Old 6th February 2006, 14:36   #101  |  Link
nm
It would be best to get someone more experienced in metric testing to figure out a good test. I can't think of any good way to include resizing in the PSNR calculations where the values are supposed to be compared with PSNR values from a non-resized encode.
Perhaps visual comparison with a low resolution (< 320x240) and very low bitrate (100-200 kbps) would be better. Still, resizing would be hard to do without affecting the judgement because of scale differences. You could do the resize twice, first to a higher resolution and then back to the original, but that wouldn't be fair.
Old 8th February 2006, 11:16   #102  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Aspect Ratio Signalling (ARS) Calculation Tool
With the help of generous friend, here is the first version of the ARS Calculator. I hope some of you guys will find it useful and enjoy using it
At the time of writing it requires version 2 of Micro$oft's .NET Framework in order to run.
My profound thanks goes to Moitah. Who was able to turn my design concept into a working reality. Many, many thanks....
Cheers
Old 10th February 2006, 07:55   #103  |  Link
Backflip
Excellent work
Backflip is offline   Reply With Quote
