Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 18th January 2009, 08:30   #1  |  Link
WalterK
WalterK's Avatar
VDPAU Info Tool
Here is vdpinfo.
Created to tell you if your vid card has support for the new vdpau decoder added to the latest stable nvidia driver
Unfortunately my new middle of the road 9800GT only has support for, MPEG1, MPEG2 and H264 using vdpau and not WMV VC-1 decoding on the gpu.
display: :0.0   screen: 0
API version: 0
Information string: Unknown
Video surface:
name   width height types
420     4096  4096  NV12 YV12
422     4096  4096  UYVY YUYV
Decoder capabilities:
name          level macbs width height
MPEG1             0  8191  2032  2032
MPEG2_SIMPLE      3  8191  2032  2032
MPEG2_MAIN        3  8191  2032  2032
H264_MAIN        41  8191  2032  2032
H264_HIGH        41  8191  2032  2032
Output surface:
name              width height nat types
B8G8R8A8          8192  8192    y  Y8U8V8A8 V8U8Y8A8
R10G10B10A2       8192  8192    y  Y8U8V8A8 V8U8Y8A8
Bitmap surface:
name              width height
B8G8R8A8          8192  8192
R8G8B8A8          8192  8192
B10G10R10A2       8192  8192
A8                8192  8192
Video mixer:
feature name                    sup
DEINTERLACE_TEMPORAL             y
DEINTERLACE_TEMPORAL_SPATIAL     y
INVERSE_TELECINE                 y
NOISE_REDUCTION                  y
SHARPNESS                        y
LUMA_KEY                         y
parameter name                  sup      min      max
VIDEO_SURFACE_WIDTH              y         1     4096
VIDEO_SURFACE_HEIGHT             y         1     4096
CHROMA_TYPE                      y
LAYERS                           y         0        4
attribute name                  sup      min      max
BACKGROUND_COLOR                 y
CSC_MATRIX                       y
NOISE_REDUCTION_LEVEL            y      0.00     1.00
SHARPNESS_LEVEL                  y     -1.00     1.00
LUMA_KEY_MIN_LUMA                y
LUMA_KEY_MAX_LUMA                y
You will need the latest stable nvidia drivers installed, 180.22
Heres the link to the nvnews forums.
http://www.nvnews.net/vbulletin/showthread.php?t=124978
WalterK is offline   Reply With Quote
Old 18th January 2009, 11:07   #2  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
cool, thanks
Old 20th January 2009, 15:25   #3  |  Link
Selur
Selur's Avatar
Thanks for the Info
Old 20th January 2009, 16:20   #4  |  Link
yeye69
Originally Posted by WalterK View Post
Here is vdpinfo.
not only middle of the road 9800, but 'highway" 260 does not support a hw.decoding of VC-1
yeye69 is offline   Reply With Quote
Old 20th January 2009, 19:21   #5  |  Link
lucassp
Than how did neuron2 make it in DGVC1DecNV?
[Intel] Core i5 8500|[ASUS] ROG STRIX Z390-I GAMING|[Noctua] NH-U12S|[GSkill] DDR4 2400 2x16GB|[MSI] RTX2060 Super Gaming X|[Samsung] 970 Pro 512Gb|[Seasonic] Focus SGX 650|[NZXT] H400|[LG] 27GL850
lucassp is offline   Reply With Quote
Old 20th January 2009, 19:42   #6  |  Link
nm
NVCUVID takes care of the work that the VP2 hardware decoder can't do (bitstream decoding). Just like the proprietary VC-1 DXVA decoders do on Windows. IIRC, NVIDIA has hinted that VDPAU may gain similar functionality in the future.
Old 21st January 2009, 08:13   #7  |  Link
lucassp
Thanks! Finally an answer.
info, nvidia, vdpau
