1st September 2011, 18:43 | #5161 | Link | |
There is a world of difference between hardware deinterlacing and YADIF. For example, with LAV CUVID I get no combing or artefacts what so ever and it's smooth as silk except for a few panning issues (which applies to both methods). I would never go back to software deinterlacing. |
1st September 2011, 19:10 | #5162 | Link | |
@nevcairel: I want to ask r.e. the new colorspace conversions, are they free from issues with hue shift like the ones in ffdshow for 10-bit --> 8-bit conversion? I have some 10-bit H.264 encodes that were created with dithertools, and presumably free from 8->10 errors. Edit: Never mind, downconversion is bit-exact between ffdshow and LAV, leaving the source of the ever-present hue shift still unknown. Last edited by Stephen R. Savage; 1st September 2011 at 19:26. |
1st September 2011, 19:40 | #5163 | Link | |
It does actually do some sort of motion compensation, but the vendors are not too keen on disclosing implementation details. Right now it is the same as ffdshows, the next version (thats when those new conversions actually make it in) will have mathematically perfect conversion from 10 to 8 (plain down-shift with dithering)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 1st September 2011 at 19:46. |
2nd September 2011, 08:47 | #5164 | Link |
can you get this one always to play fine? http://www.mediafire.com/?8y4afgs2yf20td6 (sample of South Pacific BBC 1080i25 VC-1)
seems to be acting up sometimes, not sure whether due to splitter, WMV DMOdecoder or maybe LAV audio
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 2nd September 2011 at 10:05. |
2nd September 2011, 09:16 | #5165 | Link |
Offtopic question:
I got new TV with HDMI input, so i connect it with my HTPC (Radeon 6450) by HDMI and set sound over HDMI. But now i have some problems with multichanels audio - some chanels are nearly mutted. Before i used analog stereo speakers without any problem. I am using LAV audio decoder -> ReClock on WinXP. Is it possible somehow downmix mutlichannels to stereo? I didnt found such option anywhere in WinXP/ReClock/LAV audio decoder setting. I think this should fix the problem.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 2nd September 2011 at 09:19. |
2nd September 2011, 09:42 | #5166 | Link | |
Though you should see that VC-1 Timestamp correction is on Auto else you would get a Black screen even after seeking. But this doesn't seem like a Big problem not as heavy at least as my demonstrated MPC-HC EVR Custom & Sync problem here http://mirror05.x264.nl/CruNcher/mpc-hc/ (please wait for it to be fully loaded i still have to improve the progressive streaming @ the 1:35 mark those aren't performance issues @ recording but VBV problems with Quicksync )
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 2nd September 2011 at 10:00. |
2nd September 2011, 11:37 | #5167 | Link | |
All this till Nev adds downmixing in LavAudio. |
2nd September 2011, 11:59 | #5168 | Link |
Donwmix is planned in LAV audio decoder? Good
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
2nd September 2011, 12:12 | #5169 | Link |
You can also just not use WASAPI, and let the Windows mixer do downmixing - at least on Win7 that will work pretty good.
2nd September 2011, 12:15 | #5170 | Link |
My HTPC is based on WinXP. If i am not wrong, WASAPI is not present on WinXP.
2nd September 2011, 13:00 | #5172 | Link |
depending on the hardware your htpc consists off you should really take a move to NT 6 Vista/Win7 into consideration it solves a lot off multimedia issues and doesn't make third party stuff needed for everything (also the possibility of less interoperability problems with different Hardware when using acceleration)
The Power saving also works much better it doesn't cause extreme spikes as on XP, that lowers the risk of unexpected framedrops also High Resolution timers are a improvement here (Hardware dependent).
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
2nd September 2011, 13:11 | #5173 | Link |
@CruNcher:
Yes, i known.But... I spend a lot of time to configure my HTPC to work as i would like to be working, identify freezing durning wake up (thanks to TV card) + found a solution - for this i created "plugin" for MCE standby tools which disable/enable TV card durning standby/resume + "fullresume" while HTPC resume for recording. I even created my own "codec pack" - SAF, just to fit my HTPC needs . Setup remote contorler to work with my HTPC so even my wife can easilly control it (i dont have mouse/keybard connected), silent DVD drive even after wakeup, modify WinXP to not look like windows, media sharing ower network, be able to start/exit games by remote and control them by gamepad (like game console),etc, etc,... Right now i am very happy how it is working, moving to Win7 x86 is planned, but i really don't want to start from begin BTW, i have two small kids home, so i really dont have much time to do such a big task
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 2nd September 2011 at 13:14. |
2nd September 2011, 14:56 | #5174 | Link |
Fantasy Codecs writer
found a bug lavfilters can not use lavvideo to decoder this mpeg file!
Format : MPEG-PS File size : 63.1 MiB Duration : 4mn 13s Overall bit rate : 2 086 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 1 Format settings, BVOP : Yes Format settings, Matrix : Default Duration : 4mn 13s Bit rate : 1 789 Kbps Maximum bit rate : 1 800 Kbps Width : 352 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.706 Stream size : 54.1 MiB (86%) Audio ID : 192 (0xC0) Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Duration : 4mn 13s Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : -67ms Stream size : 7.74 MiB (12%) MPC-HC only use lav splitter and lav audio! |
2nd September 2011, 15:11 | #5175 | Link | |
_
shows after LAV audio. I don't understand. :/ Windows does that automatically or there's an option ?!! Last edited by pirlouy; 2nd September 2011 at 15:17. |
2nd September 2011, 15:44 | #5177 | Link |
I mostly finished the implementation of the new RGB converter, roughly modelled after ffdshows HQ implementation, but with two key enhancements:
- Faster and more accurate chroma upscaling (ffdshow assumes MPEG-1 Chroma siting, while most content is using the MPEG2/H264 siting) --- I do plan to support the MPEG1 version as well at some point in time, but its no pressing issue - Increased processing bitdepth to natively support 9/10bit content The code will always use dithering, because i've found that disabling dithering doesn't yield a worthy performance increase. My implementation is not yet multi-threaded, but i'm not sure if thats actually needed. I'll see about that. Below some performance numbers from my i7 2600k, decoding and processing a 1080p 4:2:0 H264 movie - Decoding w/ YV12 output: 253 fps - Old low-quality RGB conversion: 235 fps - Old high-quality RGB conversion: 40 fps - New RGB conversion: 180 fps - New RGB conversion without dithering: 183 fps And for fun: - New RGB conversion in Debug mode: 20 fps. Don't watch stuff with a debug version, people! Speaking of multi-threading, anyone know a simple threadpool implementation that does not require me to use boost?
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 2nd September 2011 at 15:47. |
2nd September 2011, 15:50 | #5179 | Link |
please add multitheading if possible, there are other tweaks like sharpening or deinterlacing (ffdshow) or VC-1 decoding which are all only single threaded and already take a good amount of power from 1 core. more of such filters & co. which only work with 1 core will eventually lead to speed problems which could be avoided with multithreading support
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 2nd September 2011 at 15:53. |
2nd September 2011, 16:23 | #5180 | Link |
I will eventually offer some post-processing, at first only the filters implemented in libavfilter (mostly for yadif), anything else .. we'll see.
I would like to do some plugin type thing, maybe it'll happen. Not soon, though. Personally, i just don't use post-processing much.
