Old 13th November 2009, 23:14   #9181  |  Link
rica
I can't connect ffdshow to MPC audio renderer.
rica is offline   Reply With Quote
Old 14th November 2009, 01:02   #9182  |  Link
Andy o
Originally Posted by Jeff Flowerday View Post
Bitstreaming won't work with your iGPU, if that is what you are trying to do? You would need the new 5 series ATI or Xonar HDAV 1.3.
Someone here says he's got DD+ bitstreaming working with an Nvidia GT220 card, which should have the same HDMI device as the 8200/8300 and 9300/9400. Anyone else got DD+ working? I haven't seen it mentioned here, maybe I missed it.
Andy o is offline   Reply With Quote
Old 14th November 2009, 01:03   #9183  |  Link
SamuriHL
SamuriHL's Avatar
I've mentioned several times that DD+ crashes MPC-HC and GraphStudio for me. Awesome. So no, I haven't gotten that to work.
Old 14th November 2009, 12:16   #9184  |  Link
madshi
No, he did not. He's got DD bitstreaming working.
I still don't think that DTS-HD, TrueHD and E-AC3 bitstreaming will ever work on anything other than ATI 5xxx and Xonar (and maybe next year's new NVidia generation), but I'll be happy enough if albain proves me wrong...
Old 14th November 2009, 16:01   #9185  |  Link
SamuriHL
SamuriHL's Avatar
Have faith.
Old 14th November 2009, 17:35   #9186  |  Link
Andy o
Yeah, someone pointed that out at that thread. I had the HD-DVD version of Corpse Bride in my head, so I didn't notice the context menu languages/formats.
Old 14th November 2009, 17:37   #9187  |  Link
SamuriHL
SamuriHL's Avatar
Yup. No DD+ on that one. DD/DTS bitstreaming has been working for a while now (well, until the latest renderer change anyway). I'm hoping albain has some good ideas on how to fix the renderer so we can get bitstreaming working for HD codecs soon.
Old 14th November 2009, 19:31   #9188  |  Link
Andy o
There was some confusion on that thread, on my part as well. Trailergod first said he could get DD+ (right now waiting for his reply) and then I asked him what card he was using, then Nimo made that post I linked above in reply, in which he didn't mean DD+, just DD.
Old 14th November 2009, 20:03   #9189  |  Link
albain
Media Control author
I am in a situation when the old renderer worked (with audio gaps/jitter) at least for AC3 and not the new one and I don't know why (luckily I have both sources):
http://damienbt.free.fr/MpcAudioRend...old_working.ax
Maybe you can try bitstream with the latest ffdshow I posted, otherwise you could try reclock too
Thanks
albain is offline   Reply With Quote
Old 14th November 2009, 20:27   #9190  |  Link
SamuriHL
SamuriHL's Avatar
Didn't we already try the old renderer and we got no sound? And ReClock won't accept the bitstream formats. So, we're at an impasse.
Old 14th November 2009, 20:47   #9191  |  Link
mrcorbo
Yeah, this is something I can test....
Going back to the renderer that was in the beta 20 pack, I can get ac3 to bitstream with audio gaps and jitter, but only when DebugView is running. As before, this behavior is repeatable. Obviously, this is odd behavior. Maybe it's timing related?
My experience with the WASAPI+exclusive implementations of J. River Media Center, Foobar and ReClock show that WASAPI+exclusive is very sensitive to buffer size. To the degree that a buffer that is 1 ms too large can break it in J. River's implementation.
mrcorbo is offline   Reply With Quote
Old 14th November 2009, 20:48   #9192  |  Link
SamuriHL
SamuriHL's Avatar
James said the same thing in relation to ReClock, so, that's very possible as to what's going on.
Old 14th November 2009, 20:53   #9193  |  Link
mrcorbo
BTW - This last "old" renderer skips much worse than the beta 20 one. It still only bitstreams when DebugView is running, though.
Old 14th November 2009, 21:49   #9194  |  Link
rica
Originally Posted by albain View Post
Thanks
I'm really confused.
Why do i try non-working renderers again?
Old 15th November 2009, 00:17   #9195  |  Link
albain
Well because FFDShow is now fixed : TMT and ffdshow streams are identical. We just miss a working renderer.
But now I remember that the old renderer was not able to dynamically change of media type.
James from Slysoft already gave me some tips. I also have a working sample app (but which does not use directshow)
Also if someone has hints/sample code I take it
Meanwhile I will go on trying different things until a clear sound comes out
Old 15th November 2009, 00:21   #9196  |  Link
SamuriHL
SamuriHL's Avatar
Hopefully you're able to figure it out soon.
Old 15th November 2009, 00:30   #9197  |  Link
mark0077
Hi thanks all for working so hard
it just strikes me though that should it be so tricky to get all of this working. What I mean is there not any specs available. Is this the reason why it is down to trial and error.
Keep up the good work albain
mark0077 is offline   Reply With Quote
Old 15th November 2009, 00:32   #9198  |  Link
SamuriHL
SamuriHL's Avatar
The fact that he got the bitstreaming support done is remarkable. It's just now how to pass through the bitstream to the receiver. For that you need a WASAPI audio renderer. That's easier said than done. He's working on it. Quite simply, what albain has accomplished so far is nothing short of amazing.
Old 15th November 2009, 01:30   #9199  |  Link
rica
Nobody is helping albain but madhsi and james gives support to him.
So we are waiting as passive testers for the time being.
Old 15th November 2009, 01:32   #9200  |  Link
SamuriHL
SamuriHL's Avatar
Unfortunately I don't know anything about this kind of code. Madshi, James, and albain are the experts here. So yes, we're just waiting unfortunately. Wish I had the time to learn this code.
