19th December 2017, 17:22 | #5862 | Link | |
Personally if I make more complicated scripts I use AvsPmod. Last edited by Gser; 19th December 2017 at 17:27. |
19th December 2017, 18:01 | #5863 | Link |
The internal functions for syntax highlighting are hard-coded in CAvisynth.cpp in the VDub script editor code. Modifying the code to retrieve the functions dynamically should be rather simple.
Groucho's Avisynth Stuff |
19th December 2017, 18:42 | #5864 | Link |
@Gser:
That's what I mean ... AFAIR, TFM only flags frames, but it does not alter the clip's frame content. So, to remove duplicate fields, one would need a "TFM flag aware" other filter after TFM. Am I wrong here? |
19th December 2017, 19:40 | #5865 | Link | |
I'll tell you if it ever happens again with another disc |
19th December 2017, 22:06 | #5867 | Link |
For me, the main window remembers its size.
Check if it is able to update its settings.xml (one of the reasons why it should not be installed in an UAC protected directory like C:\Program Files...). |
21st December 2017, 17:51 | #5868 | Link |
MeGUI 2800 Development Server (Portable Version): My main window remembers its size and position, and once I adjust my Worker 1 window position it remembers every time it's used until I close MeGUI (not that I ever do ). None of my Tool windows (Stream Extractor, Bitrate Calculator, etc.) remembers its position, but this isn't an issue for me.
21st December 2017, 23:24 | #5870 | Link |
2804 [OneClick] + [FileIndexer] show playlist selection window for DVD/Blu-ray structures also if only one playlist is found 2803 [HD Streams Extractor] added support for "E-AC3 Surround" 2802 [OneClick] enhanced suitable container type detection 2801 [OneClick] fixed video name not written sometimes (regression of 2791). bug #901 |
23rd December 2017, 01:01 | #5872 | Link | |
So TFM definitely gets an occasional look in when encoding PAL, although usually only when it's needed for field matching as I usually disable it's de-interlacing anyway TFM(pp=1). If the source is interlaced or partially interlaced I prefer to run QTGMC the standard way rather than create an external de-interlaced clip for TFM to use, and TFM won't de-interlace to "double frame rate" anyway. Actually TFM could use an update in that respect. When it's in VFR mode it'd be nice if it could de-interlace to 50fps/59.940fps rather than 25fps/29.970fps. I should ask about it in the TIVTC thread. |
23rd December 2017, 01:19 | #5873 | Link |
I believe your reply does not answer my question. And I still believe you missed the whole point.
Does TFM on its own (without a following TIVTC or TDecimate) change the number or order of fields or frames, at all? |
23rd December 2017, 07:13 | #5874 | Link | |
There's a sample of the type of PAL source I referred to in my last post, attached to the opening post here. It looks interlaced and smells interlaced but it's progressive and all that's required to fix it is TFM(pp=0). For progressive PAL sources with shifted fields it's usually quite safe to disable TFM's de-interlacing as I'd assume they're shifted by the same amount from beginning to end so there shouldn't be any de-interlacing required. When a PAL source appears to be interlaced but I think it should be progressive, I'm in the habit of disabling TFMs de-interlacing for testing anyway, so then if the combing disappears I know it must be the result of field matching and I won't be fooled into thinking it's not interlaced when it is. Last edited by hello_hello; 23rd December 2017 at 09:04. |
24th December 2017, 15:15 | #5875 | Link |
It must be a while since I've encoded a PAL source with phase shifted fields, but I was reading through the VideoHelp thread I linked to for a memory refresh, and it reminded me I've used jagabo's suggestion from post #7 for outputting progressive frames successfully, no TFM required, because generally the fields will be phase shifted from beginning to end. All you need to do is separate them, remove the first one, then weave them back together again.
SeparateFields() Trim(1,0) Weave() |
26th December 2017, 19:53 | #5878 | Link |
Opus-tools v0.1.10-12-g1a79305 (using libopus 1.2.1) (GCC 7.2.0, 32 & 64-bit Windows Binaries )
https://git.xiph.org/?p=opus.git;a=summary https://git.xiph.org/?p=opus-tools.git;a=summary |
27th December 2017, 11:21 | #5879 | Link | |
Thanks, waiting for the komisar builds.
27th December 2017, 11:57 | #5880 | Link | |
Sent from my SM-G935F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else. |
