other thread. MeGUI's AVS Script creator shows the green line no matter what; MPC-HC only shows the line if single-rate NV deinterlacing and/or resizing is applied.
25th September 2009, 18:54 | #397 | Link |
Here's the first minute of the file with which I spotted the initial issue. I can reproduce the problem using this segment.
http://www.mediafire.com/?zgdzyr42qjl |
