22nd April 2011, 22:23 | #11821 | Link | |
23rd April 2011, 05:20 | #11826 | Link |
If bd rebuilder is anything like Dvd rebuilder, then it doesn't like dirty files. By dirty, I mean any imperfections in the files/code, that rebuilder doesn't like. Thankfully, my iHES108 Bd drive, doesn't do TOO poor a job LOL! It does have a tendency of introducing minor artifacting. But it hasn't done it since the firmware upgrade. Could be coincidence. Time will tell...
23rd April 2011, 15:43 | #11827 | Link |
BD Rebuilder v0.37.08 (beta)
I have updated the first post of this thread with links to a new release of BD-RB (v0.37.08). Changes for this version are:
- Corrected an issue in which resizing a source from 480i/29.97 to 720p would result in an TSMUXER "Non standard fps value" error during the remuxing. - Developed new routines so resizing of subtitle streams is now done by BD-RB (rather than via TSMUMXER). This corrects several possible issues associated with resizing PGS streams. - Corrected an issue in which opening a feature in movie-only mode that contains IGS in the main-movie stream could result in a "Selected Source is not BD Format" error. - Rebuilt the algorithms for checking subtitle sources. This should eliminate the TSMUXER error "Unexpected byte" and failure that could sometimes occur while extracting audio/subs and resizing to 720p. - Corrected an issue in movie-only mode in which "forced" subtitle (e.g. when foreign languages are spoken) were not supported during resizing. - Added support for subtitles when outputting to ALTERNATE/DVD. Note that the conversion of the graphics and integration into the output stream adds approx 2 minutes to the overall job for each subtitle kept, so it is recommended you only select the subtitles you really want. - Add a new hidden option "DVD_SUB_BACKGROUND". It lets you select the type of background you'd like for DVD output (see HIDDENOPTS.TXT). - Add a new hidden option "DVD_SUB_COLOR". It lets you select the subtitle foreground color you'd like for DVD output (see HIDDENOPTS.TXT). - Updated the included version of X264.EXE to the latest release (r1937). - Updated the included version of X264-64.EXE to the latest release (r1936). - Other minor corrections and cosmetic fixes. |
23rd April 2011, 16:01 | #11829 | Link |
Much appreciated. Writing the SUP/PGS handling routines turned out to be a little more work than I expected -- but they work well now. No more "Unexpected byte" errors from TSMUXER when resizing now. It also made it possible for me to automatically include subs in DVD output and fix the "forced subs disappearing" problem from TSMUXER.
23rd April 2011, 17:37 | #11833 | Link |
Great work! BD-Rebuilder has definitely come a long way since the first time I used it (which it didn't work for me at that time). I would LOVE to see a program removal feature added to this tool so that I can remove unwanted chains from the final result (like annoying advertisements & such). In fact, I'd be glad to even pay for such a feature. That's how annoying those things are to me. I was unable to find a feature request area so I apologize for this post being in the wrong place.
23rd April 2011, 17:48 | #11834 | Link | |
23rd April 2011, 18:24 | #11835 | Link | |
23rd April 2011, 20:10 | #11836 | Link | ||
Thanks for the new version!! seems like the problem with the Black hawk down will be solved in the next release, in the previous builds i see the error you mentioned in the changelog: Quote:
a question: What is IGS? jdobbs Last edited by jdobbs; 23rd April 2011 at 23:19. |
23rd April 2011, 22:34 | #11837 | Link |
@jdobbs
Thank you for the latest update v0.37.08. I did a first test with the new subs feature on Alternate PAL DVD. The subtitles flash up for the duration of 1 frame or so only, i.e. something with the display time seems to be wrong. The time stamps of the extracted sup from the original m2ts appear to be correct and the subtitle displays correctly for the BD. I will occasionally try with another disc. |
23rd April 2011, 23:12 | #11838 | Link | |
24th April 2011, 07:14 | #11840 | Link | |
Start and stop times are about identical .... Code:
<spu yoffset="514" xoffset="216" transparent="101010" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00634.png" end="00:50:31.71" start="00:50:31.70"/> <spu yoffset="520" xoffset="258" transparent="101010" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00635.png" end="00:50:35.79" start="00:50:35.78"/> <spu yoffset="514" xoffset="194" transparent="101010" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00636.png" end="00:50:38.19" start="00:50:38.18"/> <spu yoffset="514" xoffset="174" transparent="101010" image="C:\TEMP\BD REBUILDER\WORKFILES\DVDSUBS\4608_00637.png" end="00:50:40.03" start="00:50:40.02"/> Should perhaps the milliseconds be a 3 digit number? Last edited by Sharc; 24th April 2011 at 12:13. |
