17th April 2015, 22:02 | #19061 | Link |
Thanks DXVA2 copy-back + GTX960: UHD 4K 10 BITS ASTRA/EUTELSAT it's work only with latest LAV 0.64.52 build (16/04/2015) (ok with enhanced video renderer or madvr) (files froms nightly MPC-HC) Still not ok with DXVA2 NAtive, but it's better. (20% CPU)
CORE I5 - NVIDIA GTX960 - WINDOWS 10 10122 MPC-BE / MPC-HC + LAV FILTERS 0.65.08 DVBDREAM - SMARTDVB - tuner TBS5925 - TBS5220 4T2 CONTENT ANALYSER |
17th April 2015, 23:26 | #19063 | Link |
_
I've discovered madVR has now a 64 bits. What about dts-hd decoder ? Do you know if there's something being worked to have a 64 bits dts-hd decoder ?
I remember once reading there were a "beginning" on ffmpeg project. |
17th April 2015, 23:29 | #19065 | Link |
DXVA2 Native does not support 10-bit, and thats very unlikely to change.
18th April 2015, 00:29 | #19067 | Link | |
Why wait for final? Nev's master builds are as stable as anything final. |
18th April 2015, 00:38 | #19068 | Link | |
Half-Light Agent |
18th April 2015, 06:52 | #19069 | Link | |
http://http.download.nvidia.com/XFre...rtedchips.html |
20th April 2015, 01:47 | #19072 | Link |
No, madVR uses higher quality dithering. LAV's dithering will never be used when rendering with madVR and using LAV's default settings.
madVR options explained |
21st April 2015, 13:43 | #19073 | Link |
LAV Filters 0.65
LAV Splitter - NEW: Support for MKV subtitle Cues to show subtitles immediately after a seek - NEW: Attachments and embedded cover art images are exported through the IDSMResourceBag interface - Fixed: Improved demuxing of HEVC in MPEG-TS and increased the reliability of the SPS/PPS/VPS extraction - Fixed: Demuxing Blu-rays/MPEG-TS where the first stream was not a video stream could result in broken timestamps - Fixed: Seeking in MKVs which are currently being written is more reliable LAV Video - Fixed: Improved HEVC DXVA2 decoding on a few samples - Fixed: Playback of VFR MPEG-4 in AVI had wrong timestamps in 0.64 - Fixed: Improved handling of DVD subtitles without timestamps LAV Audio: - NEW: Native DTS-HD decoding using libdcadec - Changed: 5.1 audio prefers the speaker mask with side channels, to match recent specifications DTS-HD decoding support through libdcadec LAV Audio now includes libdcadec, a full-featured DTS-HD decoder. All known DTS-HD MA and DTS-HD HRA samples are supported and decoded perfectly lossless, up to 7.1, 192kHz, 24-bit (with a possible exception in a few weird samples). In addition, it also supports a long list of core extensions, including XCH (for 6.1 DTS ES streams), and X96 (for DTS 96/24). The only unsupported DTS format that I know of is DTS Express, which is used for interactive commentary tracks on Blu-rays. If the ArcSoft decoder is present, it will continue to be used for the time being, but in the long run I may even remove it. If you find anything that doesn't seem to behave properly with the new DTS decoder, please do report and I'll work with the libdcadec author to see what is going on! ------ I wanted to get some more features done for this release, but time was short, and it felt like this was worth releasing anyway, so, have fun with it!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 21st April 2015 at 13:54. Reason: Typos |
22nd April 2015, 09:35 | #19079 | Link |
MPC-HC Audio Renderer is not recommended to be used at this point, but thats more of a topic for the MPC-HC thread.
