29th April 2015, 04:29 | #41 | Link |
raffriff42,
That's a pretty neat script (and fast). Although the screen flicker kind of bothers me.. Can it be reduced a little? Or maybe a version with it removed. Also I noticed when I resized and added bars on the sides to maintain aspect ratio, there is a green line on the left hand side of the picture edge. I Don't know if that's from Vdub for some reason or the script tho. I did find another thread with some stuff too, if anyone finds it interesting. http://forum.doom9.org/showthread.php?t=156658 |
29th April 2015, 05:44 | #42 | Link |
Retried Guesser
Thanks, osgZach. Good points. Try this one, it looks a lot better I think:
LoadPlugin "mt_masktools-26.dll") ## version a48 required ## http://forum.doom9.org/showthread.php?t=98985 ## Last == YV12 return scanlines2(size=2, strength=0.25, flicker=false) ####################################### ## Add scanlines (light & dark horizontal bars) to a video. ## ## @ size - 1 to 4; default 2 ## @ strength - 0.0 to 1.0; default 0.25 ## @ flicker - default false ## function scanlines2(clip C, int "size", float "strength", bool "flicker") { size = Min(Max(1, Default(size, 2)), 4) strength = Min(Max(0.0, Default(strength, 0.25)), 1.0) flicker = Default(flicker, false) C A=mt_lutspa( \ mode="absolute", \ expr=mt_polish("(((y/(2*"+String(0.25*size)+"))%2)>0)?128+64:128-64"), \ u=-128, v=-128 \ ) B = (flicker) \ ? ScriptClip(A, """(current_frame % 2) > 0 ? Last : Last.FlipVertical""") \ : A return Overlay(B, opacity=0.25*strength, mode="luma") } Last edited by raffriff42; 22nd August 2016 at 03:06. Reason: fix chroma drift; remove StrReplace |
29th April 2015, 11:43 | #43 | Link |
That's a bit easier to tweak, thanks
One last question. For some reason if I try to put my resize/addborders calls after this function is called, they do not work. No error is given, it just shows the image at original resolution. Was that intended? I was hoping to see if there was a big difference in applying the script before / after a resize. |
29th April 2015, 14:36 | #45 | Link |
AviSource("whip_000.avi", audio=false) ConvertToYV12() ## LoadPlugin ("mt_masktools-26.dll") ## version a48 required ## http://forum.doom9.org/showthread.php?t=98985 ## Last == YV12 return scanlines2(size=2, strength=0.75, flicker=false) LanczosResize(1152,720) AddBorders(64,0,64,0) ####################################### ## Add scanlines (light & dark horizontal bars) to a video. ## ## @ size - 1 to 4; default 2 ## @ strength - 0.0 to 1.0; default 0.25 ## @ flicker - default false ## function scanlines2(clip C, int "size", float "strength", bool "flicker") { size = Min(Max(1, Default(size, 2)), 4) strength = Min(Max(0.0, Default(strength, 0.25)), 1.0) flicker = Default(flicker, false) C ## Last==C A=mt_lutspa( \ mode="absolute", \ expr=("""(((y/(2*$s))%2)>0) ? 128+64 : 128-64""") \ .StrReplace("$s", String(0.25*size)) \ .mt_polish, \ u=-128, v=-128 \ ) B = (flicker) \ ? ScriptClip(A, """(current_frame % 2) > 0 ? Last : Last.FlipVertical""") \ : A return Overlay(B, opacity=0.5*strength, mode="softlight") } # http://avisynth.nl/index.php/HDColorBars function StrReplace(string base, string sought, string rep) { pos = FindStr(base, sought) return (sought == "") || (pos == 0) \ ? base \ : StrReplace( \ LeftStr(base, pos - 1) + rep + \ MidStr(base, pos + StrLen(sought)), \ sought, rep) } |
29th April 2015, 17:23 | #48 | Link | |
Return allows to return a named clip eg 'myclip' rather than default Last clip, and is needed if the final function call before the end of script does not explicitly or implicitly set Last clip. It (return) also allows you to return early where you want to temporarily disable some following lines of script. __END__, makes anything following it COMMENT. Below will produce an error (EDIT: due to ',' COMMA), try remove '#' hash comment (no error). Code:
return Colorbars #__END__ , Code:
return Colorbars /* , # No error */
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 29th April 2015 at 20:59. |
30th April 2015, 01:34 | #49 | Link |
I did 2 tests. I'm a little partial to the second one at this point (scanlines after resizing). All I have to do now is see if I can tweak the brightness or gamma to reduce some of the washed out look.
Test 1 - Resize after Scanlines Test 2 - Resize before Scanlines Chrome / 720p / 60fps for best experience. |
30th April 2015, 05:38 | #50 | Link |
Retried Guesser
Looks great! However I find it a bit difficult to watch for more than a few seconds. Maybe with lower strength?
When using the effect after resizing, suggest setting the scanline size to match the native pixel size, for most realistic effect IMHO. Regarding your brightness issue, here's yet another version with a brightness adjustment, and a few other minor changes. Code:
# http://manao4.free.fr/mt_masktools.html ## version a48 required LoadPlugin("mt_masktools-26.dll") # http://forum.doom9.org/showthread.php?p=1719737#post1719737 ####################################### ## Add scanlines (light & dark horizontal bars) to a video. ## ## @ size - 1 to 16; default 2 (scanline size) ## @ strength - 0.0 to 1.0; default 0.25 (scanline strength) ## @ bright - min -128, max +128; default 0 (brightness adjustment) ## @ flicker - default false (if true, swap light & dark lines on each frame) ## (only allowed if bright == 0) ## function scanlines2(clip C, int "size", float "strength", int "bright", bool "flicker") { Assert(IsYV12(C), \ "scanlines2: source must be YV12") size = Min(Max(1, Default(size, 2)), 16) strength = Min(Max(0.0, Default(strength, 0.25)), 1.0) bright = Min(Max(-128, Default(bright, 0)), +128) flicker = Default(flicker, false) C ## Last==C A=mt_lutspa( \ mode="absolute", \ expr=("""(((y/(2*$s))%2)>0) ? 128+64+$b : 128-64+$b""") \ .StrReplace("$s", String(0.25*size)) \ .StrReplace("$b", String(bright)) \ .mt_polish, \ u=-128, v=-128 \ ) B = (flicker && bright==0) \ ? ScriptClip(A, """(current_frame % 2) > 0 ? Last : Last.Invert""") \ : A return Overlay(B, opacity=0.5*strength, mode="softlight") } # http://avisynth.nl/index.php/HDColorBars function StrReplace(string base, string sought, string rep) { pos = FindStr(base, sought) return (sought == "") || (pos == 0) \ ? base \ : StrReplace( \ LeftStr(base, pos - 1) + rep + \ MidStr(base, pos + StrLen(sought)), \ sought, rep) } Last edited by raffriff42; 30th April 2015 at 13:03. |
30th April 2015, 13:43 | #51 | Link |
(If a mod would like to split this off into new thread that would be cool)
What do you mean by "difficult to watch" though? I'll admit personally my scanline preferences are a little weird. I like having smallish looking ones. I'll give the new version a try in a little while. Thanks |
30th April 2015, 16:53 | #52 | Link |
You can also disable most of the crt_display features and keep the scanline effect. For example:
crt_display (2, 2, scandist=1.5, phosphor=false, cromaclear=0) Then resize to the target frame size. However the scanlines will be correctly preserved only if it is a vertical upscale, not a downscale. The script will be faster than with all the features enabled. The good thing is that colors and contrast will be left almost intact.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
30th April 2015, 17:24 | #53 | Link | |
But the end result is the same as if I had not changed from "2" and then applied a downsize. Scanlines still look funky The speed did improve quite a bit, but in terms of the effect + speed I think raffriff's script is a pretty good contender as it is orders of magnitudes faster. Last edited by osgZach; 30th April 2015 at 17:26. |
30th April 2015, 18:12 | #54 | Link |
What you actually see as funky scanlines is pure aliasing left by imperfect resizers (from a spectral content PoV). If you downsize, the scanlines should disappear because their frequencies are over the new Nyquist frequency. This happens if you use a resizer with a large kernel, for example BlackmanResize(w, h, taps=16).
16th November 2015, 00:55 | #55 | Link |
Been a while since I responded to this thread, but outside of upgrading to a beefier Core i7 and more than 6GB of memory what else can I do to make loading video with the script and rendering the final video faster and not hog so much memory? I've ran into some still high-cpu usage even with MT mode on, and even sometimes I just get out of memory errors trying to render a 15-second clip of Pac-Mania (which is also rotated so it's in proper vertical orientation) to a final video.
16th November 2015, 03:27 | #57 | Link |
But should I expect an out of memory error even for 6GB of memory? I understand the memory usage for video editing rises exponentially when the video size gets bigger (and moreso if the video and audio are in raw format). It's just all I'm doing is trying to maybe render it at a final resolution (after rotation) of 720x960 with the effects. I'm going to guess that for my current system rendering a 20-minute video will be an all-day process?
16th November 2015, 04:29 | #58 | Link |
Oh this is sweet. With the 64-bit AVISynth+ (though I'm not sure what plugins exactly will need the MT options), my CPU usage in 64-bit VirtualDub for rendering the video is topping out at 60% on my i7-920. Not getting any "out of memory" errors so far. I am going to have to leave the rather shoddy gameplay of mine to test this filter chain out to run all night to render (6076 frames, and time to complete already over 5 hours). I can upload a YT video or post it to my Dropbox afterwards to see the final result.
[Edit] Wow, I guess even my current system seems to be quite weak. Just this four minute clip of some brief gameplay (PS1 Arcade's Greatest Hits: The Midway Collection 1, BurgerTime) is taking a total of nearly 30 hours to render with the effects chain. At least the 64-bit VDub and AVISynth+ plugins are letting me render it. Going to see if I can't find 64-bit versions of the encoders. Last edited by NightSprinter; 16th November 2015 at 16:48. Reason: Add info regarding the amount of time rendering takes. |
18th November 2015, 17:49 | #59 | Link |
The script's working more and more for me now. It doesn't seem to get along with multithreading too well (especially if working with huge aspect ratio multiples and/or the ppp setting at higher than 1, or even setting the prefetch parameter in any manner).
If need-be, I can upload my script in order to debug. I can also upload the gameplay clip I recorded that I'm using the script on. |
20th November 2015, 15:47 | #60 | Link |
So, since all of this is stuck at single-threaded (settings I used take literally a week with AVISynth+ 64-bit and 64-bit VDub), I'd thought I'd just take a screenshot to show how nice very extreme phosphor mask settings can get. I'll also post my crt_display line in said script.
Import ("crt_display.avsi") #Import("dotcrawlplus.avsi") SetFilterMTMode("DEFAULT_MT_MODE", 2) SetFilterMTMode("AVISource", 3) LoadPlugin ("C:\AviSynth+\plugins64\mt_masktools-26-x64.dll") AVISource("C:\Amarectv310\amarec(20151117-1402).avi") ## version a48 required ## http://forum.doom9.org/showthread.php?t=98985 crop (50,0,640,240) pointresize(320,240) converttorgb() ar = 1.0/1.0 crt_display (6*ar, 6, ppp=3*ar, sharpv=0.75, sharph=0.25, blurh=1.5, scandist=1, cutoff=0.8, gamma=2, glowgain=0.125, halgain=0.03, contrast=3, phosphor=true, maskpp=3, beamshape=1.0, vcs=0.25, cromaclear=1, voff=0, pgrid=true, halrange=3, mix=2) pointresize(960,720) #converttoyv12() #dotcrawlpreset("medium") #prefetch(2) |
crt, emulation, phosphor, scanline |
