Old 11th December 2006, 21:25   #481  |  Link
travisbell
original audio ... what kind of audio ? ac3 or mpa ?
about final size... maybe the codec is saturated for settings used.... try analyzing with drf_analyzer ... are all same type of frames at same quant ? (all b at 4, all p at 3, all i at 3)
a sample could be useful as usual !
BHH
AC3 audio.
I will post a sample and link it shortly. Thanks!
Travis Bell
Consumeroo!
travisbell is offline
Old 11th December 2006, 21:48   #482  |  Link
fogbav
@travisbell : Have you tried not to use AviSynth ... and no delaycut ?
It had problems with ac3 too ...
Maybe you should try settings ProjectX - NoDelaycut ...
Greets FoGBaV
fogbav is offline
Old 11th December 2006, 22:22   #483  |  Link
buzzqw
HDConvertToX author
tell me how
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 12th December 2006, 12:20   #484  |  Link
fogbav
Ups .... i mean DGindex .... sorry ...8)
Revenge ...8) : Bepipe still doesn't realy like my AC3 File ... it isstill converted to audio1.mp4 with 5 KB ... could you integrate something like "first convert to Audio WAV 5.1 (Besweet) and then convert it ?
I posted my script in the past which worked pefectly ...
Also - there is another option in Projectx :
replace all not-3/2 AC-3 by 3/2lfe silence
and
{patch 1st AC-3 header to 3/2 ch-mode}
Maybe this solves the problem with splitting ac3 2/0 - AC3 5.1 ...
Thanx
FoGBaV
P.S. : Rest works perfectly ... every TS without AC3 is converted with superb speed and quality.
Edit :
This is the Problem in AC3 File (logged in ProjectX )
--> AC-3/DTS Audio on PID 0xD03
-> check CRC of AC-3 / MPEG-Audio L1,2
-> delete CRC in MPEG-Audio Layer1,2
-> add frames
Audio PTS: first packet 05:42:09.512, last packet 07:08:32.712
Video PTS: start 1.GOP 05:42:10.051, end last GOP 07:08:32.531
-> adjusting audio at video-timeline
-> src_audio: AC-3, CM, 2/0(2.0), dn -23dB, DS, 48000Hz, 384kbps @ 00:00:00.000
-> src_audio: AC-3, CM, 3/2lfe(5.1), dn -27dB, cm -3.0dB, sm -3dB, 48000Hz, 384kbps @ 00:00:10.240
-> src_audio: AC-3, CM, 2/0(2.0), dn -23dB, DS, 48000Hz, 384kbps @ 00:00:34.144
audio frames: wri/pre/skip/ins/add 161952/0/0/0/0 @ 01:26:22.464 done...
---> new File: 'C:\ACE3.0\tmp\temp\film.ac3'
So ... 3 different AC3 parts ...
There is a posibility to tell ProjectX with x.ini file advanced setings from above ... so maybe it would be great to enhance the CLI-Command with projectx to use a seperate x.ini file.
(i tryed to use x.ini in dgindex directory and in root of automkv but it didn't work ..8( )
normaly everybody else should have this problem when converting files with AC3 where comercials are integrated. hmm ...
fogbav is offline
Old 13th December 2006, 19:33   #485  |  Link
fogbav
bumb bumb ... 8)
fogbav is offline
Old 13th December 2006, 19:46   #486  |  Link
buzzqw
HDConvertToX author
sorry Fogbav but i am overwhelm of work...
giveme some time... also... sorry if double asked... could you post a link to this file ? i have probably already asked... but i cannot found it... sorry
BHH
EDIT: fount it
EDIT2: just put the X.ini file into \temp\folder
fixed in next release
buzzqw is offline
Old 13th December 2006, 20:08   #487  |  Link
fogbav
@buzzqw : Oh man , you don't have to say sorry here in any way !
You do so good work here - take as much time as you need.
I just was wondering where you are ... i thought you are living here in this forum ... 8)
Sorry from my side ...
FoGBaV
Edit : Ok - will try --- thaaanks (shit ... this was the only dir i didn't tried out ..8) )
fogbav is offline
Old 14th December 2006, 05:45   #488  |  Link
BleedingGums
I am having some problems with automkv mostly having to do with subtitles and final muxing.
Log File
22:57:17 0.62c  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
22:57:17 Selected Input file:     C:\Utils\Source\sf\VTS_09_0.IFO
22:57:17 Selected Output dir:     C:\Utils\Destination\temp\
22:57:17 Selected Container type: MKV
22:57:17 Selected Encoder:        X264
22:57:17 Selected Size:           10
22:57:17 Selected Slice:          1
22:57:17 Selected Profile:        1P-Maxspeed.xml
22:57:17 Selected Width:          640
22:57:17 Selected Resizer:        SimpleResize (neutral soft)
22:57:17 Selected Filters:        RemoveGrain(mode=2)
22:57:17 Selected Deinterlacer:   AUTO
22:57:18 Enabled CRF/CQ autoresize with value 18
22:57:18 Track Language 1:        English (AC3 2ch, 0xBD 0x80) [0]
22:57:18 Audio Codec 1:           Nero AAC
22:57:18 Audio Quality 1:         0.20
22:57:18 Track Language 2:        Japanese (AC3 2ch, 0xBD 0x81) [0]
22:57:18 Audio Codec 2:           Nero AAC
22:57:18 Audio Quality 2:         0.10
22:57:18
22:57:18 Starting SubRipping
22:57:20 Selected subtitle tracks: English 0 (0xBD 0x20) [0]
22:57:20 Finished SubRipping
22:57:20 Subtitle Size:           -1 bytes
22:57:20 Starting Indexing
22:57:20 Dgindex CMD: C:\Utils\AutoMKV 62\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1,2 -YR=2 -AIF=[C:\Utils\Source\sf\VTS_09_1.vob] -OF=[C:\Utils\Destination\temp\movie] -exit -minimize
22:57:27 Finished indexing
22:57:27 Starting fixing audio delay on track number 1
22:57:27 DelayCut CMD: C:\Utils\AutoMKV 62\exe\dgindex\Delaycut.exe -auto -out "C:\Utils\Destination\temp\fixed1.ac3" "C:\Utils\Destination\temp\movie T01 2_0ch 224Kbps DELAY 0ms.ac3"
22:57:27 Original 1' Audio Size:  5409152 bytes
22:57:27 DelayCut CMD: C:\Utils\AutoMKV 62\exe\dgindex\Delaycut.exe -auto -out "C:\Utils\Destination\temp\fixed2.ac3" "C:\Utils\Destination\temp\movie T02 2_0ch 224Kbps DELAY 0ms.ac3"
22:57:27 Original 2' Audio Size:  5409152 bytes
22:57:27 Finished fixing audio delay
22:57:28 Encoding C:\Utils\Destination\temp\fixed1.ac3 to NeroAAC with 0.20 quality
22:57:52 Encoded 1' Audio Track:  1094786 bytes
22:57:52 Encoding C:\Utils\Destination\temp\fixed2.ac3 to NeroAAC with 0.10 quality
22:58:06 Encoded 2' Audio Track:  620070 bytes
22:58:09 Number of Frames:        5791
22:58:09 Framerate:               29.970030
22:58:09 Movie lenght in Seconds: 194
22:58:09 Movie Width:             720
22:58:09 Movie Height:            480
23:00:59 Processing completed. Type is determined to be partly film.
23:00:59 BFF:                     62
23:00:59 TFF:                     148
23:00:59 Order:                   1
23:00:59 Starting  X264
23:00:59 ABR encoding X264:       C:\Utils\AutoMKV 62\exe\encoder\x264.exe --bitrate 361 --progress --keyint 250 --bframes 0 --qpmin 10 --qpmax 51 --no-psnr --ref 1 --filter 0,0 --subme 0 --direct auto --vbv-maxrate 25000 --me dia --merange 8 --nf --no-cabac --no-b-adapt --no-chroma-me --threads 2  --output "C:\Utils\Destination\temp\movie.mp4" "C:\Utils\Destination\temp\movie.avs"
23:04:30 Only Movie Size:         9214026 bytes
23:04:30 Selected Subtitle Track: English 0 (0xBD 0x20) [0]
23:04:30 C:\Utils\AutoMKV 62\exe\matroska\mkvmerge.exe -o "C:\Utils\Destination\temp\m1.mkv" --aspect-ratio 1:1.344538 --chapters "C:\Utils\AutoMKV 62\exe\chapters.txt" "C:\Utils\Destination\temp\movie.mp4" --language 1:eng "C:\Utils\Destination\temp\audio.mp4" --language 1:jap "C:\Utils\Destination\temp\audio2.mp4" "C:\Utils\Destination\temp\m1.idx"
23:04:30 Final Muxed size:        -1 bytes
23:04:31 Encoding finished:       00:07:14 elapsed time
23:04:31 -----------------------------------------------------------------------
23:04:31 Script AutoCrop.log
23:04:31
23:04:31 Crop(8,2,708,476)
23:04:31 Script Resmovie.avs
23:04:31
23:04:31 Script movie.avs
23:04:31
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\autocrop.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\blockbuster.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\cnr2.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\ColorMatrix.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\Convolution3D.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\corrector.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\DctFilter.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\decomb.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\Deen.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\degrainmedian.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\DGDecode.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\EEDI2.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\fft3dfilter.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\FluxSmooth.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\frfun7.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\hqdn3d.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\LeakKernelDeint.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\MaskTools.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\medianblur.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\MipSmooth.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\mvtools.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\NicAudio.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\RemoveGrain.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\SangNom.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\SimpleResize.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\TBilateral.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\TDeint.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\TIVTC.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\TomsMoComp.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\TTempSmooth.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\UnDot.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\UnFilter.dll")
23:04:31 LoadPlugin("C:\Utils\AutoMKV 62\exe\filter\VSFilter.dll")
23:04:31 #loadpluginstart
23:04:31
23:04:31 #test1
23:04:31
23:04:31 Import("C:\Utils\AutoMKV 62\exe\filter\mvbob.avsi")
23:04:31 Import("C:\Utils\AutoMKV 62\exe\filter\QMF.avsi")
23:04:31 #importstart
23:04:31
23:04:31 #test2
23:04:31
23:04:31 movie = mpeg2source("C:\Utils\Destination\temp\movie.d2v")
23:04:31 function getOrder(clip c) {
23:04:31 order = GetParity(c) ? 1 : 0
23:04:31 Return order }
23:04:31 #filter1start
23:04:31
23:04:31 #test3
23:04:31
23:04:31 #cropstart
23:04:31
23:04:31 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
23:04:31 fixed_aspect = 0.888889
23:04:31 c_width = width(cropclip)
23:04:31 c_height = Round(height(cropclip) / fixed_aspect)
23:04:31 input_par = float(float(c_width)/float(c_height))
23:04:31 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
23:04:31 out_width = 640
23:04:31 out_height = Round(float(out_width) / input_par)
23:04:31 hmod = out_height - (floor(out_height / 16 ) * 16)
23:04:31 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
23:04:31 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
23:04:31 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
23:04:31
23:04:31 tfm(d2v="C:\Utils\Destination\temp\movie.d2v").tdecimate()
23:04:31 #resizestart
23:04:31
23:04:31 #test4
23:04:31
23:04:31 BicubicResize(out_width,out_height,0,0.66)
23:04:31 #filter2start
23:04:31
23:04:31 #test5
23:04:31
23:04:31 RemoveGrain(mode=2)
23:04:31 ColorMatrix("Rec.709->Rec.601",hints=false)
23:04:31 Script mkvmaudio.avs
23:04:31
23:04:31 NicAC3Source("C:\Utils\Destination\temp\fixed1.ac3")
23:04:31 EnsureVBRMP3Sync()
23:04:31 ConvertAudioToFloat()
23:04:31 #Applyed Stereo downmixing routines
23:04:31 function stereo(clip a)
23:04:31 {
23:04:31 fl = GetChannel(a, 1)
23:04:31 fr = GetChannel(a, 2)
23:04:31 c = GetChannel(a, 3)
23:04:31 lfe = GetChannel(a, 4)
23:04:31 sl = GetChannel(a, 5)
23:04:31 sr = GetChannel(a, 6)
23:04:31 l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
23:04:31 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
23:04:31 r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
23:04:31 l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
23:04:31 r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
23:04:31 Return MergeChannels(l, r).Normalize()
23:04:31 }
23:04:31 #
23:04:31 function original(clip a)
23:04:31 {
23:04:31 Normalize(a)
23:04:31 Return last
23:04:31 }
23:04:31 6==Audiochannels() ? stereo() : original()
23:04:31 Script mkvmaudio.bat
23:04:31
23:04:31 "C:\Utils\AutoMKV 62\exe\besweet\bepipe.exe" --script "Import(^C:\Utils\Destination\temp\mkvmaudio.avs^)" | "C:\Utils\AutoMKV 62\exe\besweet\neroaacenc.exe" -ignorelength -q 0.20 -if - -of "C:\Utils\Destination\temp\audio.mp4"
23:04:31 Script mkvmaudio2.avs
23:04:31
23:04:31 NicAC3Source("C:\Utils\Destination\temp\fixed2.ac3")
23:04:31 {
23:04:31 }
23:04:31 #
23:04:31 {
23:04:31 }
23:04:31 Script mkvmaudio2.bat
23:04:31
23:04:31 "C:\Utils\AutoMKV 62\exe\besweet\bepipe.exe" --script "Import(^C:\Utils\Destination\temp\mkvmaudio2.avs^)" | "C:\Utils\AutoMKV 62\exe\besweet\neroaacenc.exe" -ignorelength -q 0.10 -if - -of "C:\Utils\Destination\temp\audio2.mp4"
23:04:31
23:04:31 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
- since moving to 0.62 extracting the subtitles on my sample file causes a "error parsing parameter file" exeption from vstrip. 0.51f did not have that problem.
- AutoMkv also fails to make the finished file. In the mkvmerge stage I noticed that one of the parameters is wrong in the muxing.bat, replacing jap with jpn (and in this particular case removing the subtitles line) created the end file like it was supposed to.
BleedingGums is offline
Old 14th December 2006, 10:50   #489  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV062d.exe
FIXED: wrong ar when muxing avi into mkv container
FIXED: no more use of process.exe ! AutoMkv can change priority of running program itself
ADDED: if ts files contain more then 1 video stream, automkv will ask to choose that pid. Not use ProjectX in conjuction with this ts
FIXED: better layout in Advanced Settigns
ADDED: Use custom X.ini file for projectX (launch projectX.jar, customize to your taste, save the default to X.ini into Dgindex folder)
ADDED: Use custom X.ini added to Save Default settings
FIXED: Subtitles on no angle dvds (beta)
FIXED: jap->jpn in audio tracks
buzzqw is offline
Old 14th December 2006, 14:20   #490  |  Link
weaver4
I was trying to make a wmv file last night and the wma audio encode seemed to fail saying the length was -1.
The same source files work with mp3.
Is this a known problem?
weaver4 is offline
Old 14th December 2006, 14:30   #491  |  Link
buzzqw
HDConvertToX author
audio channel ? Original or stereo ?
if original is VERY probable that is NOT working
if stereo... should be OK
BHH
buzzqw is offline
Old 14th December 2006, 21:31   #492  |  Link
BleedingGums
when using the "start queue" button my second audio track does not get processed
15:47:56 0.62d  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
15:47:56 Selected Input file:     C:\utils\Source\sf\VTS_09_0.IFO
15:47:56 Selected Output dir:     C:\utils\Destination\temp\
15:47:56 Selected Container type: MKV
15:47:56 Selected Encoder:        X264
15:47:56 Selected Size:           1 CD
15:47:56 Selected Slice:          1
15:47:56 Selected Profile:        AE-Maxquality.xml
15:47:56 Selected Width:          640
15:47:56 Selected Resizer:        BicubicResize (sharp=0,0.66)
15:47:56 Selected Filters:        Convolution3d (preset="animeHQ")
15:47:56 Selected Deinterlacer:   AUTO
15:47:56 Enabled CRF/CQ autoresize with value 18
15:47:56 Track Language 1:        English (AC3 2ch, 0xBD 0x80) [0]
15:47:56 Audio Codec 1:           Nero AAC
15:47:56 Audio Quality 1:         0.20
15:47:56
15:47:56 Starting SubRipping
but when i use the "start" button it works fine
15:46:53 0.62d  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
15:46:53 Selected Input file:     C:\utils\Source\sf\VTS_09_0.IFO
15:46:53 Selected Output dir:     C:\utils\Destination\temp\
15:46:53 Selected Container type: MKV
15:46:53 Selected Encoder:        X264
15:46:53 Selected Size:           1 CD
15:46:53 Selected Slice:          1
15:46:53 Selected Profile:        AE-Maxquality.xml
15:46:53 Selected Width:          640
15:46:53 Selected Resizer:        BicubicResize (sharp=0,0.66)
15:46:53 Selected Filters:        Convolution3d (preset="animeHQ")
15:46:53 Selected Deinterlacer:   AUTO
15:46:53 Enabled CRF/CQ autoresize with value 18
15:46:53 Track Language 1:        English (AC3 2ch, 0xBD 0x80) [0]
15:46:53 Audio Codec 1:           Nero AAC
15:46:53 Audio Quality 1:         0.20
15:46:53 Track Language 2:        Japanese (AC3 2ch, 0xBD 0x81) [0]
15:46:53 Audio Codec 2:           Nero AAC
15:46:53 Audio Quality 2:         0.10
15:46:53
15:46:53 Starting SubRipping
program works well otherwise
Old 15th December 2006, 08:19   #493  |  Link
buzzqw
HDConvertToX author
thanks for reporting !
are subs ok now ?
BHH
buzzqw is offline
Old 15th December 2006, 10:07   #494  |  Link
BleedingGums
yea, subs are working
Old 16th December 2006, 11:15   #495  |  Link
Barleyman
Anamorphic encoding is still busted.. It's using the "1" stream and not "0"
12:09:45 C:\Program Files\AutoMKV\exe\matroska\mkvmerge.exe -o "E:\Movies-E\temp\movie.mkv" --aspect-ratio 1:16:9 --chapters "C:\Program Files\AutoMKV\exe\chapters.txt" "E:\Movies-E\temp\movie.avi" --language 0:und "E:\Movies-E\temp\audio.mp3"
Would it be possible to check if the output file exists before encoding? It's a bother if your 2-hour encode just disappeared that way. Maybe just add running number to the filename if there's a conflict?
Barleyman is offline
Old 16th December 2006, 12:33   #496  |  Link
buzzqw
HDConvertToX author
there is already the possibility to name final file as you want.. anyway in next release if destionatio file exist the final file will be named Date()_movie.xxx , where date() is the date is windows format
BHH
buzzqw is offline
Old 16th December 2006, 13:21   #497  |  Link
Barleyman
BHH
So what about if there's already Date()_movie? You get Date()_Date()_movie?
Old 16th December 2006, 15:10   #498  |  Link
buzzqw
HDConvertToX author
IN NEXT release the value of date will be appended before the name of file ... if destination file already exist
if you write date()_test as movie name you will got "date()_test.xxx" as final movie...
BHH
buzzqw is offline
Old 16th December 2006, 15:32   #499  |  Link
Barleyman
BHH
How about date + time? Should resolve issues with batches?
Old 16th December 2006, 15:43   #500  |  Link
weaver4
When you encode a xvid movie using CQ the output file without the audio ends up in the Output directory and the output file with the muxed audio ends up in the Output\temp directory. Of course if you don't save the temp files you will deleted it.
weaver4 is offline
