27th January 2019, 14:22 | #41 | Link |
WaveForm_FilmStrip Update, added W, H args, Width, Height of FilmStrip thumbnail images.
Hope this is Final version. Code:
#AviSource("D:\G.avi") Colorbars.Trim(0,-100) WINDOW = 1 # Frames Wide = 2 * WINDOW + 1 HEIGHT = 1.0 # Audio graphs height, 0.333 = 1/3 of result filmstrip image height. UNDER = True # True, then audio graphs stacked under video, else overlay over video. ZOOM = 1.0 # Amplify audio signal for viewing (1.0=No Amp). SUBSIZE = 0.5 # Suggest 0.0(off) to about 0.5. (0.0 <= SubSize <= 1.0) : 0.0 = No Frame Number, 1.0=biggest size for current clip Height (probably too big). SHOWAUDIO = True # Default True. If False, Switches OFF WaveForm Display, Shows FilmStrip Only. W = -1 # Default -1, (or 0 or +ve). -1 = Normal Downscale behaviour, filmstrip width ~= input clip width. H = Undefined # Undefined, Let W govern height of thumbnail images (or just dont use h=H in function call, same as h=Undefined). ###### Can Remove this lot ###### TONE = False # Replace Colorbars tone with selected TONETYPE tone TONETYPE ="NOISE" # Pick from:- "Silence", "Sine", "Noise", "Square", "Triangle" or "Sawtooth" TONECHANS = 5 # Tone Channels Count (test channels display) # (TONE) ? AudioDub(Tone(Length=FrameCount/FrameRate,Type=TONETYPE,Channels=TONECHANS)) : Last ###### End Of Can Remove ###### Return WaveForm_FilmStrip(window=WINDOW,Height=HEIGHT,under=UNDER,zoom=ZOOM,subSize=SUBSIZE,ShowAudio=SHOWAUDIO,w=W,h=H) Function WaveForm_FilmStrip(clip c,int "Window",Float "Height",Bool "Under",Float "Zoom",Bool "Marks",Float "SubSize",Bool "ShowAudio",Int "W",Int "H") { /* Waveform_FilmStrip:- by StainlessS @ Doom9 ::: https://forum.doom9.org/showthread.php?p=1863963#post1863963 Where ShowAudio=True, Requires WaveForm plugin (c) Wonkey_Monkey, https://forum.doom9.org/showthread.php?t=165703 [Wonkey_Monkey, The Prince formerly known as David.] WaveForm_FilmStrip(clip c,int "Window"=0,Float "Height"=0.333,Bool "Under"=True,Float "Zoom"=1.0,Bool "Marks"=True,Float "SubSize"=0.0,Bool "ShowAudio"=True,Int "W"=-1,Int "H"=W_Based) Window, Default 1 (0 <= Window <=3), Filmstrip thumbnail Images across = 2 * Window + 1. Height, Default 0.333=1/3 of FilmStrip Height. See Waveform docs for more. Under, Default True, If True, then audio graph stacked under video, else overlay over video. Zoom, Default 1.0. Amplify audio signal for viewing (1.0=No Amp). SubSize, Default 0.0(0.0 <= SubSize <= 1.0). Suggest 0.0(No Frame Number) to about 0.5. : 1.0=biggest size for current clip Height (probably too big). ShowAudio, Default True. If False, Switches OFF WaveForm Display, Shows FilmStrip Only. W, Default -1. Governs width of thumbnail images making up the FilmStrip. -ve) Entire FilmStrip width (multiple thumbnail images based on Window arg) will be about same as input clip width. 0) Each FilmStrip thumbnail image is SAME size as input clip, result could be a quite wide clip. Else) Each FilmStrip thumbnail image Width is set by W (best Mod 2). H, Default based off W. (Suggest Dont supply H arg, let it default based on W arg. Can call with H=Undefined where will behave as if defaulting). IF H is Supplied ie not defaulted THEN H = Supplied H # could be -ve, 0, or +ve(explicit height). else if W <= 0, then H = W, ELSE H = input clip height Aspect Ratio Scaled to match W. Here, H could be -ve, 0, or +ve, defaulted or non defaulted. Where H, -ve) FilmStrip height scaled down to Aspect Ratio match FilmStrip width of individual thumbnail images. 0) Each FilmStrip thumbnail image Height is SAME size as input clip height. Else) Each FilmStrip thumbnail image Height is set by H (best Mod 2). */ Window=Default(Window,0) Height=Max(Default(Height,0.333),0.0) Under=Default(Under,True) SubSize=Default(SubSize,0.0) ShowAudio=Default(ShowAudio,True) W=Default(W,-1) H=Default(H,W<=0?W:Round(W.Float/c.Width*c.Height+1)/2*2) Assert(0 <= window <= 3,"WaveForm_FilmStrip: 0 <= window <= 3") Assert(0.0 <= SubSize <= 1.0,"WaveForm_FilmStrip: 0.0 <= SubSize <= 1.0") Frms = 1 + (2*Window) WW=(W<0)?(c.Width+Frms)/(Frms*2)*2:(W==0)?c.width:W HH=(H<0)?(c.Height+Frms)/(Frms*2)*2:(H==0)?c.Height:H sc=(WW!=c.Width||HH!=c.Height) ?c.BiCubicResize(WW,HH,b=-0.5,c=0.25) :c scSubsSz=Round(sc.Height*SubSize) SSS="""Subtitle(String(current_frame,"%.0f")""" + String(scSubsSz,",SIZE=%.0f") + String((sc.Height-scSubsSz)/2.0,",Y=%.0f") + """,align=8)""" sc=(scSubsSz!=0)?sc.ScriptClip(SSS):sc bc=sc.BlankClip(Length=1,Color=$000000) p1c=bc+sc p2c=bc+p1c p3c=bc+p2c n1c=sc.FrameCount>1?sc.Trim(1,0)+bc:bc n2c=n1c.FrameCount>1?n1c.Trim(1,0)+bc:bc n3c=n2c.FrameCount>1?n2c.Trim(1,0)+bc:bc Select(Window,sc,StackHorizontal(p1c,sc,n1c),StackHorizontal(p2c,p1c,sc,n1c,n2c),StackHorizontal(p3c,p2c,p1c,sc,n1c,n2c,n3c)) \ .AudioDubEx(c).Trim(0,-c.FrameCount).DelayAudio(0.0) return (ShowAudio && HasAudio) ? WaveForm(window=Window,height=Height,under=Under,zoom=Zoom,marks=Marks) : Last }
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 28th January 2019 at 12:53. |
12th June 2019, 16:41 | #42 | Link | |
Small mod in blue, round size DOWN rather than nearest, easier to addborders to filmstrip to match up with original clip width. -ve H also now round down rather than nearest.
Function WaveForm_FilmStrip(clip c,int "Window",Float "Height",Bool "Under",Float "Zoom",Float "SubSize",Bool "ShowAudio",Int "W",Int "H") { /* Waveform_FilmStrip:- by StainlessS @ Doom9 ::: https://forum.doom9.org/showthread.php?p=1965005#post1965005 Where ShowAudio=True, Requires WaveForm v2.0 plugin (c) Wonkey_Monkey, https://forum.doom9.org/showthread.php?t=182866 [Wonkey_Monkey, The Prince formerly known as David.] WARNING - Marks arg no longer a setting in WaveForm v0.3 x64 or v2.0 - so removed from WaveForm_FilmStrip Also, Made Under default False as Suggested by Wonkey. WaveForm_FilmStrip(clip c,int "Window"=0,Float "Height"=0.333,Bool "Under"=FALSE,Float "Zoom"=1.0,Float "SubSize"=0.0,Bool "ShowAudio"=True,Int "W"=-1,Int "H"=W_Based) Window, Default 1 (0 <= Window <=3), Filmstrip thumbnail Images across = 2 * Window + 1. Height, Default 0.333=1/3 of FilmStrip Height. See Waveform docs for more. Under, Default False, If True, then audio graph stacked under video, else overlay over video. Zoom, Default 1.0. Amplify audio signal for viewing (1.0=No Amp). SubSize, Default 0.0(0.0 <= SubSize <= 1.0). Suggest 0.0(No Frame Number) to about 0.5. : 1.0=biggest size for current clip Height (probably too big). ShowAudio, Default True. If False, Switches OFF WaveForm Display, Shows FilmStrip Only. W, Default -1. Governs width of thumbnail images making up the FilmStrip. -ve) Entire FilmStrip width (multiple thumbnail images based on Window arg) will be about same [smaller or equal] as input clip width. 0) Each FilmStrip thumbnail image is SAME size as input clip, result could be a quite wide clip. Else) Each FilmStrip thumbnail image Width is set by W (best Mod 2). H, Default based off W. (Suggest Dont supply H arg, let it default based on W arg. Can call with H=Undefined where will behave as if defaulting). IF H is Supplied ie not defaulted THEN H = Supplied H # could be -ve, 0, or +ve(explicit height). else if W <= 0, then H = W, ELSE H = input clip height Aspect Ratio Scaled to match W. Here, H could be -ve, 0, or +ve, defaulted or non defaulted. Where H, -ve) FilmStrip height scaled down to Aspect Ratio match FilmStrip width of individual thumbnail images. 0) Each FilmStrip thumbnail image Height is SAME size as input clip height. Else) Each FilmStrip thumbnail image Height is set by H (best Mod 2). */ Window=Default(Window,0) Height=Max(Default(Height,0.333),0.0) Under=Default(Under,false) SubSize=Default(SubSize,0.0) ShowAudio=Default(ShowAudio,True) W=Default(W,-1) H=Default(H,W<=0?W:Int(W.Float/c.Width*c.Height)/2*2) Assert(0 <= window <= 3,"WaveForm_FilmStrip: 0 <= window <= 3") Assert(0.0 <= SubSize <= 1.0,"WaveForm_FilmStrip: 0.0 <= SubSize <= 1.0") Frms = 1 + (2*Window) WW=(W<0)?c.Width/(Frms*2)*2:(W==0)?c.width:W HH=(H<0)?c.Height/(Frms*2)*2:(H==0)?c.Height:H sc=(WW!=c.Width||HH!=c.Height) ?c.BiCubicResize(WW,HH,b=-0.5,c=0.25) :c scSubsSz=Round(sc.Height*SubSize) SSS="""Subtitle(String(current_frame,"%.0f")""" + String(scSubsSz,",SIZE=%.0f") + String((sc.Height-scSubsSz)/2.0,",Y=%.0f") + """,align=8)""" sc=(scSubsSz!=0)?sc.ScriptClip(SSS):sc bc=sc.BlankClip(Length=1,Color=$000000) p1c=bc+sc p2c=bc+p1c p3c=bc+p2c n1c=sc.FrameCount>1?sc.Trim(1,0)+bc:bc n2c=n1c.FrameCount>1?n1c.Trim(1,0)+bc:bc n3c=n2c.FrameCount>1?n2c.Trim(1,0)+bc:bc Select(Window,sc,StackHorizontal(p1c,sc,n1c),StackHorizontal(p2c,p1c,sc,n1c,n2c),StackHorizontal(p3c,p2c,p1c,sc,n1c,n2c,n3c)) \ .AudioDubEx(c).Trim(0,-c.FrameCount).DelayAudio(0.0) return (ShowAudio && HasAudio) ? WaveForm(window=Window,height=Height,under=Under,zoom=Zoom) : Last } Code:
#AviSource("D:\G.avi") Colorbars.Trim(0,-100) WINDOW = 3 # Frames Wide = 2 * WINDOW + 1 HEIGHT = 0.33 # Audio graphs height, 0.333 = 1/3 of result filmstrip image height. UNDER = false # True, then audio graphs stacked under video, else overlay over video. ZOOM = 1.0 # Amplify audio signal for viewing (1.0=No Amp). SUBSIZE = 0.5 # Suggest 0.0(off) to about 0.5. (0.0 <= SubSize <= 1.0) : 0.0 = No Frame Number, 1.0=biggest size for current clip Height (probably too big). SHOWAUDIO = True # Default True. If False, Switches OFF WaveForm Display, Shows FilmStrip Only. W = 264 # Default -1, (or 0 or +ve). -1 = Normal Downscale behaviour, filmstrip width ~= input clip width. #H = Undefined # Undefined, Let W govern height of thumbnail images (or just dont use h=H in function call, same as h=Undefined). ###### Can Remove this lot ###### TONE = False # Replace Colorbars tone with selected TONETYPE tone TONETYPE ="NOISE" # Pick from:- "Silence", "Sine", "Noise", "Square", "Triangle" or "Sawtooth" TONECHANS = 5 # Tone Channels Count (test channels display) # (TONE) ? AudioDub(Tone(Length=FrameCount/FrameRate,Type=TONETYPE,Channels=TONECHANS)) : Last ###### End Of Can Remove ###### WaveForm_FilmStrip(window=WINDOW,Height=HEIGHT,under=UNDER,zoom=ZOOM,subSize=SUBSIZE,ShowAudio=SHOWAUDIO,w=W) #,h=H) Return Last Window=3 W=-1(total width smaller or equal original width[640], out width=630[each thumb width mod 2, ie (Window*2+1)*90 = 7*90=630]) EDIT: Removed Marks arg, Made Under default False as Wonkey suggestion.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 2nd March 2022 at 20:54. |
5th August 2019, 17:08 | #43 | Link |
Wonkey, can we have some kind of center/zero marking, ta. [EDIT: maybe dotted, eg every 4th pixel]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 5th August 2019 at 17:10. |
5th August 2019, 17:49 | #45 | Link |
No great urgency W, takes your time.
Thank you for your consideration
11th November 2019, 11:06 | #46 | Link |
Mod to dotted request, maybe eg every 4th pixels, with alternate black/white dots.
2nd January 2020, 08:55 | #47 | Link |
wonkey_monkey,
The link in the opening post is labelled waveform0.3.zip, but the file that downloads is waveform0.2.zip, which seems odd as the link location is http://horman.net/waveform0.3.zip PS The link in post 20 downloads waveform0.3.zip which I assume is the correct one. http://horman.net/avisynth/download/waveform0.3.zip Cheers. Last edited by hello_hello; 2nd January 2020 at 08:59. |
11th February 2020, 17:41 | #49 | Link |
Wonkey, can you please delete links in these two posts [to old v0.2, 2nd link says 0.3 and even name on server says 0.3 but is 0.2]
Post #11, https://forum.doom9.org/showthread.p...25#post1589325 [EDIT: This link actually says v0.2, maybe you decide to keep it] Post #30, https://forum.doom9.org/showthread.p...47#post1845947 EDIT: Hello_Hello post [2 ahead] has correct link, as does 1st post link, and so does your "My Avisynth Filters" link.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th February 2020 at 18:01. |
11th February 2020, 21:45 | #50 | Link |
StainlessS,
I appear to have overlooked your WaveForm_FilmStrip() function until now. Maybe I didn't understand it or didn't pay enough attention at the time, but I made a similar a while back, originally only displaying meters, as I didn't discover the WaveForm plugin until somewhat recently. Minus your filmstrip idea though, because I'm not smart enough to think of that. It's probably the definition of pointless, but it amused me watching the kids play together. AudioWaveL(FT=true, Zoom=5.0) WaveForm_FilmStrip(Window=1, Zoom=5.0) AudioMeterR(FT=true) WaveForm_FilmStrip(Window=1, Zoom=5.0) Last edited by hello_hello; 26th February 2020 at 11:16. |
11th February 2020, 22:03 | #51 | Link |
Looks good HH.
WaveForm_FilmStrip() handy for sync audio to loud noise, gunshot or whatever [with multi-windows]. I considered recently (today I think, when seeing you post something in another thead) adding timestamp, instead_of / as_well_as frame number, maybe ShowSMPTE() or ShowTime().
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 11th February 2020 at 22:11. |
21st January 2021, 10:29 | #52 | Link |
Today I tried the waveform and found out that it causes severe audio crackling when the Tempo of the audio is increased.
My test file is pretty simple: Code:
LoadPlugin("C:\Programme (Portable)\AviSynth Addons\Plugins\ffms2-2.40-msvc\x64\ffms2.dll") LoadPlugin("C:\Programme (Portable)\AviSynth Addons\Plugins\waveform0.3\x64\waveform.dll") FFmpegSource2(source="SomeFile.avi", atrack=-1).TimeStretch(tempo=120) waveform() Thanks for your help. |
21st January 2021, 12:13 | #53 | Link |
Formerly davidh*****
waveform doesn't alter the audio. Either it's just too slow for ffplay to keep up, or there's some kind of audio seeking issue - waveform will cause audio access to be non-linear, because it will be seeking ahead while audio playback will be requesting the current frame's audio. You could try adding preroll(0,1) (or a higher value for the second parameter, depending how wide the waveform is) before waveform.
21st January 2021, 22:05 | #54 | Link |
I tried with Preroll(0,x) with x=0,1,2,5,10,100. No difference. The file is directly playing from SSD and the CPU is pretty much totally idle.
Edit: I found out that the audio file I had was broken. I reencoded it to aac and now everything works! Last edited by Roemer; 22nd January 2021 at 23:47. |
2nd March 2022, 20:16 | #55 | Link |
Updated post #42, WaveForm_Filmstrip(Bool Under="False") # As Wonkey suggestion,
also removed marks arg as no longer supported in v0.3 x64 or Waveform v2.0.
14th March 2023, 21:45 | #56 | Link |
Big Bit Savings Now !
I am trying to cobble an allscope script together, like VideoTek()
which tiles multiple scopes around the source frame plus overlays on top but waveform() behaves different as I would expect. The line StackVertical(topbar,unprop) makes waveform() see a silent 2-track audio. So waveform() does not want to see last audio from last StackVertical, but giving that clip a named variable and hand that to waveform() won't work either. If I give an explicit clip to waveform (unprop) waveform respects it. But then the last StackVertical() does nothing anymore, as if waveform would contain an implicit return() (AviSynth+64 3.7.3 test 7 under Win10Pro64, waveform 2.0.2) Code:
function allscopes (clip clp) { src=clp.ConvertToYV24() levcolsize=256 stereosize=512 level=src.Histogram(mode="levels", keepsource=false) color=src.Histogram(mode="color2", keepsource=false)#.ColorYUV(cont_Y=1000,cont_U=1000,cont_V=1000) histoy=src.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200) histox=src.turnleft.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200).turnleft() bargraph=src.Histogram(mode="audiolevels", keepsource=false) #overlay only, starts from left border and uses full height stereo=Histogram(src,mode="stereoY8", keepsource=false).ColorYUV(gamma_Y=200).ConvertToYV24()#512 x 512, Y8 or YV12 only luma=src.Histogram(mode="luma", keepsource=false) padup=src.height-(2*levcolsize) stackR=StackVertical(color, level) stackR=padup>0 ? StackVertical(stackR,BlankClip(level,height=padup)) : stackR stackC=StackHorizontal(src,histoy) stackC=padup<0 ? StackVertical(stackC,BlankClip(src,width=src.width+levcolsize,height=-padup)) : stackC stackA=stereo stackA=padup>0 ? StackVertical(stackA,BlankClip(stackA,width=stereosize,height=padup)) : stackA allstack=StackHorizontal(stackA,stackC,stackR) unprop=StackHorizontal(stackA,stackC,stackR).Histogram(mode="audiolevels") #unprop=AudioDub(unprop,allstack) #overlay only, starts from left border and uses full height topbarwidth=unprop.width topbarheight=24 topbartextshift=levcolsize topbar=src.BlankClip(width=topbarwidth,height=topbarheight).ShowFrameNumber(scroll=false, size=18, x=topbartextshift+16, y=16)\ .Subtitle("/"+String(src.framecount),align=4,x=topbartextshift+62,y=16).Subtitle("f",align=4,x=topbartextshift+110,y=16)\ .Subtitle("TC",align=4,x=topbartextshift+130,y=16).ShowSMPTE(size=18, x=topbartextshift+198)\ .ShowTime(size=18, x=topbartextshift+300).Subtitle("ms",align=4,x=topbartextshift+350,y=16)\ .Subtitle(String(clp.width)+"x"+String(clp.height)+"@"+String(clp.framerate)+"fps"+" " +String(clp.pixeltype)\ +" "+String(clp.bitspercomponent)+"bpc"+" | "+String(clp.audiochannels)+"-CH "+"@"+String(clp.audiorate)+"Hz"\ +" "+String(clp.audiobits)+"bit"+" " +String(clp.IsAudioFloat ? "float" : "int"),size=18, align=4, x=topbartextshift+384, y=16) StackVertical(topbar,unprop) waveform(height=0.25, window=2) return(last) }
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 14th March 2023 at 23:07. |
15th March 2023, 02:19 | #58 | Link |
Yees ! Many thanks, David.
So simple: I shall not assume that my preferred audio is kept, I just have to specify. Code:
function allscopes (clip clp) { src=clp.ConvertToYV24() isSMPTE= \ round(framerate(clp))*1000==23976 || round(framerate(clp))*1000==24000 || round(framerate(clp))*1000 == 25000 || round(framerate(clp)) ==29970 || round(framerate(clp)) ==30000 \ round(framerate(clp))*1000==47952 || round(framerate(clp))*1000==48000 || round(framerate(clp))*1000 == 50000 || round(framerate(clp)) ==59940 || round(framerate(clp)) ==60000 ? true : false levcolsize=256 stereosize=512 level=src.Histogram(mode="levels", keepsource=false) color=src.Histogram(mode="color2", keepsource=false)#.ColorYUV(cont_Y=1000,cont_U=1000,cont_V=1000) histoy=src.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200) histox=src.turnleft.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200).turnleft() bargraph=src.Histogram(mode="audiolevels", keepsource=false) #overlay only, starts from left border and uses full height stereo=Histogram(src,mode="stereoY8", keepsource=false).ColorYUV(gamma_Y=200).ConvertToYV24()#512 x 512, Y8 or YV12 only luma=src.Histogram(mode="luma", keepsource=false) padup=src.height-(2*levcolsize) stackR=StackVertical(color, level) stackR=padup>0 ? StackVertical(stackR,BlankClip(level,height=padup)) : stackR stackC=StackHorizontal(src,histoy) stackC=padup<0 ? StackVertical(stackC,BlankClip(src,width=src.width+levcolsize,height=-padup)) : stackC stackA=stereo stackA=padup>0 ? StackVertical(stackA,BlankClip(stackA,width=stereosize,height=padup)) : stackA allstack=StackHorizontal(stackA,stackC,stackR) unprop=StackHorizontal(stackA,stackC,stackR).Histogram(mode="audiolevels") #unprop=AudioDub(unprop,allstack) #overlay only, starts from left border and uses full height topbarwidth=unprop.width topbarheight=24 topbartextshift=levcolsize isSMPTE==true ? Eval(""" topbar=src.BlankClip(width=topbarwidth,height=topbarheight).ShowFrameNumber(scroll=false, size=18, x=topbartextshift+16, y=16)\ .Subtitle("/"+String(src.framecount),align=4,x=topbartextshift+62,y=16).Subtitle("f",align=4,x=topbartextshift+0,y=16)\ .ShowTime(size=18, x=topbartextshift+172).Subtitle("ms",align=4,x=topbartextshift+222,y=16)\ .Subtitle("TC",align=4,x=topbartextshift+258,y=16)\ .ShowSMPTE(size=18, x=topbartextshift+328, y=16)\ .Subtitle(String(clp.width)+"x"+String(clp.height)+"@"+String(clp.framerate)+"fps"+" " +String(clp.pixeltype)\ +" "+String(clp.bitspercomponent)+"bpc"+" | "+String(clp.audiochannels)+"-CH "+"@"+String(clp.audiorate)+"Hz"\ +" "+String(clp.audiobits)+"bit"+" " +String(clp.IsAudioFloat ? "float" : "int"),size=18, align=4, x=topbartextshift+384, y=16,text_color=$00FF00) """) \ : Eval(""" topbar=src.BlankClip(width=topbarwidth,height=topbarheight).ShowFrameNumber(scroll=false, size=18, x=topbartextshift+16, y=16)\ .Subtitle("/"+String(src.framecount),align=4,x=topbartextshift+62,y=16).Subtitle("f",align=4,x=topbartextshift+0,y=16)\ .ShowTime(size=18, x=topbartextshift+172).Subtitle("ms",align=4,x=topbartextshift+222,y=16)\ .Subtitle("(no SMPTE-TC)",align=4,x=topbartextshift+258,y=16,text_color=$EE8800)\ .Subtitle(String(clp.width)+"x"+String(clp.height)+"@"+String(clp.framerate)+"fps"+" " +String(clp.pixeltype)\ +" "+String(clp.bitspercomponent)+"bpc"+" | "+String(clp.audiochannels)+"-CH "+"@"+String(clp.audiorate)+"Hz"\ +" "+String(clp.audiobits)+"bit"+" " +String(clp.IsAudioFloat ? "float" : "int"),size=18, align=4, x=topbartextshift+384, y=16,text_color=$00FF00) """) StackVertical(topbar,unprop) AudioDub(unprop) waveform(height=0.25, window=2) return(last) } Thinking about narrower audio bargraphs now, 2 of them already eating too much screen. There are so many nice and tiny bargraphs in other apps, lets see.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 15th March 2023 at 02:26. |
15th March 2023, 09:04 | #59 | Link |
With autoscaling topbar and bits>=8
color2 is not HBD ready yet (graph too wide), well, levels looks wrong too in HBD, graph too narrow. histox is for later, lets see where I put it. Code:
function allscopes (clip clp) { src=clp.ConvertToYUV444() bpc=clp.bitspercomponent() fontsize= 6+ceil(width(clp)/480.0)*6 isSMPTE= \ round(framerate(clp))*1000==23976 || round(framerate(clp))*1000==24000 || round(framerate(clp))*1000 == 25000 || round(framerate(clp))*1000 ==29970 || round(framerate(clp))*1000 ==30000 \ round(framerate(clp))*1000==47952 || round(framerate(clp))*1000==48000 || round(framerate(clp))*1000 == 50000 || round(framerate(clp))*1000 ==59940 || round(framerate(clp))*1000 ==60000 ? true : false levcolsize=256 stereosize=512 level=src.Histogram(mode="levels", keepsource=false) color=src.Histogram(mode="color2", keepsource=false)#.ColorYUV(cont_Y=1000,cont_U=1000,cont_V=1000) histoy=src.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200) histox=src.turnleft.Histogram(mode="classic", keepsource=false).ColorYUV(gamma_Y=200).turnleft() bargraph=src.ConvertBits(8).ConvertToYV24().Histogram(mode="audiolevels", keepsource=false).ConvertBits(bpc) #overlay only, starts from left border and uses full height stereo=src.ConvertBits(8).Histogram(mode="stereoY8", keepsource=false).ColorYUV(gamma_Y=200).ConvertToYV24().ConvertBits(bpc)#512 x 512, Y8 or YV12 only luma=src.Histogram(mode="luma", keepsource=false) padup=src.height-(2*levcolsize) stackR=StackVertical(color, level) stackR=padup>0 ? StackVertical(stackR,BlankClip(level,height=padup)) : stackR stackC=StackHorizontal(src,histoy) stackC=padup<0 ? StackVertical(stackC,BlankClip(src,width=src.width+levcolsize,height=-padup)) : stackC stackA=stereo stackA=padup>0 ? StackVertical(stackA,BlankClip(stackA,width=stereosize,height=padup)) : stackA allstack=StackHorizontal(stackA,stackC,stackR) unprop=StackHorizontal(stackA,stackC,stackR).ConvertBits(8).Histogram(mode="audiolevels").ConvertBits(bpc) topbarwidth=unprop.width topbarheight=fontsize*4/3 topbartextshift=levcolsize isSMPTE==true ? Eval(""" topbar=src.BlankClip(width=topbarwidth,height=topbarheight).ShowFrameNumber(scroll=false, size=fontsize, x=topbartextshift+fontsize, y=topbarheight*2/3)\ .Subtitle("/"+String(src.framecount),size=fontsize, align=4,x=topbartextshift+(fontsize*4),y=topbarheight*2/3).Subtitle("f",size=fontsize, align=4,x=topbartextshift+0,y=topbarheight*2/3)\ .ShowTime(size=fontsize, x=topbartextshift+(fontsize*41/4), y=topbarheight*2/3).Subtitle("ms",size=fontsize, align=4,x=topbartextshift+(fontsize*13),y=topbarheight*2/3)\ .Subtitle("TC",align=4,x=topbartextshift+(fontsize*15), y=topbarheight*2/3)\ .ShowSMPTE(size=fontsize, x=topbartextshift+(fontsize*19), y=topbarheight*2/3)\ .Subtitle(String(clp.width)+"x"+String(clp.height)+"@"+String(clp.framerate)+"fps"+" " +String(clp.pixeltype)\ +" "+String(clp.bitspercomponent)+"bpc"+" | "+String(clp.audiochannels)+"-CH "+"@"+String(clp.audiorate)+"Hz"\ +" "+String(clp.audiobits)+"bit"+" " +String(clp.IsAudioFloat ? "float" : "int"),size=fontsize, align=4, x=topbartextshift+(fontsize*22), y=topbarheight*2/3,text_color=$00FF00) """) \ : Eval(""" topbar=src.BlankClip(width=topbarwidth,height=topbarheight).ShowFrameNumber(scroll=false, size=fontsize, x=topbartextshift+fontsize, y=topbarheight*2/3)\ .Subtitle("/"+String(src.framecount),size=fontsize, align=4,x=topbartextshift+(fontsize*4),y=topbarheight*2/3).Subtitle("f",size=fontsize, align=4,x=topbartextshift+0,y=topbarheight*2/3)\ .ShowTime(size=fontsize, x=topbartextshift+(fontsize*41/4), y=topbarheight*2/3).Subtitle("ms",size=fontsize, align=4,x=topbartextshift+(fontsize*13),y=topbarheight*2/3)\ .Subtitle("(no SMPTE-TC)",size=fontsize, align=4,x=topbartextshift+(fontsize*15), y=topbarheight*2/3,text_color=$EE8800)\ .Subtitle(String(clp.width)+"x"+String(clp.height)+"@"+String(clp.framerate)+"fps"+" " +String(clp.pixeltype)\ +" "+String(clp.bitspercomponent)+"bpc"+" | "+String(clp.audiochannels)+"-CH "+"@"+String(clp.audiorate)+"Hz"\ +" "+String(clp.audiobits)+"bit"+" " +String(clp.IsAudioFloat ? "float" : "int"),size=fontsize, align=4, x=topbartextshift+(fontsize*22), y=topbarheight*2/3,text_color=$00FF00) """) StackVertical(topbar,unprop) AudioDub(unprop) waveform(height=0.25, window=2) return(last) }
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 15th March 2023 at 09:39. |
