7th November 2005, 14:30 | #181 | Link | |
BeHappy/MeGUI developer
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
7th November 2005, 16:11 | #182 | Link | |
amd & h.264 fanboy
edit: a 4k demo called "Parsec" required the Feb release of DX9.0c. i loaded a March or later version and the demo still asked for "d3dx9_24.dll." i looked in the folder, and, i think there was like a d3dx9_25.dll or higher. i simply renamed it to (or rather copied it to) d3dx9_24.dll and all was dandy. i'd suggest that MPC 6.4.8.6 ask for d3dx9_27.dll and above (or whatever number) Last edited by plonk420; 7th November 2005 at 16:17. |
7th November 2005, 16:20 | #183 | Link |
李姗倩 Lǐ Shān Qiàn
This d3dx9_27.dll thing is both in Aug05 and in oct05:
* directx_9c_oct05sdk_redist : Aug2005_d3dx9_27_x86.cab * directx_9c_Aug05sdk_redist : Aug2005_d3dx9_27_x86.cab * dxsdk_oct2005 : Redist\DirectX9\Aug2005_d3dx9_27_x86.cab * dxsdk_aug2005 : Redist\DirectX9\Aug2005_d3dx9_27_x86.cab You might want to install one of those redistributable, instead of just putting that .dll, especiall for x64, i guess. |
7th November 2005, 16:31 | #185 | Link | |
n00b ever
thx y |
7th November 2005, 16:36 | #186 | Link | |
7th November 2005, 17:17 | #188 | Link | |
Be Brave!
7th November 2005, 17:20 | #189 | Link | |
7th November 2005, 18:13 | #192 | Link |
Life's clearer in 4K UHD
So.... given the current Nero AAC situation (which is not likely to change). What we need is a more flexible (freebie) AAC encoder that offers 6Ch encoding
It's a shame the iTunes AAC encoder can't be used to create 6Ch AAC streams.... like it's possible to do with QT7 Pro (which sadly you have to pay for also) Surely there must be some clever people out there who can develop an 6Ch AAC-LC encoder (which can handle 6Ch AC3 streams as an input source)! If development costs are an issue, I'm willing to put some money into the venture. Anybody else feel the same? Cheers
7th November 2005, 18:16 | #193 | Link | |
Be Brave!
7th November 2005, 18:17 | #194 | Link | |
WinAmp can encode 5.1 HE-AAC audio (at 128kbps)! You can use my plugin for BeSweet for AC3->HE-AAC transcoding (look @ BeLight)
8th November 2005, 02:31 | #195 | Link | |
amd & h.264 fanboy
8th November 2005, 02:53 | #196 | Link |
李姗倩 Lǐ Shān Qiàn
Yeah, that happened already.
http://forum.doom9.org/showthread.ph...347#post698347 |
8th November 2005, 02:55 | #197 | Link |
Aac?
I'm sure I missed something, but what's so special about AAC anyway? I realize this is a bit off-topic, but why is everyone so excited about using it? For movie encoding, why not just include the original unmodified AC3 or DTS stream? I know my receiver won't decode AAC over the S/PDIF cable, and isn't quality lost in transcoding from a lossy format to another lossy format? And if AAC is lossless, what have you gained by transcoding the original AC3 or DTS to AAC?
Any answers would be greatly appreciated. |
8th November 2005, 03:38 | #198 | Link | |
I discovered that this does not work with OGM. If I save video in AVI format, I got é or à or ç but as soon as I mix OGG with my video and save it (using virtualdubmod) all accents are gone. A problem with OGM? |
8th November 2005, 06:09 | #199 | Link | |
李姗倩 Lǐ Shān Qiàn
@RyosukeFC: AAC, per se, is not the "only one." Vorbis is good too. In higher bitrate, we have of course MP3, and much more (Musepack, WavPack, OptimFROG, FLAC, TTA, APE, etc, etc). Some of them are usable as the audio part of the movie too.
But (AVC+AAC).mp4 is today's de-fact standard for .mp4, and if you want to use AVC .mp4 is, probably, a natural choice. For one thing, you can make (AVC+MP3).mp4 or (AVC+AAC).mkv, but QuickTime doesn't like those files. In other words, I'd say "they use AAC because they want to use AVC with it." Another reason is technical interests: HE-AACv2 is not high-quality in the absolute measure, since it's designed for very low bitrate (48kbps or so). Anyone can ABX 15/15 if compred with the source. But it's relatively less bad as 48kbps, and parametric stereo is a challenging technology. (Whether or not you use it for practical purposes is another matter, though.) Yet another reason is, AAC is usually higher-quality than MP3 at the same rate. Nero and Apple and Real all came in with AAC and AAC is now very popular. MP3 has its forte, but I guess many people here in doom9 forum like to try new things. @LordIntruder: Texts stored in MKV/Ogg etc are usually Unicode (UTF-8), so they can be safely multilingual, but unfortunately that is not true for OGM. Basically OGM is not Unicode-based. 0.9.9.6 might be different, but 99.9% of OGM is 0.9.9.5-compatible. As a result OGM is not good at handling multilingual texts. However, since OGM is not Unicode-based, it works better on Windows 98 (i.e. the OS that is not Unicode-based) than other Unicode-based formats would. Each format has its good points & weak points PS Quote:
8th November 2005, 11:48 | #200 | Link |
LordIntruder> OGM is a dead format. I would suggest you to use MKV instead. AFAIK one of the advantages of MKV over OGM is that it uses Unicode. So your "fault" is probably a limitation of OGM.
Liisachan> As some people from HydrogenAudio proved, AAC in current implementations is quite often worse then MP3. But MP3 is only 2ch currently and I don't think the new MP3 surround will ever become a standard. The only formats that can beat MP3 always are MPC and OGG Vorbis. MPC seems to be dead, but Vorbis probably has a bright future and supports multi-channel. The problem with Vorbis is the fact, that in order to have support for it in standalone players, they have to support Matroska container first. There is no regular way to get Vorbis in MP4 or AVI container. I know you can do it, but it is not standardised (did I get the word right?). For this reasons it makes sence to use AAC. The best AAC encoder seems to be WinAMP. You can use WinAMP's filters in BeLight a you don't have to download 100MB of Nero's all-in-one, which can do everything, but nothing correctly. Regarding d3dx9_27.dll, what are pixel shaders good for in video playback? Does it work if I put the .dll in MPC's folder? Vlada Last edited by vlada; 8th November 2005 at 11:52. Reason: Fix some mistakes |
media player classic |
