23rd December 2010, 18:27 | #5081 | Link | |
Kid for Today
I can't get 0.32 to lock up anymore(and I tried really hard ), I guess it was a PotPlayer problem indeed.
It was a mix up w/ an EVR screenshot, Reclock doesn't say YUY2 when using mVR...for very obvious reasons Last edited by leeperry; 23rd December 2010 at 22:08. |
23rd December 2010, 20:36 | #5082 | Link | |
I have a HD5850. It wasn't supported until the last PowerStrip release but this latest version doesn't seem to work neither. I tried to force some custom refresh rates but nothing happened. May be it works with older drivers (<10.12) or other outputs (I am using DP right now). |
23rd December 2010, 20:45 | #5083 | Link | |
23rd December 2010, 20:57 | #5084 | Link | |
Does madVR still save its settings to an ini file, so I could manipulate that file manually? Or is there any other possibility to get to the config editor without having to run madVR first? Same behavior (as I described in my initial post) with a lower refresh rate (60hz) on a single monitor setup. Would logs of these tests be of any use to you? €dit: Strange observation - I am getting more and more confused by the minute.. If I wait for the timeout / D3D error and try to play the same file with the already opened mpc-hc, all madVR features (including exclusive mode) seem to be working. Any other file opened in that instance of mpc-hc afterward works flawlessly. I have created a log of that test. This time I did not get the D3D error but the movie started playing right away after said timeout. Please let me know if there is anything else I could do to help debugging. |
23rd December 2010, 21:38 | #5085 | Link | ||||
(1) loading of "madHcNet.dll" (2) enumeration of monitors (3) initialization of madHcNet network (4) start of "madHcCtrl.exe" One thing you could try is to start madHcCtrl.exe manually. Wait until the madVR tray icon is visible (in case you haven't disabled it). Then start madVR. Does the timeout still occur? If yes, the problem is likely not (4). Otherwise it's probably (4). Also try disabling your firewall as a quick test. It the problem is (2) or (3), it might be difficult to find the real cause for the timeout. Because no other user seems to have this problem, I fear it might be some kind of OS problem, which may only be cured by reinstalling the OS. Hopefully not. |
23rd December 2010, 22:01 | #5086 | Link | |
23rd December 2010, 22:35 | #5087 | Link | |
So I doubt it's because I have my firewall blocking the network function, as version 0.24 did not have that function and did not work either, but I will try and test to rule out all possibilities. Another thing I don't get is why I don't seem to be able to save my madVR settings(?). And you are right - it could be one of those random OS mess ups. Even though I can't recall any major changes I have made that would cause madVR to glitch, but as an IT professional I know that hardly anyone ever recalls those kind of changes until they are pointed on them specifically When I get a chance I'll try and see if I get the same behavior with the same machine under another OS / a live OS. €dit: I went through your list of possible causes. (1) Any advice on how to rule this possibility out? (2) Just did a couple of tests using a single monitor setup. No change. (3) Even if I disable both my fw and av, I get the same behavior :/ (4) If I start madHcCtrl.exe manually it indeed takes forever until the task bar icon appears (even though the process starts immediately and does not cause any load). But madVR still shows the same behavior (timeout and afterward flawless playback). Last edited by Guest; 9th June 2012 at 01:15. Reason: 4 |
23rd December 2010, 23:12 | #5088 | Link | |||
I'll add some more log outputs to the next build. That should help figuring out which step exactly causes the freeze for you. That's already a good indication! On all my PCs the tray icon appears *instantly*, right when starting the exe, without any noticeable delay. madHcCtrl.exe, before showing the tray icon, does some of the same network initialization stuff that madHcNet.dll is doing. So my current guess is that one of those network calls hangs on your PC, for whatever reason... |
24th December 2010, 00:59 | #5092 | Link | |||
It certainly seems like this is the way that it should be done. I would expect chroma upsampling to be done using the algorithm that has chroma matching luma as best as possible, and then both being scaled to the display resolution using the selected 'luma' scaling algorithm. My original testing for chroma upsampling that resulted in me choosing Bicubic75 was displaying everything at the native luma resolution on CRT (720x480 for dvd and so on) so perhaps Bicubic75 is not the best choice for chroma if you are going to a 1080p native display, at least with the current method. I know you don't really like commenting on the future of madVR, but do you plan on implementing this change soon, or should I start testing chroma when going from SD to 1080p? For what it's worth, I recently did another round of testing luma scaling going to a 1080p native LCD and after several tests my conclusion was the same: SoftCubic50 produces results that are truest to the source and the best approximation of what an SD source looks like natively on a high end CRT. (the best SD can look in my opinion) Mitchell Netravali does look sharper, with less ringing than SoftCubic50, but suffers from a considerable amount of aliasing unfortunately. If it were not for this, it would be my choice. 8-tap Lanczos does an amazing job with aliasing and some detail reconstruction, but unfortunately there is far too much ringing with any variant of it. I wish there was an option for scaling with a high tap count that did not introduce such high levels of ringing into the image. Quote:
Whatever it is doing, looks very artifiical to me. Thank you for taking the time to go back through this topic and answer all these questions! |
24th December 2010, 01:24 | #5093 | Link |
madshi,
I'm so glad that you're back. Could you, please, look at this error report http://forum.doom9.org/showthread.ph...86#post1449086 This problem is from a while back but it's still present and as far as I can tell independent on sourice filters/splitter and decoders and forced me to go back to v 0.30 to avoid it. If you want I can provide more recent .log file? Edit: Actually it was v0.31 I was using not v0.30 Last edited by pankov; 24th December 2010 at 16:01. |
24th December 2010, 08:35 | #5094 | Link | ||||
Don't hold your breath too much, though, I've *loads* of other things on my to do list for madVR, first. Quote:
Is it eventually possible that you were a bit prejudiced when testing spline, because you thought the image would be converted into curves? You're the only person whom I have heard saying that Spline resampling looks artificial. |
24th December 2010, 08:44 | #5095 | Link | |
It doesn't occur with 0.30? Which is the exact first version it occurs with? 0.31? I need an exact answer to that, that would be helpful, thanks. |
24th December 2010, 10:59 | #5096 | Link | |
Kid for Today
Chroma is encoded at 1/2 res because the brain supposedly isn't too sensitive to chroma res? So who cares if it's too soft? At least its noise doesn't interfere w/ luma anymore? But maybe that mVR tweak is what you meant when you were implying that the softest chroma was't necessarily the truest to the source? Ah well, PQ is eye popping anyway Last edited by leeperry; 24th December 2010 at 11:02. |
24th December 2010, 12:18 | #5097 | Link | |||||
The more I think about it, the more it makes sense to do it the other way. (which is why I assumed it was being done like that before) What might be the best chroma algorithm for DVD could be completely different for 720p sources, which would be different for 1080p the way things are being done now. Only using chroma upsampling to bring chroma resolution to match the native luma resolution, and then scaling both using the luma resampler chosen should produce consistent results regardless of input video resolution. (because then you are always scaling chroma by the same amount) Quote:
Did anything ever come of that iNEDI / ICBI or other more advanced resamplers? Quote:
Something I have noticed recently is that when bringing up the madVR preferences, it is quitting fullscreen mode in MPC-HC, which isn't very helpful when you're trying to compare scaling algorithms. (it resizes the window so that video is displayed at 100%) Quote:
Quick example taken from a very poor DVD scaled to 1080p, shown at 200%. If you open each in its own tab and switch between the two, the difference should be obvious. It has very little effect on reducing chroma noise, but a significant effect on reducing saturation. |
24th December 2010, 15:49 | #5098 | Link |
Kid for Today
I'll give you that SoftCubic100 might look blurry on very sharp 1080p...70 looks too noisy to my eyes, maybe 80 is a good compromise. What remains to be seen is what it'll do on noisy SD, but it still looks like a good compromise between noise and bluriness.
24th December 2010, 16:06 | #5099 | Link | |
I hope this is more helpful information now. |
