22nd November 2008, 22:04 | #3121 | Link |
I've been using this program for a while now to convert HD DVDs for playing on my PS3 and think it's great.
Having recently got an Iphone I thought I would try and convert one of my films to watch on that. I have tried the default settings for Iphone/Ipod and the conversion worked fine but disappointingly the image is very small as it is a full width letterbox with black bars top and bottom. Can anyone suggest some settings that would use the full 480 x 320 screen of the phone cropping the image on either side? This way I would hope to get a good size and good quality image. |
22nd November 2008, 22:11 | #3122 | Link |
Is the information collected in pass1 "job1.stats" using ripbot, bitrate specific to the job or does it analyse the video data for any re-encode ?
For example if I re-encode a movie using ripbot at a fixed bitrate of 4000kbps (720p) and then edit the job1 settings to re-encode the same movie at 6000kbps(720p), can I then maually run only pass 2: "job1_EncodeVideoPass2.cmd" alowing it to use the previously generated "job1.stats"? Thx for any help. |
22nd November 2008, 22:56 | #3123 | Link |
I've just used RipBot264 and its very easy to use. However, I finished my first re-profile from a 6.8GB High@L5.1 MKV and ended up with a 4.1GB High@L4.0 MKV.
The thing that worries me is the rather large decrease in filesize of 2.7GB. Surely, this must have a considerable impact on quality? Is there some setting I should use in order to keep the video bit rate as high as possible? A 2nd thing I noticed is that the subtitle stream has disappeared in the re-profiled version? Did I miss some setting for keeping subtitles? I do see a Subtitles-button but this appears to be a way for adding external subtitle files. |
22nd November 2008, 23:15 | #3124 | Link | |
I dont care so should you
My Installer's || |
22nd November 2008, 23:15 | #3125 | Link |
kriz6912 - If you want to retain same filesize - use 2-pass encode and set filesize in ripbot . Subtitles can only be added from external files with ripbot - First you need to make a .srt from your original .mkv and - then, best way with ripbot, is to build subtitles into the movie.
23rd November 2008, 00:07 | #3126 | Link | |
video=Crop(video, 0, 140, 0, -140) video=AddBorders(video, 0, 48, 0, 232) A bottom-margin of 232 (or near about) nicely positions the movie so you can have subtitles underneath it, instead of over it (which I think looks gross).
Gorgeous, delicious, deculture! Last edited by asarian; 23rd November 2008 at 01:41. |
23rd November 2008, 00:32 | #3128 | Link | |
23rd November 2008, 00:52 | #3129 | Link | |
The other strange thing is Ripbot already analysed the files before without any problems. |
23rd November 2008, 05:34 | #3130 | Link |
Is there any way to have chapters imported from DVD/VOB files like they are done from Blu-Ray/M2TS files? It doesnt seem to matter whether mp4 or mkv files are created on the output. There are simply no chapters from a DVD.
23rd November 2008, 11:50 | #3132 | Link | |
I guess selecting the maximum of 8192 would yield the best quality but might increase size of the file unnecessarily. On the other hand 8192 Kbps (or 'KBPS' as stated by Ripbot but I assume it's kilobit ripbot is talking about and not kilobyte) would mean 8 mbit which then sounds very limiting for high quality blu-ray rips. As you can see I'm somewhat confused. |
23rd November 2008, 12:15 | #3133 | Link |
I seem to have problem encoding U2 : Rattle and Hum HD-DVD.
This is found in the "video - Log.txt" eac3to v2.77 command line: "C:\Users\yuchou\Desktop\RipBot264v1.11.4\Tools\eac3to\eac3to.exe" "C:\Users\yuchou\Desktop\rip\U2_RATTLE_AND_HUM\" 1) 3:"C:\Temp\RipBot264temp\job1\video.mkv" 4:"C:\Temp\RipBot264temp\job1\audio.1.eac3.flac" 6:"C:\Temp\RipBot264temp\job1\subtitle.1.sup" 2:"C:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers ------------------------------------------------------------------------------ EVO, 1 video track, 2 audio tracks, 4 subtitle tracks, 1:38:52 "Main Movie" 1: Joined EVO file 2: Chapters, 20 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 4: E-AC3 EX, English, 5.1 channels, 1536kbps, 48khz, dialnorm: -27dB 5: DTS-ES, English, 6.1 channels, 24 bits, 1509kbps, 48khz, dialnorm: -4dB 6: Subtitle, English 7: Subtitle, French 8: Subtitle, Spanish 9: Subtitle, English, "SDH" [a04] The Nero decoder doesn't seem to work, will use libav instead. Creating file "C:\Temp\RipBot264temp\job1\chapters.txt"... [v03] Extracting video track number 3... [v03] Removing h264 pulldown... [a04] Extracting audio track number 4... [a04] Removing E-AC3 dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Remapping channels... [a04] Reducing depth from 64 to 24 bits... [a04] Encoding FLAC with libFlac... Loading white noise (needed for dithering)... [v03] Muxing video to Matroska... [a04] Creating file "C:\Temp\RipBot264temp\job1\audio.1.eac3.flac"... [s06] Extracting subtitle track number 6... Unfortunately the Haali Muxer cannot handle this source file. It doesn't contain enough seek/recovery points. The "-seekToIFrames" option may work around that. However, using this option may result in artifacts when seeking. Aborted at file position 189415424. This is found in mkvinfo.txt Error: The source file 'C:\Temp\RipBot264temp\job1\video.mkv' could not be opened successfully, or retrieving its size by seeking to the end did not work. |
23rd November 2008, 18:39 | #3137 | Link |
I get the error in the attached image. "Directshowsource: Timeout waiting for graph to start".
I've searched and tried several fixes which have not helped. The problem started with I upgraded to version 1.11.4. I had the "mjpg" error when starting the new version after I upgraded ffdshow. Per a post, I added "ffdshow_vfw" & the "default" key which seemed to fix that problem. What is causing the timeout issue and how can I fix it? Thank you. |
23rd November 2008, 19:03 | #3138 | Link | |
23rd November 2008, 19:47 | #3139 | Link |
I've uploaded it to my server on http://www.netsingapore.com/ripbot/FEATURE_1_CUT.EVO. Thanks
