12th April 2009, 20:51 | #21 | Link |
Here is the link
http://www.mediafire.com/?sharekey=b...018c8114394287 2 files .zip (I had to create 2 files to upload) |
13th April 2009, 18:59 | #22 | Link |
here is my avs:
DGDecode_mpeg2source("F:\VTS_01_1.d2v", info=3) ColorMatrix(hints=true, interlaced=true, threads=0) #blank deinterlace line crop( 4, 2, -4, -2) Spline36Resize(720,528) # Spline36 (Neutral) #denoise the audio has a +192 ms delay... here is the encoded version (h264@1000mbs in .mkv + original .ac3) http://www.mediafire.com/?xlhxn2tmbja _ |
23rd April 2009, 15:10 | #24 | Link |
The initial vob and the dvd have already an V/A delay, so to get the exact sync, 192ms is a good value. But to have the same delay of the dvd, I think that 50 ms is perhaps good. So to conclude, I have 10 small pgc ( of 5 min cartoons) on the dvd. Each cartoons produce a 50ms delay when we make the .avs When I encode the entire dvd, I note an approximately 500ms delay between Video and audio at the end of the film but it is progressive delay!!! So if I can't remove those delays, can somebody tell me how can modify the framerate of the video (in the .avs script?) to make the V/A synch at the end of the film. Thanks for help |
2nd May 2009, 05:49 | #25 | Link | |
this is from one guy name guns1inger and its work fantastic ,
the source http://forum.videohelp.com/topic309224.html |
6th May 2009, 05:38 | #26 | Link |
Posts: n/a
Tried DGIndexing each individual cartoon as the video starts (to avoid the common anti-ripping measure of blank audio cells to havoc sync)?!?
That is, find the first full video frame, step one frame back from that, and mark the DGIndex start, then set the end marker at the end of video ... Use DGIndex on each cartoon, queue them all in MeGUI seperately (but can keep the single VOB in which they will reference) ... Progressive sync problems are either VBR audio issues, or blank audio cells in the VOB inserted delibreately to hamper ripping (a common Disney trick) ... 7ek |
