23rd April 2008, 23:01 | #1161 | Link |
Hi,roman76r
Thanks for your efforts. Is this correct? http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.1(b).zip |
23rd April 2008, 23:57 | #1164 | Link |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th April 2008 at 00:07. |
23rd April 2008, 23:59 | #1165 | Link | |
Caped Crusader
Still no subs showing with new version on PS3.
Cheers. Last edited by B4tm4n; 24th April 2008 at 00:36. |
24th April 2008, 03:02 | #1168 | Link |
Roman
Sorry for my poor English first. I also have got a message "Can't convert UTF-8 to UTF-16. Invalid source text". and I found that it's OK when the charset is set to "ANSI_CHARSET" and English font. However TsMuxer said error message when it's set to "HANGEUL_CHARSET"(Korean) for Korean font. I believe that the other charset also have same trouble except English. I hope that you can fix this soon. Last edited by changjunk; 24th April 2008 at 03:29. |
24th April 2008, 04:52 | #1169 | Link | |
I've done the same like Erdelamoto. -Open the Mkv and the Chinese srt with tsMuxer. -Demux the Chinese Srt in sup with tsMuxer. -Open again the Mkv with tsMuxer, add the new sup of tsMuxer. -Create the BluRay structure. -Play with PS3, the subtitles show up correctly. |
24th April 2008, 09:17 | #1171 | Link | |
I follow this thread from time ago, but i never post until now. I Write my previous post because i guess the info could help you. Again, sorry for my bad English, I am from Spain. Last edited by Erdelamoto; 24th April 2008 at 09:20. |
24th April 2008, 10:24 | #1172 | Link |
Erdelamoto
Thanks again for your information. I have found the following bug: when tsMuxer converts 24-bit RGB color into 24 bit YUV color, sometimes several RGB colors correspond to the single YUV color(because initially YUV contains only 11.2 milions of colors, but RGB color space contains 16.7 millions). When it happens, tsMuxer forms 2 different records in the palette definition. It is not correct. Here new version: http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.2(b).zip Last edited by roman76r; 24th April 2008 at 10:51. |
24th April 2008, 11:26 | #1174 | Link |
I am using version 1.8.1(b) to convert Create Blu-Ray Disk, the Chinese subtitle can show up conrrectly in PC PowerDVD but not in Sony PS3 or in Panasonic BD-30, although it does have check box for you to choose Chinese subtitle. I tried to convert to SUP file, then convert to Create Blu-Ray using 1.7.6 version, the Chinese can show up but not in the same pace of the sound.
24th April 2008, 11:43 | #1176 | Link | |
24th April 2008, 12:36 | #1178 | Link |
Caped Crusader
I not sure about the subs yet, in the process of checking. But the split function has been broken, in version 1.7.x a CLIPINF files was created for every split m2ts file but in 1.8.x theres only 1 CLIPINF file been created no matter how many m2ts files there are. I'm putting the files from 1.8.x into 1.7.6 to see if it creates the missing files. |
24th April 2008, 12:37 | #1179 | Link | |
tsmuxer |
