20th March 2011, 02:49 | #6102 | Link | |
Edit: the version of MPC-HC that Madshi posted doesn't hang my system, it just stays forever on Opening, when I try to open/play any file. It's pretty weird what is screwed up in my system and why the 32-bit version won't run. If there was some way I could debug this I would but I have no clue how or if it can be done.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S Last edited by fairchild; 20th March 2011 at 02:58. |
20th March 2011, 03:03 | #6103 | Link | |
20th March 2011, 03:09 | #6104 | Link |
The player doesn't get to the point where it even opens the file and loads all the decoders, renderers, filters etc. So it's not even connecting to MadVR for it to create a log. It's just majorly borked and won't do anything.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S |
20th March 2011, 04:24 | #6106 | Link | |
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
20th March 2011, 04:46 | #6108 | Link |
OK, I have problem to report. I'm using the same file as ranpha as reference.
I have the "Position..." option fully enable. In fullscreen exclusive mode, if I do something so madVR has to switch out of exclusive mode, the subtitle will go outside of the video frame as if the "Position..." option is disabled. It won't go back even when madVR switched back to exclusive mode. Other than that it works great, outside of squeezed text which also happen in EVR. Edit: Kinda obvious but I should say that if I disable exclusive mode altogether then there is no problem, which is what I'll be doing right now. Edit2: I use MPC-HC 2990 Black edition from xvidvideo.ru, but I also double check with your version to make sure and it does the same thing.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. Last edited by Hypernova; 20th March 2011 at 04:49. |
20th March 2011, 05:56 | #6109 | Link | |
Angel of Night
20th March 2011, 07:07 | #6110 | Link | |
I have tried requesting support back in november, but I was just directed to this page and told to delete some registry entries and any residual files which I did, but that never helped. http://sourceforge.net/apps/trac/mpc...ing_guidelines
20th March 2011, 09:21 | #6111 | Link | ||||||
http://mpc-hc.svn.sourceforge.net/vi...&view=revision Can you please complain to Trend Micro? Thanks!! Quote:
What would you need that for? The x86 version works just fine on 64bit OSs. Quote:
20th March 2011, 10:19 | #6114 | Link |
Thanks a lot for the subtitle rendering support madshi, good work.
Some threads before someone talked about a proportion bug, this bug is about video that don't have a 1:1 Pixel aspect ratio. http://sourceforge.net/apps/trac/mpc-hc/ticket/60 here it is, if anyone could fix it since mph-hc team doesn’t want to work on it. Grab the test case at the end of the ticket for easy understanding. Of course non 1:1 PAR video are getting very rare, and the problem can be solved by writing the ASS script without PAR compensation. |
20th March 2011, 10:24 | #6115 | Link |
Here is a log, http://unibios.free.fr/madlog.rar
Just to give some specs, Im on Win7x64SP1. After the single seek forward the subs are display way out of sync. |
20th March 2011, 10:44 | #6117 | Link | |
20th March 2011, 11:22 | #6120 | Link |
Thats because you're using ffdshow to render the subs, and not the MPC-HC sub renderer which works with every decoder. ffdshow directly pins the subs onto the decoded image, the renderer does not know about it. The MPC-HC sub renderer creates a surface with the sub information on, and relys on the renderer to merge that surface onto the picture from the decoder.
