Old 3rd July 2013, 13:10   #2161  |  Link
itsonlyjustincase
Originally Posted by jkauff View Post
I played around with Win 8 without the fake screen today, and LAV seems to have trouble with it. Config dialog shows QS as available, but doesn't use it during runtime. I'll try re-installing the Intel drivers tomorrow and see if that makes a difference.
Same here it uses avcodec
itsonlyjustincase is offline   Reply With Quote
Old 12th July 2013, 12:02   #2162  |  Link
wanezhiling
9.18.10.3214
Old 14th July 2013, 06:56   #2163  |  Link
theoneofgod
Originally Posted by wanezhiling View Post
Those drivers make my QSV slow with Media Converter.
theoneofgod is offline   Reply With Quote
Old 14th July 2013, 07:12   #2164  |  Link
ryrynz
ryrynz's Avatar
9.18.10.3214 Windows 7/8/8.1 32/64 bit for HD graphics 4000+
Turbobit.net (217MB)
wanezhiling's link is for Windows 8/8.1 only.
Old 14th July 2013, 08:00   #2165  |  Link
egur
QuickSync Decoder author
Beta drivers...
They are meant mostly for developers to test Win 8.1 new features.
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 14th July 2013, 08:19   #2166  |  Link
theoneofgod
Originally Posted by egur View Post
Beta drivers...
Thought so, didn't expect them to break existing functionality though.
Old 19th July 2013, 11:12   #2167  |  Link
diizzy
First of all, great work Eric! :-)
I reported this to nevcairiel who directed it to you so I'll just quote it.
I just updated to the newest version (0.58.1) and there seems to be a regression using QuickSync. From what I can tell it pretty much affects all types of MPEG-2 irregardless of container (.ts, .mpg, .vob). If you're lucky you'll get a few frames correctly but it'll then play roughly one frame per second making it a slideshow. Turning off QuickSync fixes the issues, H.264 works fine.
Windows 7 SP1 64-bit
LAV Filters 0.58.1 (32-bit)
MPC-HC 1.7.0.7634 (32-bit)
madVR 0.86.9 (32-bit)
Intel Graphics HD4000 (i7-3770) - v9.18.10.3165
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3442&DwnldID=22873&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+7+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DZ77GA-70K&lang=eng
Best regards,
Daniel
diizzy is offline   Reply With Quote
Old 19th July 2013, 16:08   #2168  |  Link
egur
I couldn't reproduce on an i7-2600 with Windows 8.
Plays great with the LAV + MadVR (ZoomPlayer and MPC-HC).
I'm using LAV as splitter (splitter source) in my tests. What do you use?
Also, try changing settings in MadVR and see if things change (like queue lengths, etc.). My MadVR settings is default + DXVA scaling.
Eric Gur,
Intel Corp.
Old 19th July 2013, 16:39   #2169  |  Link
diizzy
I did a few more tests, something breaks when you enable hardware deinterlacing in LAV Filters (QS). I confirmed on both MPEG2 and H.264. QS and YADIF works fine though...
My settings are default in MadVR including scaling. Didn't notice it on H.264 earlier because I just a few files that are interlaced.
Best regards,
Daniel
Old 19th July 2013, 17:36   #2170  |  Link
nevcairiel
Yeah i'm personally not really convinced that the QS hardware deinterlacing works all that great, or it fails when i disable timestamp correction in QS, or something, but i've heard numerous problem reports from it.
Generally, you should just turn it off, and turn YADIF off as well, and just let your renderer do the deinterlacing.
Old 20th July 2013, 14:56   #2171  |  Link
egur
I also checked with and without HW deinterlacing. Still works on all my 18 MPEG2 test clips.
In one clip, when HW DI is off, MadVR had issues. This clip is a pathological case where the stream switches between soft and hard telecine (evil_trees.ts clip).
Normal clips had no issues.
The reason I asked about the splitter is that some splitters may produce very bad time stamps affecting playback, nothing I can do about this...
Please share a representative clip (<100mb).
Eric Gur,
Intel Corp.
Old 20th July 2013, 18:20   #2172  |  Link
diizzy
I can cut a few regular TS files too but here a MTS file.
http://projects.pyret.net/dump/sample.mts
I use LAV Filter as splitter, missed to mention it earlier.
//Daniel
Old 23rd July 2013, 11:42   #2173  |  Link
theoneofgod
What a dick move to Windows 8.1 to find Lucid doesn't work! ffdshow works fine though with QSV, if not better on Windows 8.1
Old 23rd July 2013, 15:53   #2174  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Hi.
I'm using Marumo ISDB Splitter, which supports PID change in a service of ISDB stream.
http://www.marumo.ne.jp/junk/isdbsplitter-0.2.19.lzh
I can't use Intel Quick Sync Decoder with this splitter.
egur's ffdshow won't start playback of any ISDB stream.
LAV Video Decoder can't select as an active decoder for any ISDB stream.
Is this an issue of Intel Quick Sync Decoder?
Or of Marumo ISDB Splitter?
Here is my playback environment.
OS: Windows 7 Professional SP1 64bit
CPU: Core i5-3570 Intel HD Graphics 2500 (9.18.10.3165)
Player: MPC-HC rev7646 (x86)
Video Renderer: madVR 0.86.9
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 23rd July 2013, 21:12   #2175  |  Link
egur
I don't know whose fault it is...
Could be a different (unsupported) fourCC code or an unsupported profile.
If there for me a way to test this?
Eric Gur,
Intel Corp.
Old 23rd July 2013, 21:46   #2176  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
What is needed for you to test and confirm this issue?
At least, I can use Quick Sync Decoder of your ffdshow and LAV Video when LAV Splitter is used to split from ISDB stream.
Old 23rd July 2013, 22:09   #2177  |  Link
egur
For testing I need a sample file and how to setup this splitter. If this splitter require connection to a live TV broadcasts (not via the Internet) then I can't test this.
What is this splitter used for?
Eric Gur,
Intel Corp.
Old 23rd July 2013, 22:23   #2178  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
For local file playback.
OK, here is a sample: http://vfrmaniac.fushizen.eu/TX_noise_sample.ts
And the setup is just doing "regsvr32 isdbsplitter.ax".
Old 24th July 2013, 15:25   #2179  |  Link
egur
@VFR maniac
I reproduced the failure with this splitter but I don't know what the exact cause is. It's sending a different stream than LAV splitter.
This splitter doesn't work at all with some of my TS files (H264 and MPEG2) - simply doesn't connect to the File Reader (Async) filter needed for playback.
My suggestions is to use LAV splitter.
Unless you're the developer of this splitter, why would you use it?
Eric Gur,
Intel Corp.
Old 24th July 2013, 15:59   #2180  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
@VFR maniac
LAV Splitter (libavformat) doesn't support PID change in a service.
A certain TV channel I frequently recode changes PID when a SD TV program is changed into another HD, and vice versa.
So LAV Splitter is useless unless splitting TS file at points of PID change.
In addition, this splitter supports decryption of Japanese ISDB stream through smart card reader with B-CAS card.
For people who legally watch encrypted ISDB stream in Japan, LAV Splitter is absolutely useless.
ffdshow, h264, intel, mpeg2, quicksync, vc1, zoom player
