6th December 2019, 01:15 | #17941 | Link |
Grumpy Old Man.
So, if I create these extra "Custom" MDegrain .avs filters, is it as simple as adding (whatever you've named them), into the "Limit to following filters only" window, and the MT function will be enabled.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
6th December 2019, 13:08 | #17942 | Link |
It's easy, I have to replace C:/Program Files/RipBot264 in the script, with D:\DirectCD\Program Setup Files\RipBot264v1.25.0
and I think I will be alright EDIT: Preview Script works now
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B Last edited by slalom; 6th December 2019 at 13:14. |
6th December 2019, 14:51 | #17944 | Link | |
https://forum.doom9.org/showthread.p...06#post1891906
6th December 2019, 15:25 | #17945 | Link | |
So, now that everything works, can you add those 2 variations in the same drop down list? I've been checking some new jobs today, and I had a dilemma, use 1 or 2, or use 2 or 3? I had to de-select one then press the arrow, and select the other one, preview, too many clicks I think they have to be in the same menu
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
6th December 2019, 16:46 | #17946 | Link | ||
ByteShare
Usually what I do if I have a lot of jobs is either add them in groups with the custom filters I want or if only a few jobs add them all at once and then go back and change just those jobs manually. When you say frame accurate you don't mean timing, but rather frames completely just get skipped when they are not "accurate"? I haven't played with GPU decoding much but if that is more accurate than LSmash I'd use that on the machines I can even if sometimes slower. |
6th December 2019, 16:53 | #17947 | Link | |
6th December 2019, 17:24 | #17948 | Link | |||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 6th December 2019 at 17:28. |
6th December 2019, 18:48 | #17950 | Link |
Add MDegrain2 to custom section and you have all 3 in the same spot.
6th December 2019, 19:18 | #17951 | Link |
Hi Atak, I recently updated to v1.25.0. I just tried encoding the movie Life in DE mode and it failed with about 8 minutes left in the movie. When I look at the Chunks folder there are no *.264 files for the last 8 chunks. When I try to run each .cmd file manually I get these errors.
y4m[error]: bad sequence header magic x2464[error]: could not open input file `_' If I rerun the .cmd files for any of the completed chunks I get the normal .264 output. I don't understand what's going on. Should I just try recoding again from scratch? |
6th December 2019, 19:29 | #17952 | Link |
This might be corrupted source file, bug in source filter or broken hardware or driver.
6th December 2019, 19:46 | #17953 | Link | |
ByteShare
6th December 2019, 19:46 | #17954 | Link | |
6th December 2019, 19:49 | #17955 | Link |
With latest version of lsmash I recommend to use it for ALL formats! Just forget about ffms. Lsmash is superior in almost every aspect.
7th December 2019, 00:42 | #17959 | Link | |
Grumpy Old Man.
7th December 2019, 07:42 | #17960 | Link |
Grumpy Old Man.
Off topic...storage question..
So I would imagine that most of you have a reasonable collection of both unprocessed and processed movies & series, etc, which can add up to a LOT of Terabytes.
I would be interested to know what some of you (who are happy to oblige) have & use for storage, of said data ??? I have several reasonable capacity Supermicro storage servers, and a couple of Unraid "box's", but unfortunately, every so often there is a problem, and as a result, I get data corruption. I don't really have too much backed up, so sometimes it's a complete loss , which can be very frustrating, especially if it was irreplaceable. Anyway, I'm just curious...
