2nd March 2007, 16:06 | #41 | Link | |||
MPEG Member
2nd March 2007, 16:30 | #42 | Link | ||
NAL units have nothing to do with HRD and any rate control. It is just packetizing. |
2nd March 2007, 16:46 | #43 | Link | |
MPEG Member
I know. I was just reacting to your sentence : "...since you need definitely known size to transmit your data through network..." that's why i've said : that's why NAL has been created. To adapt the stream and prepare it for the network. Or at least one reason why. |
2nd March 2007, 19:20 | #47 | Link | |
aka XaS
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS |
8th March 2007, 14:54 | #48 | Link |
MPEG Member
After a great help from Manao (and akupenguin), we finally sorted this CBR problem out (or at least, i understood why x264 is working this way ).
For those who have interest in CBR, the vbv is only compliant on single pass mode, which has been verified by Manao small patch, (and the little tool i used to provide the curves). When using two passes or more, the x264 vbv is no more compliant, but that's not a problem, because the gain in CBR on several passes would be negligible. If i have some spare time, i'll try to implement this compliance for 2 passes, just to check if this can slightly increase the quality (by curiosity....). Some bitrates are so small that just a small enhancement can make the difference. A big Thank again to Manao and to akupenguin for your time. |
