4th December 2009, 20:07 | #641 | Link | |
Just open it in VirtualDub and look at the duration in File/Information. If that changes due to running your other script I'll be shocked. |
4th December 2009, 21:15 | #642 | Link |
In Vdub both dgindex and dgindexnv return 53:29 (also with directshowsource running in mpc in the background), directshowsource returns 58:26. If dgindex(nv) is played in mpc while playing directshowsource in mpc they both run 58:26 (in mpc). See this: http://i48.tinypic.com/1zpjq6w.png
Hmmm... |
4th December 2009, 22:48 | #643 | Link |
file name parsing & invalid license bug reports
hey Don,
Haven't used your tools for a while. Installed beta 4 recently and ran across a few new issues. 1. There is what appears to be a new filename parsing bug. A real simple one. I copy/b my AVCHD .MTS files together and rename them to a YYYY.MM.DD.MTS format for archiving purposes. The problem is that DGIndexNV outputs files (for example) YYYY.MM PID 1100 2_0ch 48KHz 256Kbps DELAY 0ms.AC3 and YYYY.MM.DGA filenames. This is no big deal, I just rename the files and all is well. My guess is that you're parsing for the '.' (dot) file extension separator forwards thru the filename string instead of backwards. So you pick up on the first dot and not the last dot in the filename and split the name from the extension based on that. Reverse the string search and it should be fixed. Easy fix, dont you love those? 2. I ran into a 'DGSource: Invalid license' error. It turned out I had installed VirtualBox on this system recently and its tripping up your MAC address detection logic by using the virtual adapter's info instead of my real hardware's info. That's not real good in several aspects- validating to a virtual nic is a crack in the door for piracy among other things. Right now I have to disable VirtualBox's virtual network adapter to get your tools to work. I hate DRM mostly for reasons like this. I'd suggest you enumerate all NICs, maybe filter out the virtual ones if there is a way to detect that, then try to validate the license against all remaining 'real hardware' entries. That should eliminate confusion in several scenarios I can think of. Ok, keep up all the hard work... The tool is looking good. -Dave |
4th December 2009, 23:14 | #644 | Link | |
5th December 2009, 02:44 | #646 | Link | |
Do you want it resolved? If so, I will PM you with my address to send me the files by mail. Or you can make them available on an FTP site for download. One thing that could help is for you to post here the DGM files for all of them done individually and for doing them all at once. |
5th December 2009, 04:18 | #647 | Link | ||
5th December 2009, 23:59 | #648 | Link |
The new DGIndexNV seems to struggle with DTS audio tracks now, with the old V11 beta it would load up fast and just not show the DTS track. Now when I add vob files containing a DTS track, it sits there for a couple minutes "Not Responding" and still doesn't show the DTS track.
It's relative to size, a small 50MB clipped vob will load decently fast. http://www.mediafire.com/?jtbgluijiok |
6th December 2009, 15:29 | #651 | Link |
Your 5.mpg file has dropped frames. You can see that it plays jerky at the beginning in MPCHC. A player will go by the timestamps and freeze frames so as to present frames at their presentation times. So there is no bug in DGIndex or DGIndexNV in this regard.
6th December 2009, 15:44 | #652 | Link | |
Good to here there's no bug. Keep up the good work |
6th December 2009, 15:57 | #653 | Link | |
7th December 2009, 02:08 | #657 | Link |
Version 2.0.0 beta 5
* Eliminate overhead of updating the Info dialog while saving project. This speeds up indexing substantially.
* Add support for DTS audio in program streams. @Jeff Please advise if DTS support is working properly. http://neuron2.net/dgdecnv/dgdecnv200b5.zip |
7th December 2009, 02:17 | #658 | Link | |
7th December 2009, 02:24 | #659 | Link |
Ok I just tried throwing the resultant dts file into mkvmerge and it's giving me no valid header errors when I try to mux the dts into a MKA file.
mediainfo doesn't give me details on the resultant dts file either? |
