10th December 2012, 02:00 | #16121 | Link | |
I don't know about NTSC - as there were all sorts of issues with 480 vs 486 lines. (Modern digital "NTSC" is based on 480 active lines, but analogue NTSC and digital broadcast video originally worked on the basis of 486 active lines) (NB PAL changed from analogue 575 to digital 576 active lines - but didn't change picture height. How? Originally analogue "PAL" was deemed to be 575/50i active lines - with each 575 line frame made up from two fiels each of 287.5 lines - one had a half-line at the top, one had a half-line at the bottom. In digital "PAL" these half-lines are padded to full lines creating 2 x 288 line fields or a 576 line frame. You often still see the half-lines at the top and bottom of frame when viewing 576/50i content scaled to 1920x1080 and viewed with no overscan) |
10th December 2012, 02:30 | #16122 | Link |
So I've gone back and done some testing with hardware accelerated decoding and interlaced DVD playback, as something didn't look right when doing that aspect ratio testing earlier.
If I use DXVA2 Native decoding in LAV Video, I am only able to select Video as a source type, Film is not available - Video appears twice when hitting the keyboard shortcut. It doesn't appear to be a problem with the label either, it's definitely not being deinterlaced as film content. If I use DXVA2 Copy-back decoding in LAV Video, Film-type deinterlacing works correctly. If I use CUVID, Film-type deinterlacing is available, but not enabled by default. When CUVID is set to 25/30p output, it is detected as having a 2:2 cadence, and 4:4 when set to 50/60p output, but the output is aliased/low resolution as if the wrong type of deinterlacing is being applied. I see that CUVID no longer has the option to force a specific type of deinterlacing, and suspect that it's only using "Adaptive" now, which is probably the cause of problems there; Film-type content needs to use "None (Weave)" option to look correct. EDIT: Unchecking the "Enable Adaptive HW Deinterlacing" option with CUVID also looks correct. I don't know if the only difference now is that the "bob" option has been eliminated. When you uncheck that option, the "High-Quality Processing" option is greyed out, but I don't know if that would have been used with the "None (Weave)" option anyway. So only Software decoding, CUVID with "Adaptive HW Deinterlacing" disabled, or DXVA2 Copy-Back are working correctly with interlaced film-type content. (I only have film-type content to test with) In case it makes a difference, this was PAL film-type content. (as you probably guessed from the 2:2/4:4 cadence) It looks like the image is the correct aspect ratio when scaled from 720x576 to 1024x576, but with black bars on either side of it. If I stretch it to eliminate the bars, the image looks distorted. Last edited by 6233638; 10th December 2012 at 02:45. |
10th December 2012, 03:41 | #16123 | Link |
The old-day CRT has the overscan area. The signal is analog. The electron scanning beam is contiguous, not like flat panel devices --- PDP, LCD, DMD-DLP, etc... So you never see all CRTs have the same aspect ratio like 4:3 or 16:9 w/o accurate calibration. But only very few people can tell the minor difference.
In my country, most DVB-T broadcasters send out MPEG-2 704x480i30 signal on SDTV programs. But few of them send out MPEG-2 720x480i30 one. Yet the DAR (Display Aspect Ratio) is described in the MPEG-2 stream's header. It does cause issues on calculating PAR (Pixel Aspect Ratio) to prevent unnecessary horizontal scaling for MPEG-2 720x480, 720x576 DVD / SDTV contents. At that time I decided to use MPEG-4 PAR to describe the image pixel apect ratio. I also made the MPEG-2 decoder to send out the video frame with fake PAR information to the video scaling processor. So all 720x480, 720x576 combinations always get the same PAR of 704x480, 704x576. If the output signal is NTSC / PAL / SDTV D1, for the 704x480 and 704x576 contents at 100% zooming rate, just let the video player to put the video displaying window at (8,0)-(704, 480/576) of the video frame buffer w/o any scaling. Last edited by pie1394; 10th December 2012 at 05:49. |
10th December 2012, 06:25 | #16124 | Link | |
Any consideration about AVX? It is supported on the 2nd and newer Core i processors. Not only the integer parts, it also does provide some boosts over SSE3 on FP32 / FP64 intensive calculations. The Altivec-type 3-operand instruction formats also get some benefits on saved code size. But 256-bit AVX packed shuffle / sum-of-2 instruction logics are somewhat different from 128-bit SSE3 ones on the same sized element. |
10th December 2012, 06:29 | #16125 | Link |
It's wiki, so not to be taken as a scientific fact but https://en.wikipedia.org/wiki/Oversc...olution_issues proves both Sneals2000 (analog) and EE guy (digital) correct. It's all above my head but he explained it to me a few years ago and something about color carrier and a bunch of numbers it came out to 703 and 706 respectively, bored me to death. But it's 1 pixel no naked eye could tell the difference. However avisynth has issues with resolutions that aren't mod4, green lines and repeated lines, dunno know if that's a problem with madvr.
10th December 2012, 07:36 | #16126 | Link |
Audiophile
Request: add a text file to the madvr.zip file that states miscellaneous stuff.
In particular the peculiarities of DXVA2 scaling, decoding, deinterlacing, w/e. It's confusing as not only must this information be chased down, it's subject to change. And if anyone does not follow the hundreds of pages in this thread, important notes can be missed. |
10th December 2012, 07:55 | #16127 | Link |
Whilst madVR has been stable for quite some time I still believe Madshi considers it a "in development" project and is still interested in implementing a few more features.
Full documentation will likely be supplied once it gets close to or hits 1.0 Last edited by ryrynz; 10th December 2012 at 12:49. |
10th December 2012, 09:06 | #16128 | Link | |
AVX does not provide an improvement over this, AVX2 will however, AFAIK.
10th December 2012, 10:21 | #16129 | Link | |
QuickSync Decoder author
Copy back should be done on 2 threads using SSE aligned addresses. You must use the VS2012 compiler or Intel compiler 12.1 (maybe 13.0, didn't check) or newer. The instructions used are: VMOVNTDQA: streaming load 256bit. Used via the _mm256_stream_load_si256 intrinsic function. VMOVDQA: aligned store 256bit. Used via the _mm256_store_si256 intrinsic function. See the code here (gpu_memcpy_avx2 function).
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
10th December 2012, 10:49 | #16130 | Link | |
Without the buffered DMA unit + internal CPU data ram, it is quite inefficient for CPU to fetch / write-back large stride-based contiguous non-cacheable memory like video frame buffer or peripheral memory. Yet it is often only provided on the video processors, not general-purposed one like x86... |
10th December 2012, 11:05 | #16131 | Link | |
For discrete GPUs, I'm not sure how CB actually works, this is not my cup of tea... I can guess that the surface is copied via DMA when it's locked via the LockSurface function, but maybe not.
10th December 2012, 11:05 | #16132 | Link | ||||||||||
(1) Do users today play more content which needs 720x576 -> 1024x576 scaling, or do they play more content which needs 720x576 -> 1050x576 scaling? (2) What do the majority of DVD studios do today? (3) What do the majority of broadcasters do today? (these are not questions I expect you to be able to answer) It seems to me that probably the majority of newly released DVDs these day probably need 720x576 -> 1024x576 scaling. This is an educated guess, though, and would need to be confirmed first. I've not sure about (3). There's a good chance that the majority of broadcast material might need 720x576 -> 1050x576 scaling. But it's hard to know for sure. So what all this leaves us in is a total mess... I think it would be a bad idea if I just scaled all 720x576 content to 1050x576 now because my impression is that it would produce stretched images for many newer DVDs. But then simply ignoring the whole issue might not be such a good idea, either. Oh well. Not really sure what to do now... Quote:
10th December 2012, 11:26 | #16133 | Link |
MPC-HC Developer
@madshi
madVR doesn't work good with mpc and microsoft dxva decoder at least on HD5870 with 12.10 driver. Playback starts fine, but madvr freeze after seek: see https://dl.dropbox.com/u/16282309/mad/madVR-freeze.report.mpc.dxva.7z and log: https://dl.dropbox.com/u/16282309/mad/madVR.log.mpc.dxva.7z ffdshow DXVA and LAV doesn't have seeking problem. MPC and Microsoft DTV-DVD Video Decoder have. Last edited by kasper93; 10th December 2012 at 12:08. |
10th December 2012, 11:45 | #16134 | Link |
Old videocard
Sorry if already discussed: When running on old video card (Radeon 550 PS2.0) just a black screen. No any errors. All interfaces are created without errors. How can I know that the video can not be played (black screen)?
10th December 2012, 12:09 | #16135 | Link | |
Maybe it should be an auto-detection thing - if the outer x number of columns are blank, assume it's ITU 601 and scale accordingly. If they're not blank, assume the whole frame is meant to be 16:9 and scale accordingly.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
10th December 2012, 12:47 | #16137 | Link | |
Automatically activate ITU scaling when pillarboxing is detected
A simpler solution would simply be to have a global preference for what you want to do with all SD content, and a keyboard shortcut to toggle between the two though. |
10th December 2012, 12:55 | #16138 | Link | |
tells us that active video for 625 line system can have 52.3us (64 - 11.7us). System based on BT.601/656 use 13.5MHz sampling ie 1 pixel have 1/13.5MHz length ie active video length in digital pixels is equal: 52.3/(1/13.5)=(approx) 706 pixels so no 702, no 704, no 708 or 710 or 720 but 706 pixels - thus story is even more complicated and it should be 1044 not 1050 video. Why not 52us - in digital world time control is very precise and many vendors offer hardware capable to produce 52.3 not 52us video which is allowed by video standard . Last edited by pandy; 10th December 2012 at 13:09. |
10th December 2012, 13:46 | #16140 | Link |
When you use a ISF calibrated digital front projector (like my Sony HW50) do I just check the option 'disable calibration for this display'? (can t remember the exact name of that option but it is the first radio button you can choose)
