7th September 2011, 22:12 | #12841 | Link |
@colinhunt
Hi! See my post from last year: http://forum.doom9.org/showpost.php?...postcount=9533 (Similar in concept to "The Girl..." series) |
8th September 2011, 13:15 | #12843 | Link |
You can do a movie-only backup of any legally authored disc. In the link the source violated the Blu-Ray standard. I'll see if I can get "A Star is Born" and test it.
8th September 2011, 19:06 | #12846 | Link |
Yup, that's the one. Here's some info, just in case.
"Warner Bros. dedicates this film" text screen preceding the movie is a file named 00064.m2ts: Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : AP@L3 Codec ID : 234 Duration : 21s 104ms Bit rate : 1 690 Kbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.034 Stream size : 4.25 MiB (82%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 22s 48ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 172 KiB (3%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 22s 48ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 172 KiB (3%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 22s 48ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 172 KiB (3%) Main movie is 00020.m2ts: Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : VC-1 Format profile : AP@L3 Codec ID : 234 Duration : 2h 55mn Bit rate : 24.9 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 fps Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.501 Stream size : 30.6 GiB (86%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : DTS Format/Info : Digital Theater Systems Format profile : MA / Core Muxing mode : Stream extension Codec ID : 134 Duration : 2h 55mn Bit rate mode : Variable Bit rate : 2 425 Kbps / 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Compression mode : Lossless / Lossy Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Format profile : Dolby Digital Mode extension : CM (complete main) Codec ID : 129 Duration : 2h 55mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 242 MiB (1%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 2h 55mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 242 MiB (1%) 00064.m2ts is played first, followed seamlessly by 00020.m2ts. If you skip back to the beginning of the movie, playback resumes from start of 00020.m2ts; 00064.m2ts is not played. Last edited by colinhunt; 8th September 2011 at 19:14. |
9th September 2011, 03:28 | #12847 | Link |
I just shrank a Blu-ray movie, The Lincoln Lawyer, by using BD-Rebuilder. As a result, when I play it with PowerDVD 11, the Audio lags behind the video.
Has anyone had this kind of problem? Could somebody tell me how to resolve it? [04:58:59] BD Rebuilder v0.38.09 (beta) - Source: THE_LINCOLN_LAWYER - Input BD size: 34.31 GB - Approximate total content: [01:58:28.935] - Target BD size: 7.84 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [04:58:59] PHASE ONE, Encoding - [04:58:59] Extracting A/V streams [VID_00436] - [05:20:44] Reencoding: VID_00436 (1 of 1) - [05:20:44] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 170,444 frames - Bitrate: 7,966 Kbs - [05:20:44] Reencoding: VID_00436, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - [07:32:39] Reencoding: VID_00436, Pass 2 of 2 - [09:49:02] Video Encode complete - [09:49:02] Reencoding audio tracks (if req'd) - [09:53:16] Multiplexing M2TS [09:57:18]PHASE ONE complete [09:57:18]PHASE TWO - Rebuild Started - [09:57:18] Rebuilding AVCHD file Structure [10:01:35] - Encode and Rebuild complete [10:01:35]JOB: THE_LINCOLN_LAWYER finished. |
9th September 2011, 14:50 | #12849 | Link | |
But I don't understand your report... you're reporting output that has audio sync issues, but your log shows an encode failure? I'd recommend you reinstall from scratch following the directions in the first post of this thread. I'd also suggest that if you are overclocked, you lower the speed. Something is clearly wrong, and it looks like your system -- as the encode had issues during the first pass. |
9th September 2011, 14:59 | #12851 | Link | |
9th September 2011, 15:22 | #12852 | Link |
Another full backup to BD9, this time Your Highness, results in DTS HD Master 5.1/48kHz/24 bit being converted to DD 2.0 640kbps.
Some additional info: This is a multi-part .m2ts movie, with a theatrical and extended version option. Regardless of choice, the original DTS HD Master is converted to DD2.0 640kbps. NOTE: only the last .m2ts of either version is converted properly to DD 5.1 640kbps. This is what I find with the audio AVS: Incorrectly converted: Code:
#Created by BD Rebuilder - v0.38.09 (beta) LoadPlugin("C:\Users\Ed\Desktop\BD-RBV03809C\tools\nicaudio.dll") audio=DirectShowSource("G:\YOUR_HIGHNESS BDRB\WORKFILES\AUD_50285_4352.mkv").Amplify(1.2) ConvertAudioTo16bit(ResampleAudio(audio, 48000)) Code:
#Created by BD Rebuilder - v0.38.09 (beta) LoadPlugin("C:\Users\Ed\Desktop\BD-RBV03809C\tools\nicaudio.dll") audio=NicDTSSource("50306.track_4352.dts").Amplify(1.2) ConvertAudioTo16bit(ResampleAudio(audio, 48000)) When BD-RB converts the audio file with NicDTSSource on the .dts file it converts properly to DD 5.1 640kbps. Last edited by Capsbackup; 9th September 2011 at 15:40. |
9th September 2011, 16:04 | #12853 | Link |
While it is encoding, could you check your FFDSHOW audio decoder configuration? The "Mixer" checkbox should be unchecked. When the mixer is selected the default is for the audio to be converted to 2/0 (stereo). In BD-RB I manually turn that setting off during DirectShowSource() encoding and then reset it to its original value upon completion. The only thing I can imagine is if the setting is not "taking".
BD-RB uses this strategy on multi-part sources because NicDTSSource() isn't exact in it's timing, which can sometimes cause timing problems when attempting playback on full backups. If you look at the DD output of DTS sources when using NicDTSSource() you'll see that the audio length is very slightly different than the original. On a single-part movie it is no big deal and can be ignored, but it becomes an issue on multi-part playback (with certain players, e.g. Samsung). Last edited by jdobbs; 9th September 2011 at 16:08. |
9th September 2011, 16:12 | #12856 | Link |
I have unchecked it now. I have never made any selection to that area of the ffdshow audio decoder before, so it does appear that if BD-RB is making that change as necessary, it is not reverting back to unchecked when completed.
9th September 2011, 16:36 | #12858 | Link | |
So if it should be normally checked, I will do that. Are you saying to us users that we need to verify the source first before making a selection to this ffdshow audio decoder mixer selection?? Or, most likely BD-RB should be checking/unchecking if source is DTS or not! Last edited by Capsbackup; 9th September 2011 at 16:54. |
9th September 2011, 17:12 | #12859 | Link | |
9th September 2011, 17:27 | #12860 | Link | |
