Old 14th July 2015, 18:10   #31801  |  Link
nevcairiel
Originally Posted by James Freeman View Post
Madshi,
Here is my crash report (Ctrl+C as you instructed):
The actual crash report would be much longer than this one line.
You can copy-paste the entire dialog - and it'll include plenty information. Don't try to extract this one line from it.
Its in German.
Thats fine, so is he.
Old 14th July 2015, 18:12   #31802  |  Link
James Freeman
I did not try to extract anything, just ctrl+c and ctrl+v into notepad. That's all there is.
BUT, it tries to send email with a much longer crash report, I'll upload that.
EDIT:
Ahh yes, I need to click "show bug report" and only then press ctrl+c.
In a minute...
http://www.mediafire.com/download/6v...eport_James.7z
disassembling:
4a47e0dd call +$4f6e ($4a483050) ; settings.cpp.CSettings.GetCurrentSmoothMotion (madVR64.ax)
4a47e0e2 test al, al
4a47e0e4 jz loc_4a47e387
4a47e0ea 7078 movsxd rax, dword ptr [r13+$26a0a0]
4a47e0f1 imul rax, rax, $9a8
4a47e0f8 > cmp byte ptr [rax+rsi+$71], 0
4a47e0fd jz loc_4a47e10f
4a47e0ff mov rcx, [r13+$26a0e0]
4a47e106 call -$6a30b ($4a413e00) ; dynopencl.cpp.COpenCL.IsNVidia (madVR64.ax)
4a47e10b test al, al
4a47e10d jnz loc_4a47e128
Disabling SmoothMotion from the start stops the crashes.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410.
James Freeman is offline   Reply With Quote
Old 14th July 2015, 18:15   #31803  |  Link
ashlar42
Originally Posted by XMonarchY View Post
Another thing I noticed is that my TV is set to 12bit color depth via NVidia CP, madVR is set to 10bit+, ctrl+J menu shows D3D11 exclusive (10bit), but right under it I get "h264, 8bit, 4:2:0 - NV12, 8bit, 4:2:0". Is that how it should be or is my LAV Filter/Decoder (or something else) not configured correctly? I have all LAV Filter/Decoder output formats ticked/enabled except for AYUV.
I would be interested in a reply to the very same question.
Old 14th July 2015, 18:15   #31804  |  Link
Ver Greeneyes
madshi, I think the crash report I uploaded may not have been for the right crash (it may have been an old one still sitting on my desktop). Even though the crash reporter comes up, when I get this crash it doesn't seem to create a crash report - which may explain why it can't send the report. I created a debug log where it crashes, and tried pressing Ctrl+C on the crash reporter window (then pasting it to a text file), which seems to have worked. I've uploaded the two logs here.
Old 14th July 2015, 18:24   #31805  |  Link
noee
madshi,
I'm getting an immediate crash with jRiver MC20b129 as soon as I open an MKV for playback with 17. 16b is fine, seems like what the other guys are getting, would you like a crash report or do you have enough? MPC-HCx64, however, is not crashing...
Win7Ult || RX560/4G || Ryzen 5
noee is offline   Reply With Quote
Old 14th July 2015, 18:33   #31806  |  Link
means this:
h264 8bit is the source video. codec and bit deep.
NV12 is the decoded frame format. lavfilter or any other decoder is decoding these frames to this example format.
NV12 is a 8 bit 4:2:0 colorspace could be YV12 too doesn't matter.
or in short it is what madVR gets as input.
Old 14th July 2015, 18:36   #31807  |  Link
madshi
A crash report is always helpful, so yes, I would like to see it. It could be the same as the one from Ver Greeneyes and James Freeman (which is identical), but it could also be a different one. One quick look at it and I know.
Old 14th July 2015, 18:56   #31808  |  Link
Warner306
Originally Posted by surgical View Post
Greetings to all:
First of all, I apologize if the question I'm going to do may seem silly, but for more that I've read in this thread yet I've a doubt about the " upscale refinements ".
My question is if these are activated in "any" upscaling, I mean, for example, with "image doubling"; or only when acts an algo from "image upscaling" .
Thanks in advance
Upscaling Refinement is activated whenever a video is resized. If your display is 1080p, then any source below 1080p must be resized and will use the Upscaling Refinement setting.
Old 14th July 2015, 19:05   #31809  |  Link
noee
Meh.....for grins and tickles, I rebooted and now I can't get the crash to occur again.....hate that.....er....or love it.
Be on Windows for a while so I'll see what else.
Oh yeah, I do see that strobing deint issue mentioned above with 17. 16b does not show it.
Old 14th July 2015, 20:49   #31810  |  Link
Braum
To be sure : if there is only Chroma Upscaling and Image downscaling, does Upscaling refinement is activated ?
Basically : Source resolution > Monitor resolution
Braum is offline   Reply With Quote
Old 14th July 2015, 22:08   #31811  |  Link
surgical
Dopax
Understood ...........thanks Warner306
surgical is offline   Reply With Quote
Old 14th July 2015, 23:19   #31812  |  Link
Damien147
Shall I activate superRes filter in chroma upscaling permanently?Is it for good?
Damien147 is offline   Reply With Quote
Old 15th July 2015, 00:33   #31813  |  Link
madshi
No.
I don't know. Try it, and let me know what you think!
Old 15th July 2015, 00:34   #31814  |  Link
madshi
madVR v0.88.18 released
http://madshi.net/madVR.zip
* fixed: DXVA deinterlacing resulted in heavy flickering
* fixed: low latency mode was always activated with some media players
* fixed: smooth motion FRC: OSD incorrectly reported empty queues
* fixed: crash when OpenCL wasn't working properly
* fixed: FSE mode was sometimes activated when it shouldn't
Any problems (introduced by v0.88.17) left?
Old 15th July 2015, 00:36   #31815  |  Link
tobindac
works now with DVB-T on latest mpc-hc (nightly). thanks.
tobindac is offline   Reply With Quote
Old 15th July 2015, 02:24   #31816  |  Link
XMonarchY
Any plans for an auto-updater for madVR?
EDIT: Yey! 88.18 fixed my presentation glitches on my 120Hz monitor!!!
8700K @ 5Ghz | ASUS Z370 Hero X | Corsair 16GB @ 3200Mhz | RTX 2080 Ti @ 2100Mhz | Samsung 970 NVMe 250GB | WD Black 2TB | Corsair AX 850W | LG 32GK850G-B @ 165Hz | Xonar DGX | Windows 10 LTSC 1809
XMonarchY is offline   Reply With Quote
Old 15th July 2015, 02:52   #31817  |  Link
baii
With current update speed, it will need to separate beta and stable for a updater to work for everyone, which is extra effort that can probably spend else where?
Sent from my 306SH
baii is offline   Reply With Quote
Old 15th July 2015, 06:06   #31818  |  Link
TOM_SK
htpc-updater - install or update MPC-HC, LAV Filters and madVR automagically.
https://github.com/nikola/htpc-updater
TOM_SK is offline   Reply With Quote
Old 15th July 2015, 06:25   #31819  |  Link
KhR0N1K
awesome! DXVA deinterlacing etc. seems fine now with v .18
i noticed something else im not sure is fixable. but in FSE DX11 its not as Exclusive as FSE DX9 was. for example my kaspersky trial notification still pops up while in FSE DX11 mode or the "Completed" msg pops up after successful burn with ImgBurn the video turns black for about half a second then stays Exclusive. the FSE DX9 version stayed fully Exclusive in both these situations.
not a big deal at all. just not sure if anyone has pointed these specific situations out.
KhR0N1K is offline   Reply With Quote
Old 15th July 2015, 06:45   #31820  |  Link
j5627429
Is there a way to adjust the size of the OSD text?
j5627429 is offline   Reply With Quote
