25th June 2010, 11:20 | #1181 | Link | |
audio: 3.1 to 2.0
i've run into the following issue trying to downmix + slow down 3.1 ac3 tracks to 2.0 ac3. i ended up with 3.1 encodes instead of 2.0. tried two similar source files. all relevant info (hopefully) given below. megui updated yesterday to all development updates.
25th June 2010, 12:28 | #1182 | Link | |
You can create a specific avs file to downmix others channels configurations, for instance: Code:
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\NicAudio.dll") a=NicAc3Source("D:\SomePath\SomeAudio01\SomeAudio01 T82 3_0ch 384Kbps DELAY 0ms.ac3") flr = GetChannel(a, 1, 2) fcc = GetChannel(a, 3, 3) lfe = GetChannel(a, 4, 4) clf = MixAudio(fcc, lfe, 0.2929, 0.2929) MixAudio(flr, clf, 0.4142, 1.0) Include the slowdown (if you need) and normalize after. The downmix work fine for the first sample (L,R,C,LFE), with the second (L,R,C,S) you need this mix: Code:
flr = GetChannel(a, 1, 2) fcc = GetChannel(a, 3, 3) lrc = MixAudio(flr, fcc, 0.4142, 0.2929) sl = GetChannel(a, 4) sr = Amplify(sl, -1.0) blr = MergeChannels(sl, sr) MixAudio(lrc, blr, 1.0, 0.2929)
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 25th June 2010 at 12:44. |
25th June 2010, 12:59 | #1183 | Link |
thanks so much tebasuna51, i'll try that right away.
also i have a totally stupid question: i don't understand the sample02 chan configuration: L C R, Side: C; what is "Side: C"? Edit: i just tried this second sample in Ac3 filter it shows left, center, right and.. SL (side left), what kinda weird configuration is that? could it be a broken (in some way) audio track? Last edited by Vincent Vega; 25th June 2010 at 13:04. |
26th June 2010, 03:01 | #1184 | Link | |
L C R S (acmod 5 in ac3 header) means: Left Center Right Surround equivalent (after remapping) to wav channels FL FR FC BC FrontLeft FrontRight FrontCenter BackCenter If you don't have a Back Center speaker a proper player must play the BC in BL-BR
26th June 2010, 07:03 | #1185 | Link |
so if AC3Filter plays the Surround channel in SL only it's a bug in it? i've always liked valex's decoder so much.. what ds filter would you recommend that can handle such chan config properly?
26th June 2010, 11:36 | #1186 | Link | |
With ffdshow you can remap (matrix mixer) the BC to BL-BR with 0.7071 coefficients.
29th June 2010, 14:54 | #1188 | Link |
Mr. Sandman
nice to see Zathor worked on MeGUI while i was away
29th June 2010, 15:01 | #1190 | Link |
Mr. Sandman
it seems you did a huge work zathor. thank you.
i guess i have to study the latest sources almost from scratch. feel free to contact me and, obviously, give me some days and i will be back developing megui
30th June 2010, 11:36 | #1193 | Link |
Practising Schemer
Has anyone else had trouble in megui with Warpsharp.dll and toon.dll.
I removed both dll's and my megui encodes perfectly. I replaced warpsharp.dll with the version from warpenterprises and it stopped the error. But I re added toon.dll to my avisynth plugins and it cannot complete an encode with the toon.dll being used. Does anyone have a light toon/anime dll that plays well with megui. I haven't had to encode much anime previously. |
30th June 2010, 13:22 | #1194 | Link |
Mr. Sandman
@flebber: it seems an avisynth problem more than a megui problem... try to find newer version of the toon plugin.
@Taurus: thanks, i had "troubles" of all kinds... @JoeH: thanks
30th June 2010, 13:49 | #1195 | Link |
changes to --level and --profile in their new location do not update the commandline below until after you close and save the x264 configuration dialog. and i still think they should be basic x264 settings.
edit and i dont think the threads checkbox or field is working. nvm i think it's just doing the same thing as level and profile. Last edited by quantum5uicid3; 30th June 2010 at 13:52. |
30th June 2010, 13:52 | #1196 | Link |
Mr. Sandman
i think i read somewhere zathor is working on the x264 configuration window.
1st July 2010, 15:37 | #1198 | Link |
some fixes to profiles. ***for latest x264***
1. added "--open-gop coded" to bluray and avchd presets. 2. force disabled bframes and soft enabled CABAC for iphone profile. 3. force disabled b-pyramid and soft enabled CABAC for psp profile. 3. and removed redundency of setting vbv to 10000 when level 3 is already set. *correction* http://www.mediafire.com/?zgr5wz25iim md5: 75f2898b57f84b501ab92b2d0c31161a addition i packaged ffm2-312 for the update server too just in case you hadn't had time. it seems stable. http://www.mediafire.com/?qwgnnyjmmzc md5: e8a202a143774340d7ee869ea52694f3 edit2: wasnt thinking and disabled bframes completely on psp also, the motorola droid supports --level 3.1 --profile baseline --ref 5 @ 856x480 Last edited by quantum5uicid3; 2nd July 2010 at 05:16. |
1st July 2010, 18:48 | #1200 | Link |
Mr. Sandman
im pretty good and recovering well but my health is OT here
however, thanks
