13th April 2009, 13:29 | #2084 | Link |
1. I think there is a bug when the filename to import has the character ' (apostrophe) - forx example "king arthur director's cut".
It generates a movie that has a time 0:00:00 and which is unplayable. If i rename the file all seems ok. 2. when i select XMB directshow option, i have a lot of x264.exe error when creating menu 3. the renaming of avchd folder into avchd_date don't work for me and generate errors with line 6642 mentionned Last edited by navycrow; 13th April 2009 at 13:32. |
13th April 2009, 13:56 | #2085 | Link |
Programmer (or just 教务长)
Okay I added *.MPLS support in build 521. Be advised that your files have to have the long file names format, i.e. 00000.mpls / 00000.m2ts (but not 8.3 00000.MPL/MTS).
Please test it and let me know if it works... It will probably need more work, but this is the initial support. (a late fix: chapters and audio/subtitle language tags) Dean Last edited by deank; 13th April 2009 at 14:18. |
13th April 2009, 14:09 | #2086 | Link | |
13th April 2009, 14:34 | #2088 | Link |
Okay now in build 521 you can use your blu-ray's playlist to create multiAVCHD. It's useful if you want to transfer it to external HDD, split in 4GB chunks and watch it on your PS3 in minutes.
[16:21:26] Log started for multiAVCHD v2.5 (build 521) [16:21:26] Processing 1 input file/folder. [16:21:26] Converting PLAYLIST to AVCHD (I:\BD-TrainingDay\BDMV\PLAYLIST\00003.mpls). [16:21:26] Generating meta file for tsMuxer... [16:21:26] M2TS stream split set at 4000MiB... [16:21:28] Detected video: V_MS/VFW/WVC1 (TID#4113) [16:21:28] Detected audio: A_AC3 (TID#4352 / language: und) [16:21:28] Detected audio: A_AC3 (TID#4353 / language: eng) [16:21:28] Detected audio: A_AC3 (TID#4354 / language: ita) [16:21:28] Detected audio: A_AC3 (TID#4355 / language: eng) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4608 / language: spa) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4609 / language: ita) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4610 / language: ita) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4611 / language: nld) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4612 / language: dan) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4613 / language: fin) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4614 / language: nor) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4615 / language: swe) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4616 / language: ita) [16:21:28] Detected subtitles: S_HDMV/PGS (TID#4617 / language: eng) [16:21:28] Detected media file: 00000.m2ts [16:21:28] Detected chapter mark: 00:00:00.000;00:03:53.524;00:08:02.356;00:12:20.072;00:15:37.394 [16:21:28] Detected chapter mark: 00:20:35.943;00:25:42.290;00:32:13.932;00:36:12.670;00:40:41.063 [16:21:28] Detected chapter mark: 00:45:20.467;00:47:15.207;00:49:24.002;00:55:04.259;00:59:59.762 [16:21:28] Detected chapter mark: 01:02:56.272;01:09:56.859;01:15:08.253;01:20:29.699;01:24:17.385 [16:21:28] Detected chapter mark: 01:29:26.277;01:33:27.601;01:37:21.335;01:41:25.579;01:45:00.210 [16:21:28] Detected chapter mark: 01:48:44.184;01:52:39.961;01:55:43.144;02:02:02.481 [16:21:28] Creating BluRay folders (tsMuxer)... [16:22:28] Done! [16:22:28] CLPI transfer: D:\_TEMP\20090413-162128-3276\BDMV\CLIPINF\00000.clpi -> D:\multiAVCHD\AVCHD_TDmenu\BDMV\CLIPINF\00000.clpi [16:22:28] M2TS transfer: D:\_TEMP\20090413-162128-3276\BDMV\STREAM\00000.m2ts -> D:\multiAVCHD\AVCHD_TDmenu\BDMV\STREAM\00000.m2ts [16:22:28] MPLS transfer: D:\_TEMP\20090413-162128-3276\BDMV\PLAYLIST\00000.mpls -> D:\multiAVCHD\AVCHD_TDmenu\BDMV\PLAYLIST\00000.mpls [16:22:30] Will use chapter marks: 00:00:00.000;00:03:53.524;00:08:02.356;00:12:20.072;00:15:37.394;... [16:22:30] Preparing authoring information... [16:22:30] Creating PAL top menu. [16:22:30] Authoring menu (PAL). [16:22:35] Creating menu backgrounds for 1 titles (XMB)... [16:22:35] Trying to use Directshow first... [16:22:57] Creating video backgrounds for XMB menu completed. [16:23:03] Authoring custom menu completed. [16:23:03] Setting menu for 1 titles... [16:23:03] Setting menu properties... [16:23:03] Processing clip (CPI/CLPI) files... [16:23:03] Completed. [16:23:03] Done! [16:23:03] D:\multiAVCHD\AVCHD_TDmenu folder created! [16:23:03] Burn its CONTENTS to DVD UDF 2.50/2.60 disc! [16:23:03] Deleting only files in temp folder (D:\_TEMP\)... [16:23:03] You may now remove temp folder (D:\_TEMP\). [16:23:03] Your compilation contains 0hrs 10min 38sec of video material. [16:23:04] End of log. Last edited by deank; 13th April 2009 at 14:43. |
13th April 2009, 14:40 | #2089 | Link | |
Check if you really have enough space on your _TEMP and TARGET drives. Also about AVCHD-rename problem - it is always better to use "Custom name" and the newly created AVCHD will be named "AVCHD_custom name"... You can't always use AVCHD if you already have one in your output folder and if another program is using the content. |
13th April 2009, 14:57 | #2090 | Link |
i've read the guide
i don't know why i have these bugs. i use this soft since 1 month and the most of time it works allright but on on certain files it hangs. I don't know why. i have enough space (more than 320 gb free) |
13th April 2009, 15:25 | #2091 | Link | |
It caught me out for a while until I re-read the whole thread. over 4gb it has to be the m2ts file only. Simon |
13th April 2009, 15:40 | #2092 | Link |
In case of blu-ray structure, containing 4+GiB m2ts files now you can use the new option to import mpls files. Then large m2ts will be split.
13th April 2009, 15:41 | #2093 | Link | |
the problem if import only the m2ts, i doesn't take account of chapters and language id For the problem of renaming, i think i have understand if i have already have a folder named AVCHD with some movies and i want to add a new one. The rename doesn't work. i ve to rename manually the AVCHD folder with a new name. But if i import a folder named for ex. AVCHD_LIST1 and add a new movie and a folder names AVCHD already exists. It rename AVCHD without problem. Last edited by navycrow; 13th April 2009 at 15:47. |
13th April 2009, 15:51 | #2094 | Link |
i just found how to import mpls. The button doesn't mention MPLS
... but it doesn't work ! i'have this message "tsMuxer didn't like (E:\King_arthur\BDMV\PLAYLIST\00000.mpls). Skipping it... No compatible folders/files processed..." Last edited by navycrow; 13th April 2009 at 15:54. |
13th April 2009, 15:55 | #2095 | Link | |||
edit: Please post your LOG file (what's inside LOG tab). Before all this - update to multiAVCHD build 521 - use multiUPDATE.exe. Quote:
Also - I doubt that 00000.mpls you used is the MOVIE playlist - it could be a menu or something else. Last edited by deank; 13th April 2009 at 16:06. |
13th April 2009, 16:11 | #2096 | Link | |||
here is he log Quote:
I've REALLY read your post but you didn't mention where to find tis option. 00000.mpls is the movie, not a menu. it's the only file i have. it's a blu-ray structure created by tsmuxer. Last edited by navycrow; 13th April 2009 at 16:16. |
13th April 2009, 16:15 | #2097 | Link |
Home Theater Freak
Just tested the Bluray support function and I have just successfully burnt to a BD-RE (Single-layered) media with no problem. And previously files that have stutter were gone now!!! I dunno how but it appears that my LG BD370 preferred BDMV file structure over the stripped-down AVCHD version of the Blu-ray format.
I am very happy |
13th April 2009, 16:16 | #2098 | Link |
@navycrow:
Looking at your log I'd say that: 1) 00000.mpls is definitely not your movie playlist 2) You either didn't rip the original blu-ray disc properly or you don't have it at all. Take a look few posts up where I pasted my log. There you will see a lot of streams being detected before the line "Creating Blu-ray folders (tsMuxer)...". @desray: And I believe your player indicates that it's playing Blu-ray disc (content). |
