5th July 2015, 19:03 | #221 | Link |
The command line is not complete. The de-muxer has to be specified (--demuxer y4m).
Groucho's Avisynth Stuff |
5th July 2015, 20:37 | #222 | Link |
Soul Architect
Piping seems to considerably lower the performance, nullifying any advantage of switching to the 64-bit x264. I also lose the estimated time left as it doesn't know the total amount of frames.
Is the SetMemoryMax command necessary? Not sure what to set it to. It seems to lower the performance when I specify it. It seems to work best when I use symmetrical thread values: 1, 2, 4, 8 or 16. Whenever I start using values like 3 or 6, I get lower performance. I'll try with MT=8, EEDI3 with 4 threads and NNEDI3 with 4 threads. It seems to be what works best. While encoding with x264, I get 6.3fps, 326 threads, 1374MB memory and CPU between 95-100%.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 5th July 2015 at 20:47. |
5th July 2015, 21:37 | #223 | Link | |||
You should start reading the documentation of the tools you use. Spoon-feeding you all the information becomes tiresome.
5th July 2015, 21:49 | #224 | Link | |
Soul Architect
Edit: OK after doing more tests, performance may be the same after all. Found a way to hack around and extract the total frames count to pass it to x264. It's a hack but it works. Edit2: After running the script, it still freezes at some point with 25-30% CPU usage. It's not because of memory usage.
FrameRateConverter | AvisynthShader | AvsFilterNet | Natural Grounding Player with Yin Media Encoder, 432hz Player, Powerliminals Player and Audio Video Muxer Last edited by MysteryX; 5th July 2015 at 23:41. |
13th February 2019, 11:12 | #227 | Link |
Here is an All-In-One package of LSFMod 1.9 which works for me under AVS 2.60 (or 2.61 Alpha) and the latest AVS+ 32-bit. Extract all files from the archive into the "Avisynth\Plugins" folder.
https://www.sendspace.com/file/dp73mb Cheers manolito |
4th July 2020, 14:39 | #229 | Link | |
### +-------+ ### | DEBUG | ### +-------+ ### ### show [bool] ### ----------- ### Show debug clip & informations ### ### screenW ; screenH [int] ### ----------------------- ### Screen resolution (for show clip)
25th July 2020, 04:47 | #231 | Link |
BUMP!
At some point, Smethod=5 was removed from LSFmod.avsi: Code:
449 Assert( ( Smethod >= 1 && Smethod <= 4 ) ? true : false, chr(10) + "'Smethod' have not a correct value! [1,2,3,4]" + chr(10)) According to the AviSynth Wiki, these should be the values for Smethod: Code:
int Smethod = 2 Sharpening method: (not used for Smode=1&2) 1 : 3x3 Kernel 2 : Min/Max (original) 3 : Min/Max (enhanced) 4 : Min/Max (original) + 3x3 Kernel 5 : Min/Max (enhanced) + 3x3 Kernel Last edited by Treaties Of Warp; 25th July 2020 at 04:51. |
1st January 2022, 09:05 | #232 | Link |
Should LSFMod really upscale by default for antialiasing? It introduces blurring, which seems to defeat the purpose.
If you're sharpening so much that it's aliasing, then you could set the supersampling. But it doesn't seem like such a lossy operation should be the default. |
21st October 2022, 11:44 | #235 | Link |
You can try LSFplus
https://github.com/Dogway/Avisynth-S...s/LSFplus.avsi Depen: https://github.com/Dogway/Avisynth-S...plus.avsi#L214 |
21st October 2022, 16:56 | #237 | Link |
Change "int "undershoot2"" to "float "undershoot2"" in LSFM_Show()
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
21st October 2022, 18:28 | #239 | Link |
Broadcast Encoder
Thanks Dogway, as always!
We reported it to the maintainer on GitHub too, including your fix. |
