3rd March 2007, 09:00 | #203 | Link |
http://forum.doom9.org/showthread.ph...683#post930683
I speak about these releases |
9th March 2007, 19:12 | #206 | Link |
Swallowed in the Sea
The preview available is a pre-release of the 2.0...If you speak about the next one, for the moment I can only provide a build with some features disabled (due to the lack of time...not finished yet). Let me know if you are still interested. |
18th March 2007, 10:06 | #211 | Link |
I have a problem with Serbian subtitles(SRT, code: 1250 ANSI Central European) after multiplexing with video,audio and chapters....Serbian letters don't display correctly. Don't have this problem with external SRT loading. Any idea ?! Do I have to convert cp1250 to unicode?
I'm using Yamb-2.0_20070311, MP4Box-0.4.3_20070314, and MPC+ffdshow_rev1006_20070307_clsid_sse_icl9(for subtitle decoding)...or I've had to do some tweaking by Haali splitter-7-March-2007? When I choose "Brand Name"(i.e. "ND HDTV AVC", because that what I've used with Nero Recode-only video encoding by AviSynth) other than "Unspecified" Yamb won't do multiplexing, with "Unspecified" is OK. By the way custom PAR still don't work ("Properties->Pixel Aspect Ratio->Other...", i.e. 64:45)....or I'm doing something wrong. (I still have to stick with mp4box commandline for PAR changing) Last edited by SealTooGreat; 18th March 2007 at 11:29. |
18th March 2007, 10:53 | #213 | Link |
And pls, could you fix PAR custom, because MeGUI by default don't put PAR=1:1, and in Nero Recode I have to disable it 'cause of automatic resizing...and I need those default PAR=1:1.....or You can put one more PAR preset (i.e 1:1 Square Pixel)
btw, any news, when will you release Yamb 2.0 with "fake" DAR input? Last edited by SealTooGreat; 18th March 2007 at 11:00. |
18th March 2007, 11:09 | #214 | Link |
I've also tried saparetly to convert SRT to Gapac TTXT...and it doesn't help.
Note: This options in "Editing" it's a little bit tricky. First you have to choose which format you prefer and than to load subtitle, otherwise it won't let you change format. *update* Directshow Players with ffdshow-EastEurope subtitles code(MPC, WMP 11 and 6.4) have a problem to display subtitles correctly....also same is with Nero ShowTime(when for some reason use ffdshow) but with his own filters it doesn't show subtitles at all. Only with gmplayer2007.02.14.Athlon-64 Celtic Driud built(subfont-encoding=cp1250 in mplayer config), Serbian letters are OK, but can not recognize name i've applied (to subtitles), it says "Unknown" Last edited by SealTooGreat; 18th March 2007 at 12:45. |
18th March 2007, 11:28 | #215 | Link |
the subtitles in mp4 are utf-8 always, so try mp4box feeding that
edit: this might very well also be a player issue, not using utf-8 for displaying the subs
18th March 2007, 12:46 | #217 | Link |
yamb has nothing to do with the chars. there is no option in mp4box to force utf-8. its your job to feed it a file that uses utf-8
18th March 2007, 13:15 | #218 | Link |
^I don't know how to create utf-8 compatible subtitles, but here's my subs ripping workflow:
DVD(.IFO)->SubRip1.5(Save as 1250 ANSI Central European)->SubtitleWorkShop2.51(to fix "informations and errors" and than again save as .SRT) Does this workflow give me utf-8 compatible subtitle. If not, do you have any suggestion how to make it compatible. And how am I only having no problem with GMPlayer? btw, multiplexing with IDX/SUB(only IDX is loaded in Yamb) I have no issue...probably they are pictures, not charts. Last edited by SealTooGreat; 18th March 2007 at 13:20. |
