24th March 2011, 15:49 | #1041 | Link |
MPC-HC Project Manager
That is really inconsistent behavior.
This is how it should work: * The internal filters when enabled should always override any external filter, even when one is preferred. * When no internal filter is enabled, a preferred external filter should be used. * When no preference is set, the directshow merits should be used to determine the filter to be used. IEven these behaviour is uninituitive. If we had a willing developer the whole internal/external filter selection and preferences could be changed into a unified and logical interface.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 24th March 2011 at 15:59. |
24th March 2011, 15:55 | #1042 | Link | |
If an external filter is not set to prefer, then I agree that an internal filter should override any merit set for the external ones. |
24th March 2011, 16:04 | #1044 | Link |
The *'ed items are the currently intended behaviour.
As madshi also says, we would all like to see "preferred" override everything.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
24th March 2011, 16:06 | #1046 | Link |
I disable most of the internal filters anyway, it was just a PITA that preferences for source filters were not working at all.
24th March 2011, 18:48 | #1048 | Link |
right now, it seems when a source filter is set to prefer, it can't override an internal one, but when a transform filter is set to prefer, it will override an internal one.
I don't mind it too much the way it is now, but I would rather preferred filters always override internal ones. Also, nev, did you get my large sample? If not, is there any other way i could send it to you? |
24th March 2011, 19:08 | #1049 | Link |
I got it, well, still downloading the last parts of it.
24th March 2011, 19:56 | #1050 | Link |
So to all that helped me get the ArcSoft video decoder up and running, I wanted to report back on my progress. That checkactivate.dll thing is definitely required whether using a fully installed TMT instance or not. I dropped that in the Codec dir and now the codec works perfectly. I just want to step back for a moment and look at what I now have set up. Just to think about this for a moment. MPC-HC...all internal filters are disabled. Audio switcher is disabled. Subtitles are enabled. Renderer is madVR which of course just added subtitle support for MPC-HC hence why I'm using MPC-HC's subtitle support. Video is decoded by ArcSoft or Cyberlink video decoder (depending on my mood I guess) and sent into ffdshow raw video for post processing, before being sent to madVR for rendering. Audio is handled by ffdshow for perfect bitstreaming. Splitting, obviously, being done by LAVF. What this means is that I now have *THE* perfect MKV playback environment!!! I'm actually EXTREMELY happy with this setup right now! To recap:
MPC-HC with subtitles turned on, internal filters turned off ArcSoft and Cyberlink video decoders ffdshow audio bitstreaming madVR renderer LAVF splitter Absolutely LOVE IT!
24th March 2011, 21:58 | #1051 | Link |
Hi Samuri,
Nice setup. Why do you prefer to use ArcSoft and Cyberlink video decoders and additionally pass them over to ffdshow raw? Im just curious if Arcsoft decoders doing better job than ffdshow video decoders. Im using ffdshow for H.264/AVC+VC1+MPEG2 decoding and outputting as YV12 to madVR. Is there any PQ improvement or cpu/gpu saving by using your setup? Thanks Pluto
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
24th March 2011, 22:17 | #1052 | Link |
I can honestly say that with the Cyberlink decoder I'm getting great CPU utilization and incredible PQ with the way I have it set up. I'm using ffdshow for resizing when necessary. (I.E. DVD's I've remade into MKV's). It's quite outstanding. If what you have works, don't mess with it. I mean, it's simple really...just add the video decoder, set it to prefer, and uncheck ffdshow and compare. If it's not an improvement, go back to your original setup. That's what I've been doing. I wanted to see how the ArcSoft decoder compared. It's not bad, but, I think the Cyberlink decoder works better in this environment. For my bedroom machine I use CoreAVC because the CPU is too slow for video decoding. Nonetheless, this setup works PERFECTLY for all videos I've tried it on.
25th March 2011, 02:12 | #1053 | Link | |
25th March 2011, 03:26 | #1054 | Link |
Glad to hear I could help (that's a rare occurrence for me ).
On my system, it takes much longer to open a VC-1 file with Cyberlink, and interlaced VC-1 is also not as smooth as it is Arcsoft. I'm interested to hear if you have similar results.
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
25th March 2011, 03:30 | #1055 | Link |
I'll give it a try maybe tomorrow with a VC-1 MKV I have. (Golden Compass blu-ray...created to torture ArcSoft cause they can't play it in an MKV container. Interestingly it can from MPC-HC now. ) I don't have any interlaced VC-1 content, though. But yea, you definitely helped so thanks.
25th March 2011, 07:59 | #1056 | Link |
Classic DXVA disables madVR, which is a no-no, but there are other hardware acceleration solutions..
<teaser>If you're an NVIDIA user, i'll have a treat for you soon.</teaser>
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th March 2011 at 08:04. |
25th March 2011, 08:09 | #1058 | Link |
Technically its not using CUDA to decode, just to access the hardware decoder.
I like to call it what NVIDIA calls that interface, a CUVID decoder.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th March 2011 at 08:11. |
25th March 2011, 08:23 | #1059 | Link |
Yeah, it's looking quite promising, I have the sample on my harddisk, too... There's one disadvantage: You'll have to copy the decoded frame back from GPU -> system RAM, but from what I've measured (madNV12Test) that should be very fast (~ 500fps with 1080p content on newer cards), so no real problem.
25th March 2011, 08:30 | #1060 | Link |
Yeah, NVIDIA put real focus on getting data from the GPU back to the CPU, its used alot in CUDA. I didn't actually measure performance when using the CUDA interface to copy the frame back instead of using the D3D functions to read a surface, but i figure it'll not be slower, possibly even faster. A quick test in GraphStudios decoder performance gives me about 70fps in a 1080p H264 file (don't remember the complexity of it right now, though), about the same as CoreAVC in CUDA mode, so i must be doing something right.
I'll post some more measured stats when i release it. (Oh, the main difference to CoreAVC? In addition to H264, mine supports VC-1, MPEG-2 and MPEG-4 ASP as well - given hardware support, of course.)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th March 2011 at 08:32. |
