27th May 2006, 07:42 | #22 | Link |
Pig on the wing
Did you put it in the Avisynth plugins folder? What's the error message? You have to be more specific so that we don't have to guess or ask everything.
27th May 2006, 08:54 | #23 | Link |
Sorry as far as i know i have all my filters in the plugins directory in their own subfolders
My script is now as follows BTW Telecide TFF works a treat and look a bit better Code:
SetMemoryMax(768) LoadPlugin("C:\PROGRA~1\GORDIA~1\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\Decomb.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\chromashift27\ChromaShift.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\MaskTools-v1.5.8\MaskTools-v1.5.8\MaskTools.dll") Import("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\FixChromaBleeding.avs") loadplugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\fft3dfilter.dll") loadplugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\RemoveGrain\Repair.dll") loadplugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\RemoveGrain\Removegrain.dll") loadplugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\Vaguedenoiser\vaguedenoiser.dll") import("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\seesaw.avs") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\DeGrainMedian\Degrainmedian.dll") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\masktools-v2.0a28\mt_masktools.dll") Import("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\LimitedSharpenFaster\LimitedSharpenFaster.avs") Import("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\Soothe_MT2.avs") LoadPlugin("C:\PROGRA~1\GORDIA~1\AviSynthPlugins\AddGrain\AddGrain.dll") mpeg2source("C:\DVD\Rips\ZULU_VTS_01_PGC1\ZULU.d2v") AssumeTFF().Telecide() #FieldDeinterlace() (Im still playing with this) crop(16,114,694,344) LanczosResize(544,256) FixChromaBleeding() FFT3DFilter(sigma=3,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) a = last b=a.degrainmedian(mode=2).VagueDenoiser(threshold=0.8, method=1, nsteps=6, chromaT=0.8) SeeSaw(a,b, NRlimit=6, NRlimit2=7, Sstr=1.5, Slimit=5, Spower=5, SdampLO=6, Szp=16) dull=last sharp=dull.LimitedSharpenFaster(SMode=4,LMode=3,Strength=1000,wide=true,soft=75) Soothe(sharp,dull,30) c=last GrainU=c.UtoY().AddGrain(1,0,0) GrainV=c.VtoY().AddGrain(1,0,0) Return ytouv(GrainU,GrainV).MergeLuma(c).AddGrain(5,0,0) Avisynth open failure: Script error: there is no function named "mt_edge" (C:\PROGRA~1\GORDIA~1\AviSynthPlugins\LimitedSharpenFaster\LimitedSharpenFaster.avs, Line 68) (C:\Documents and Settings\Admin\Desktop\Test.avs, Line 43) Last edited by demonicos; 27th May 2006 at 08:58. |
27th May 2006, 10:10 | #26 | Link |
Pig on the wing
Yes. They just cannot be placed in any subfolders though.
Scripts can be automatically imported if you rename the extension .avs to .avsi and put the script in the plugins folder.
27th May 2006, 11:10 | #29 | Link |
Cool but im still getting the same error for "mt_edge" im guessing i need more plugins
Here it is again Avisynth open failure: Script error: there is no function named "mt_edge" (C:\PROGRA~1\GORDIA~1\AviSynthPlugins\LimitedSharpenFaster\LimitedSharpenFaster.avs, Line 68) (C:\Documents and Settings\Admin\Desktop\Test.avs, Line 43) |
29th May 2006, 08:15 | #32 | Link |
I finally sorted it all out the problem was with limited sharpenfaster i needed to use limitedsharpen and also soothe_MT2 i had to use soothe maybe i got the wrong masktools.dll for modded plugins i do not know maybe someone could shed some light on to this problem but its working with the original limitedsharpen and soothe
BTW as you all said it will be very hard to improve this well you were right but the crash course in filtering is greatly appreciated and is becoming very beneficial
AMD Athlon 2800+ (Barton) 1gig DDR400 ASUS A7N8X-X Geforece 7600GS Last edited by demonicos; 29th May 2006 at 09:13. |
29th May 2006, 14:55 | #33 | Link |
Aging Video Hobbyist
demonicos if you could would you please PLEASE post the "after" frames that result from your filtering.
I have an old-but-classic movie that I wish to attempt to sharpen myself; if you can improve Zulu, or not, that would be very helpful to know. |
29th May 2006, 16:14 | #34 | Link |
Using the settings Chainmax gave me for a 2cd Xvid at 1300kbps gave the following results
Before Filtering After Filtering im gonna try to tone them down a bit tomorrow and see how it goes it shoulld be able to get a bit better than it is For reference i did change the script experimenting but for this screenshot i use what chainmax suggested except order of resizing Code:
tfm(d2v="C:\DVD\Rips\ZULU_VTS_01_PGC1\ZULU.d2v") crop(16,114,694,344) LanczosResize(544,256) FixChromaBleeding() FFT3DFilter(sigma=3,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) a = last b=a.degrainmedian(mode=2).VagueDenoiser(threshold=0.8, method=1, nsteps=6, chromaT=0.8) SeeSaw(a,b, NRlimit=6, NRlimit2=7, Sstr=1.5, Slimit=5, Spower=5, SdampLO=6, Szp=16) dull=last sharp=dull.LimitedSharpen(SMode=4,LMode=3,Strength=1000,wide=true) Soothe(sharp,dull,30) c=last GrainU=c.UtoY().AddGrain(2,0,0) GrainV=c.VtoY().AddGrain(2,0,0) Return ytouv(GrainU,GrainV).MergeLuma(c).AddGrain(10,0,0)
AMD Athlon 2800+ (Barton) 1gig DDR400 ASUS A7N8X-X Geforece 7600GS Last edited by demonicos; 29th May 2006 at 17:29. |
29th May 2006, 16:54 | #36 | Link |
Huh?
First of all, does the "after" screen come from viewing the script in VDub or from the encode itself? If it's the latter, then it might be that the bitrate you used just isn't enough. In any case, I'd suggest you to do the filtering in the order I recommended, or at the very least put the FixChromaBleeding and FFT3DFilter lines before the resizing. In addition, try replacing this;
LanczosResize(544,256) Code:
GaussResize(544,256,p=100) Code:
dull=last sharp=dull.LimitedSharpenFaster(SMode=4,LMode=3,Strength=1000,wide=true,soft=75) Soothe(sharp,dull,30) Code:
LimitedSharpenFaster()
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 29th May 2006 at 17:15. |
29th May 2006, 17:13 | #37 | Link | |
example Code:
crop(16,114,694,344) FixChromaBleeding() FFT3DFilter(sigma=3,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) LanczosResize(544,256) Gave errors Code:
crop(16,114,694,344) LanczosResize(544,256) FixChromaBleeding() FFT3DFilter(sigma=3,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) Worked fine Error is Avisynth open failure ConvertToYUY2: Image width must be even. Use crop! (C:\Program Files\AviSynth 2.5\plugins\FixChromaBleeding.avs, Line 14) (C:\Documents and Settings\Admin\Desktop\Zulu.avs, Line 16)
AMD Athlon 2800+ (Barton) 1gig DDR400 ASUS A7N8X-X Geforece 7600GS Last edited by demonicos; 29th May 2006 at 17:25. |
29th May 2006, 17:24 | #38 | Link |
Angel of Night
That's a quite amazing result, very similar to what the Deconvolution method I mentioned earlier does but far quicker. I'm surprised SeeSaw and LimitedSharpen could bring that out, I must study it more! Once you have that you can use a fancy deblocker to clean up some of the revealed artifacts.
29th May 2006, 20:46 | #40 | Link | |
Huh?
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
