8th November 2004, 22:48 | #421 | Link | ||
Just a Member
jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
8th November 2004, 23:00 | #422 | Link | |
8th November 2004, 23:12 | #423 | Link |
If that works, that's a very good suggestion! One fewer intermediate steps. PgcEdit could use the same modified DVD2AVI that jsoto came up with and talk to it via windows messages, the same way vobblanker talks to it...
Suddenly PgdEdit preview does not seem so out of reach EDIT: I also saw an extension of tcl called "CWind" that allows sending windows messages from tcl... http://www.interq.or.jp/japan/s-imai/tcltk/cwind.html Jeanl Last edited by jeanl; 8th November 2004 at 23:25. |
8th November 2004, 23:20 | #424 | Link | |
PGC Navigator in Training
2COOL |
9th November 2004, 01:35 | #425 | Link |
PgcEdit daemon
Thanks to everybody here helping to implement a preview in PgcEdit. Great!
For your information, as this is not a programming thread, we are currently exchanging PMs and mails on this matter. I will keep you informed of the progress of the Preview...
9th November 2004, 04:29 | #427 | Link |
@r0lZ
When we choose to "Jump to Target" in our menu buttons viewer, we can see the jump on the main window in the background. Can you have it so we do click on this button, the viewer would automatically close too? When I want to jump to the target, I "want" to jump to the target.
2COOL |
9th November 2004, 12:18 | #429 | Link | |
PgcEdit daemon
Note that the viewer is not closed if the target is not found, or if the target is within the same PGC (for example, when the command is a LinkCN). In this latter case, the right cell is automatically selected and shown in the viewer.
9th November 2004, 12:20 | #430 | Link |
PgcEdit daemon
@DMagic, blutach and everybody
Thanks for your kind words.
9th November 2004, 19:30 | #431 | Link | |
2COOL |
10th November 2004, 00:43 | #432 | Link |
@r0lZ
Enhancement request When using the SetSTN command in Command Editor, I'm envisioning the languages next to the stream number in slidebar. Beats having to check the stream attributes on the side to figure out which to pick. No ()'s will work too. Also, I'm sure you can get the total number of streams,in question, in PGC to set/match the number of streams in slide bar too. So, if I only had 3 audios, my slide bar would only go up to 3. This would make life easier, don't you think?
2COOL Last edited by 2COOL; 10th November 2004 at 01:28. |
10th November 2004, 01:42 | #433 | Link | |
PgcEdit daemon
10th November 2004, 01:54 | #434 | Link | |
Edit: We are already know what PGC we are in since it's still selected in the PGC Selector.
2COOL Last edited by 2COOL; 10th November 2004 at 01:58. |
10th November 2004, 02:14 | #435 | Link |
PgcEdit daemon
It's not a programming problem. It just doesn't make sense.
I'll try to explain again: In your VOB, say you have 4 subpic streams: 0: English, widescreen 1: English, letterbox 2: French, widescreen 3: French, letterbox In the PGC, you will probably have something like that: Subpic 0: use VOB streams 0, 1, 1, 0 Subpic 1: use VOB streams 2, 3, 3, 2 In the domain stream attribs, you FINALLY have the description of the streams assignments made in the PGC: Subpic 0: en Subpic 1: fr So, when you change the assignments in the PGC editor, you cannot say what are the languages of the physical streams in the VOB by looking at the domain stream attribs. And it's also impossible to say how many physical streams are in the VOB.
10th November 2004, 07:18 | #436 | Link |
This post is in reference to the problem northwind reported around here
http://forum.doom9.org/showthread.ph...&pagenumber=17 This is slightly off topic, but the problem emerged when northwind started using PgcEdit. northwind was able to prepare a small version of the problem DVD, which I was able to download for testing. I'm stumped! Here's what I'm seeing: - The *original* DVD as made by northwind plays find in PowerDVD. - But if I burn it on a DVD-RW, and try to play it from PowerDVD, PowerDVD reports an error and stops! * I've tried 3 different discs, same result. * I've tried to load it in IFOEdit and do a Get VTS Sector. Same result! I'm puzzled. There's something wrong with the DVD to begin with, but I'm not sure what it is. Does anybody have an idea what's going on here? Jeanl EDIT: Even more weird! The same DVD-RW that PowerDVD can't play will play on my sampo settop DVD player! Last edited by jeanl; 10th November 2004 at 07:23. |
10th November 2004, 08:05 | #437 | Link | ||
C:\vstrip\vStrip.exe c:\dvd_video\video_ts\VTS_01_1.VOB Of course, it won't tell you any languages. Oh BTW, I've read that the default setting for gprm(1) is 16, not 15. It's in my Ralph LaBarge book.
2COOL |
10th November 2004, 10:08 | #438 | Link | ||
PgcEdit daemon
[EDIT:] The default for gprm(1) is 15, not 16. Ralph LaBarge is wrong. Confirmed with soft players, Sony and KISS.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 10th November 2004 at 10:21. |
10th November 2004, 23:01 | #440 | Link |
there is a minor bug in pgcedit. in command editor menu, when the "value" option is selected, if the box is empty (no number entered), when you click the "B" button you get
application error: can't use empty string as operand of "/" |
