Old 29th October 2005, 13:14   #781  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Originally Posted by nexus
Newly discovered issue:
In AAC Encoding Tab the descriptions aren't sourced out to the .ini, is that right? This concerns FAAC and Winamp encoder.
not an issue. It's because I don't translated these parts yet...I'm working on it.
You (all) can find almost every day an updated version of Deutsch.ini in the thread mentioned above.
ok...did you start with the Megamacy translation or did you made the German translation from scratch ?
@Drob : I know...I'm working on it.
Old 29th October 2005, 14:38   #782  |  Link
megamacy
hm, seems like i'm out of work now ^^
but my actual translation is for the latest daily build
(http://corecodec.org/forum/forum.php...8&forum_id=128)
megamacy is offline   Reply With Quote
Old 31st October 2005, 18:34   #783  |  Link
nexus
digitally remastered
nexus's Avatar
We started with the English.ini because I didn't knew that there's already a Deutsch.ini. But I thinks ours is better.
Can you post it if you add new lines to the language.ini?
@megamacy: Thought you won't work on the Deutsch.ini anymore?! It doesn't make sense to work on two different Deutsch.ini files. If there are any problems please contact me via Germans forum PM or post in the accordant thread there.
May The FourCC Be With You
nexus is offline   Reply With Quote
Old 31st October 2005, 22:43   #784  |  Link
Kurtnoise
Kurtnoise's Avatar
yep...in the next build.
Old 6th November 2005, 09:41   #785  |  Link
nexus
nexus's Avatar
Great!
Everybody seems to be satisfied with our latest translation so it will be a good idea if you add our language file in the next build. As always: here .
Old 6th November 2005, 11:17   #786  |  Link
Kurtnoise
Kurtnoise's Avatar
Check out the lastest daily build to update your file...
Old 6th November 2005, 11:20   #787  |  Link
Elias
Be Brave!
Elias's Avatar
So how long will BeLight be Beta? I don't think it's fair to call it beta any longer, because it's pretty stable nowadays
Elias is offline   Reply With Quote
Old 6th November 2005, 12:51   #788  |  Link
MacAddict
XviD User
Latest daily build breaks Nero encoding with "unable to get bsn interfaces"??? Or is it just me?
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2
MacAddict is offline   Reply With Quote
Old 6th November 2005, 13:41   #789  |  Link
Kurtnoise
Kurtnoise's Avatar
No it isn't...
Old 6th November 2005, 13:43   #790  |  Link
Kurtnoise
Kurtnoise's Avatar
be sure to have bse_Nero7WA.dll...I'll add condition to switch bse_Nero7 and bsn asap.
Old 6th November 2005, 15:21   #791  |  Link
MacAddict
XviD User
Thanks Kurt, that did the trick :-)
Old 6th November 2005, 15:43   #792  |  Link
nexus
nexus's Avatar
Deutsch.ini updated. Maybe you should include it in the daily build.
Old 6th November 2005, 19:24   #793  |  Link
Marcovelo
Hello experts !
I'm trying to encode a 6ch wav in AAC using BeLight 0.2.2.0 beta 8 and BeSweet v1.5b31.
I'm getting this log:
BeSweet v1.5b31 by DSPguru.
Using Shibatch.dll v0.25 by Naoki Shibata & DSPguru (shibatch.sourceforge.net).
Using bse_FAAC by dimzon, Build Sep 14 2005, 11:26:17
Logging start : 11/06/05 , 18:54:40.
BeSweet.exe -core( -input C:\Temp\util_Audio\BeLight\TestSequence_48_16b.wav -output C:\Temp\util_Audio\BeLight\TestSequence_48_16b.aac -logfile C:\Temp\util_Audio\BeLight\TestSequence_48_16b_3.log ) -dimzon( -dllname bse_FAAC.dll -b 128 --obj-type LC -6chnew )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : C:\Temp\util_Audio\BeLight\TestSequence_48_16b.wav
[00:00:00:000] | Output: C:\Temp\util_Audio\BeLight\TestSequence_48_16b.aac
[00:00:00:000] | Floating-Point Process: No
Error 84: error configuring bsn!
Quiting...
[00:00:00:000] Conversion Completed !
Logging ends : 11/06/05 , 18:54:40.
Strange, because I didn't invoke -bsn option (Nero), -dimzon( -dllname bse_FAAC.dll ...
By the way, I was able to encode my 6chwav using FAAC.exe (1.24) from commandline:
-> faac.exe TestSequence_48_16b.wav -q 125 -o TestSequence_48_16b.aac
The resulting .aac seems to be correct when played in VLC 0.8.2, with correct channel mapping (5.1).
Any suggestion about my problem with BeLight would be very appreciated...
Thanks in advance
Marco
PS: Big thanks to Kurtnoise and Dimzon for BeLight and plugins .
Marcovelo is offline   Reply With Quote
Old 6th November 2005, 19:56   #794  |  Link
Kurtnoise
Kurtnoise's Avatar
Thanks..I'll included it tomorrow. I need to tune different things before to release a new build.
Old 6th November 2005, 19:57   #795  |  Link
Kurtnoise
Kurtnoise's Avatar
Marcovelo : what kind of Sampling Rate did you have concerning your input stream ?
Old 7th November 2005, 00:04   #796  |  Link
Marcovelo
Kurt:
my imput stream is Wav (non extensible): TestSequence
samplerate = 48000
channels = 6
codec = PCM
bitspersample = 16
I built this input wav using BeSweet from 6 mono wav 48Khz 16 bits:
besweet -core ( -input "list.mux" -output "TestSequence_48_16b.wav" -6chwav )
Thanks for your advices
Marco
Old 7th November 2005, 01:20   #797  |  Link
tebasuna51
tebasuna51's Avatar
For me work without problems.
Logging start : 11/07/05 , 01:24:28.
BeSweet.exe -core( -input G:\TestSequence_48_16b.wav
 -output G:\TestSequence_48_16b.aac
 -logfile G:\TestSequence_48_16b.log )
[00:00:00:000] |  Input : G:\TestSequence_48_16b.wav
[00:00:00:000] |  Output: G:\TestSequence_48_16b.aac
[00:00:00:000] |  Source Sample-Rate: 48.0KHz
[00:00:00:000] +---------------------
[00:00:05:836] Conversion Completed !
[00:00:01:000] <-- Transcoding Duration
Logging ends : 11/07/05 , 01:24:29.
The wav6 is absolutely correct and the aac plays fine and well channel mapping.
Old 7th November 2005, 01:42   #798  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
The new built (BeLight-0.22beta_20051106.zip) still looks like this:
Old 7th November 2005, 11:06   #799  |  Link
Kurtnoise
Kurtnoise's Avatar
weird...try to remove BeLight.ini file and reload BeLight coz I really don't know why.
btw, for those who want to test a new preversion I updated a new daily build : http://corecodec.org/frs/?group_id=4...se_id=212#r212
Old 7th November 2005, 16:14   #800  |  Link
Marcovelo
@tebasuna51:
Thanks for your test.
I'll check again my configuration, as I still don't see why it does not work on my side.
I just tried again with the same (short) path for file names, but I still get the same error...
I think I have exactly the same version of BeSweet (v1.5b31) and bse_FAAC.dll (Build Sep 14 2005, 11:26:17)...
Very strange...
I will tell you if I found the solution...
@Kurt:
I also experience the same problem of display than reported by LoRd_MuldeR on today's BeLight build.
Deleting BeLight.ini and running again BeLight.exe is not better.
This small pb is not present with BeLight 0.21 on the same PC.
