7th July 2017, 22:36 | #21981 | Link |
I already told you that I'm not very interested in streaming stuff. Streaming is delivered "as is", either it works or it doesn't. If something doesn't work, test with and report to ffmpeg.
7th July 2017, 23:41 | #21983 | Link | |
And my SR#27 was about local file playback. You did not answer too. |
8th July 2017, 00:09 | #21984 | Link | |
8th July 2017, 00:23 | #21985 | Link | |
https://forum.doom9.org/attachment.p...1&d=1499469771 https://forum.doom9.org/attachment.p...1&d=1499469744 |
8th July 2017, 00:26 | #21986 | Link |
He is not wrong. raw vbr audio files have no duration information and you need to read the entire file from start to finish to figure it out, and LAV/ffmpeg does not do this (and will likely not start doing this, either).
8th July 2017, 09:56 | #21987 | Link |
VBR MP3 may have an additional non-audio frame with per-frame bitrate statistics (e.g. "Xing VBR frame").
Or not. Then the decoder would have to scan the whole file and build such statistics before playing. Anyway, no decoder is forced to care about non-audio frames. |
9th July 2017, 12:37 | #21988 | Link | |
Δ
Also deinterlacing doesn't work correctly when forcing 4:2:2 to play in NV12/YV12 mode, ghost colors... Last edited by P.J; 9th July 2017 at 12:41. |
9th July 2017, 12:59 | #21989 | Link |
when EVR CP is creating such artifacts you should contact the MPC-BE MPC-HC team. there is no need to use NN on chroma.
edit: i got the chroma sub sampling wrong 4:2:2 is half horizontal not half vertical. you can't scale it to 4:2:0 because you can't scale an interlanced image vertical without "deinterlancing" it before. Last edited by huhn; 9th July 2017 at 13:06. |
13th July 2017, 06:01 | #21990 | Link |
Due to Aleksoid1978 I get hardware acceleration of h265 10bit via NVIDIA CUVID again - diff for 0.70.2.1-git https://yadi.sk/d/9xRWsX343KyoFB - and he said: "in WinXP CUVID not supported P016 output (even for HEVC 10/12bit)".
nevcairiel, before you stop support WinXP can you spend some minutes of coding LAV Video Decoder to force NV12 output in case of decoding h265 10bit via NVIDIA CUVID in WinXP like it done in diff in future releases of LAV Filters? |
13th July 2017, 23:03 | #21992 | Link |
There is no support for this, and unlikely to ever be.
13th July 2017, 23:09 | #21993 | Link |
I'm confused as hell, using LAVSplitter in the graph for certain and getting this:
http://videoff7.free.fr/lav_editions.jpg Going to explore how it's done..
XP SP3 / Geforce 8500 / Zoom Player |
13th July 2017, 23:11 | #21994 | Link |
Editions have been supported for a couple years now. But thats unrelated to TrackSets.
14th July 2017, 12:53 | #21996 | Link | |
Matroska find' ich toll
It is not possible to build a TrackSetEx with the Matroska-Elements. Only with multiple editions and the ChapterTrackNumber(s) you could have a kind of TrackSetEx, but if you change the edition(to change the Tracks) always the movie start from beginning. I would say, TrackSetEx are easy to implement. Its only a Tag like the edition-tags. LAV-Splitter could read this "new Tag". All editions are shown in the TrayIcon-menu and now here could shown the TrackSetEx also. When I change an audio or subtitle track, I make a click on the new track and LAV change it for me. Why can't LAV change two things at the same time. A click on a "TrackSetEx" change first the audio and then the subtitle track. |
15th July 2017, 19:34 | #21997 | Link | |
I don't think nev is planning to "stop" Windows XP support, I'm pretty sure he stopped supporting it years ago (as did Microsoft).
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
17th July 2017, 06:02 | #21998 | Link |
I don't know why nevcairiel don't want spend about 5 minutes to add h265 10bit hardware acceleration via CUVID in WinXP by implementing 100% working code in LAV Filters https://github.com/Nevcairiel/LAVFilters/issues/145 and then officially stop WinXP support in LAV Filters. All people using WinXP (I often see here in the bottom of posts too) will know i.e. 0.70.3 is last fully functional in WinXP version of LAV Filters and if they have (or buy) GM206-based videocard h265 10bit hardware acceleration via CUVID must work in their old sweet WinXP. I believe that's right.
PS. May be nevcairiel affraid National Security Agency (NSA) prohibit using WinXP to easier watch for people all over the world? Last edited by VictorLS; 17th July 2017 at 06:38. |
17th July 2017, 09:10 | #22000 | Link |
LAV filters can also be used via DirectShow API (which is used in MPC-HC when you disable internal decoders and splitters), in case LAV Filters might become incompatible to an older build of MPC-HC as substitute for internal filters.
