20th March 2007, 05:04 | #1162 | Link | |
AviSynth script: Code:
# Created by AVSEdit # LC 3/17/2007 DirectShowSource("Equilibrium.rebuilt.H.264.stream.0.mp4",audio=false,video=true) Crop(0,134,-0,-134) AssumeFPS(23.976) |
20th March 2007, 08:43 | #1163 | Link |
Hello,
I´ve got a Problem to get the Audio and Video in Sync, perhaps someone can help Okay let´s start. The Movie is "Running Scared" which was demuxed with EvoDemux 0.625b. It has 3 DTS HD Tracks and Video is VC-1 encoded. Start PTS of Video is "D6D8" and the one of the Audio Tracks is "D6D8", which should tell me that there is no Delay between Video and Audio, right? The Video was reencoded using the following Script and x264: DirectShowSource("D:\HD-DVD Test\RS.grf",audio=false,fps=23.976,framecount=174948) Crop(0,131,0,-132) LanczosResize(1280,544) ConverttoYV12() I reencoded the DTS HD into AC3 using tranzcode and Sonic Foundry. When the Tracks get muxed by mkvtools the sound is far off, meaning the video seems to run faster and is ahead of the audio.. Anyone got an Idea? Rambo was done in the same way and it was in sync... Edit: Even if I take the original DTS (processed with dtscore) Audio and Video is async... Edit2: Found the Error, it was a wrong filter in graphedit (D´oh) Last edited by Easy123; 20th March 2007 at 12:58. |
20th March 2007, 11:55 | #1164 | Link |
Just another quick question - what tool do you guys prefer to merge the two feature m2ts files of BluRay posts?
I mean when there actually are two, like in Kingdom of Heaven. TIA S. Last edited by Momber; 20th March 2007 at 13:14. |
20th March 2007, 14:04 | #1165 | Link | |
I see Cineplayer mentioned in this thread, but the official Roxio/Sonic site only has Cineplayer 3.4 available for purchase. |
20th March 2007, 14:38 | #1166 | Link |
King of the Jungle
The latest Cineplayer is only bundled in with Sonic's profesional products (Scenarist/Cinevision) right now. I would imagine it will be available to consumers quite soon though. I'm afraid this is still quite an expensive game to play if you don't work in the industry.
20th March 2007, 17:09 | #1168 | Link |
Be aware that you may run into problems if you do any processing on merged m2ts files. It appears that the MPEG2 end sequence flag is written at the end of each m2ts file. If you merge the files together some tools will quit as soon as they hit the first end sequence flag. For example, I've had problems with MPEG2Repair and pulldown.exe. I haven't found a tool yet that can manipulate the end sequence flag.
20th March 2007, 23:12 | #1172 | Link | |
Posts: n/a
20th March 2007, 23:28 | #1173 | Link | |
Do you know which version of Scenarist/Cinevision contains Cineplayer 4.2 (ie is it as simple as Scenarist 4.2/Cinevision 1.2)? |
21st March 2007, 01:13 | #1174 | Link | |
21st March 2007, 01:31 | #1175 | Link |
You can be more helpful to this community if you actually provide the info as to how you fixed an issue. "I found it" doesn't really provide anything helpful to those who may be experiencing the same problem.
Chumbo |
21st March 2007, 13:16 | #1177 | Link | |
Ta S. Edit: What would be the correct command line for xport? I tried "xport KoH.m2ts 1 1 1" and I get huge amnounts of sync error messages right from the outset. Last edited by Momber; 21st March 2007 at 13:33. |
21st March 2007, 13:55 | #1179 | Link | |
I know it 100% sure, cause i made a lot of hddvd /blueray reencodes to 23.976fps. And all demuxed AudioTracks matches exactly to the 23.976fps Video and Audio is 23.976fps Last edited by ACrowley; 21st March 2007 at 13:59. |
