Old 18th October 2009, 02:49   #5961  |  Link
Preludee01
Was wondering, whats "Low Priority" for? I alwast use it when encoding. But not 100% sure what its for.
Preludee01 is offline   Reply With Quote
Old 18th October 2009, 05:48   #5962  |  Link
8ternity
8ternity's Avatar
It's the priority of use of the program during conversion. If you need to do some thing with your computer like surfing on the net, make paiements, chat, the memory request are in low priority. If you want to use it only for conversion and maximise your fps rate, you set it to "0".
If my knowledge is good
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating.
8ternity is offline   Reply With Quote
Old 18th October 2009, 06:00   #5963  |  Link
Preludee01
alright tks
Old 18th October 2009, 16:49   #5964  |  Link
MKVCrazy
HD-Fan
Sorry to bother you again, Atak. I have got a few basic questions. I have a clip which has 44.0 kHz and I want to make all my audio output to 48.0 kHz. How can I do this and also how can I make audio profile HE-AAC 2CH 48 kbps? The least I see in the drop down is HE-AAC 2CH 64 kbps.
MKVCrazy is offline   Reply With Quote
Old 18th October 2009, 21:01   #5965  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
ripbot264 always automatically resamples audio to 48khz.
I see no logical explanation why user would need 48 kbps option. Difference in size is too small compared to video size. 60 min -> 48kbps / 8 * 3600 = 21.1 MB vs 64kbps / 8 * 3600 = 28.1 MB
Old 18th October 2009, 21:55   #5966  |  Link
AMED
AMED's Avatar
I'm not sure if i'm missing something here, but does RipBot support creating anamorphic encodes like MeGUI?
The output of the few DVD movies i have tested with RipBot don't seem to be stretching on playback.
I'm not sure if it's my steps causing the problem, so i'll list what i'm doing.
1. Open ripped dvd in RipBot clicking on first .VOB
2. Once loaded, I click Properties.
3. Auto Crop, size is set to do not resize.
4. Denoise set to Flim
How RipBot encode plays in MPC-HC
How MeGUI encode plays in MPC-HC
#MT
#VideoSource
LoadPlugin("E:\RipBot264v1.14.5\Tools\dgindex\DGDecode.dll")
video=MPEG2Source("D:\temp\RipBot264temp\job1\job1.d2v")
#Deinterlace
#Decimate
#Crop
video=Crop(video,10,68,-6,-72)
#Resize
#Colors
#Denoise
LoadPlugin("E:\RipBot264v1.14.5\Tools\AviSynth plugins\fft3dgpu\fft3dgpu.dll")
LoadPlugin("E:\RipBot264v1.14.5\Tools\AviSynth plugins\gradfun2db\gradfun2db.dll")
video=FFT3DGPU(video,sigma=1.25).gradfun2db
#Subtitles
#AudioSource
LoadPlugin("E:\RipBot264v1.14.5\tools\AviSynth plugins\NicAudio\NicAudio.dll")
audio=NicAC3Source("D:\temp\RipBot264temp\job1\job1 T80 3_2ch 384Kbps DELAY 0ms.ac3")
audio=ResampleAudio(audio,48000)
#DownMix
Import("E:\RipBot264v1.14.5\Tools\AviSynth plugins\Scripts\DownMixAudio.avs")
audio=DownMix2Stereo(audio)
#Delay
audio=DelayAudio(audio,0)
#Tempo
#Normalize
#AudioDub
audio=ConvertAudioTo16bit(audio)
AudioDub(video,audio)
#Triming
#AVSameLength
#ColorSpace
ConvertToRGB
A Man Eating Duck
AMED is offline   Reply With Quote
Old 19th October 2009, 01:03   #5967  |  Link
Atak_Snajpera
Anamorphic works only if resolution is 720x480 or 720x576 or 1280x1080 or 1440x1080
Old 19th October 2009, 04:14   #5968  |  Link
illestdomer2005
I am trying to convert "Be Kind Rewind," and I keep getting the error message in Media Player Classic:
"DirectShowSource: couldn't open file [directory]: The system cannot find the file specified.
(C:\Temp\RipBot264\job5\getinfo.avs, line 2)"
Any help? I am using 1.14.4. Thanks!
illestdomer2005 is offline   Reply With Quote
Old 19th October 2009, 05:40   #5969  |  Link
Ajax_Undone
I dont care so should you
Ajax_Undone's Avatar
I have released a new installer on mediafire the link is in my signature...
There is also a torrent if you prefer.
Oh I almost forgot if you choose to download via the torrent please Seed.
My Installer's ||
Ajax_Undone is offline   Reply With Quote
Old 19th October 2009, 06:14   #5970  |  Link
Preludee01
@Ajax_Undone
Is thier any diference between yours and Atak_Snajpera?
Old 19th October 2009, 17:07   #5971  |  Link
Ajax_Undone
'Mine?' I just packed it into an nsis script installer that includes the extras needed to get it to run...
My Installer's ||
Old 19th October 2009, 19:27   #5972  |  Link
tommy9901
Originally Posted by Rumbah View Post
As you are using Windows 7, try using a tool to change the default DirectShow behaviour. You could use http://www.codecguide.com/windows7_p...er_tweaker.htm . Switch the desired decoder to ffdshow. If you want to use the Microsoft vc1 decoder, you have to select ffdshow in the program and then set the decoder in ffdshow to wmv9.
You have to set it only for 32 bit (and need a 32 bit ffdshow) as avisynth uses 32 bit.
i've the same problem in mpeg-1 ,what can i do
tommy9901 is offline   Reply With Quote
Old 19th October 2009, 21:57   #5973  |  Link
MKVCrazy
HD-Fan
Ok then now this is solved.
Uhm, well that's great then. Do you know if Zune or ZuneHD plays 64kbps HE-AAC audio? By they way do you recommend converting DVD movie backups to PSP format with 64kbps HE-AAC even though the frequency is half? How does half affect the experience?
I still need the answer on how to modify the default FFT3GPU parameters you put in RipBot264.
MKVCrazy
Old 19th October 2009, 22:01   #5974  |  Link
Atak_Snajpera
Do not use HE-AAC because mobile players (PSP and so on) do not decode HE part. Instead of 48khz you will get 24Khz.
Old 20th October 2009, 11:56   #5975  |  Link
MKVCrazy
HD-Fan
Yes, I noticed that clearly. I'll use 96 LC-AAC then. Sorry if you didn't see my last reply as I edited after you replied.
Is there away to change the default FFT3GPU parameters that's used when selecting any of the DENOISE option? For me, the FILM was is a little too smoothed.
Old 20th October 2009, 14:44   #5976  |  Link
Rumbah
I just got an error of Ripbot not finishing an encoding job. With further inspection of the log file I noticed that Ripbot set -fps 23,96 in the x264 command line and it has to be 23.96. I'm using a German Windows and the "," is the normal decimal separator opposed to the English ".". Manually editing the bat file fixes the problem.
My log:
P:\>"C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\tools\bepipe\bepipe.exe" --script "import(^P:\temp\RipBot264temp\job1\job1.avs^)"   | "C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\Tools\enc_aacPlus\enc_aacPlus.exe" - "P:\temp\RipBot264temp\audio.aac" --lc --cbr 98804
 BePipe by dimzon
Script used:
# BEGIN
import("P:\temp\RipBot264temp\job1\job1.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=2, BitsPerSample=16, SampleRate=48000Hz
Writing Header...
Writing Data...
0%
Done!
* AACPlus v2 Encoder (using Winamp 5.2 enc_aacplus.dll)
* Source timestamp Mon May 15 17:24:26 2006
* Build May 15 2006, 17:24:35
* NOTE!	enc_aacplus.dll must be into executable directory
*	get it from Winamp 5.2 plugins directory
*	tested on Winamp 5.2 Release Feb 23 2006 Full (Not Pro) version)
Input file: -
Output file: P:\temp\RipBot264temp\audio.aac
SampleRate: 48000
ChannelCount: 2
BitsPerSample: 16
Bitrate: 98804
ChannelMode: Stereo
Encoder: AAC-LC
Encoding...
Finalizing...
Done
P:\>"C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\tools\avs2yuv\pipebuf.exe" "C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\tools\avs2yuv\avs2yuv.exe" "P:\temp\RipBot264temp\job1\job1.avs" -raw - : "C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\tools\x264\x264_x64.exe" --crf 22 --stats "P:\temp\RipBot264temp\job1\job1.stats" --fps 23,96 --min-keyint 24 --keyint 240 --frames 28493 --sar 1:1 --level 3.0 --filter 1,1 --ref 3  --bframes 16 --b-adapt 2  --direct auto --subme 10 --aq-mode 1 --trellis 2 --partitions p8x8,b8x8,i4x4,p4x4 --no-8x8dct --me umh --output "P:\temp\RipBot264temp\video.264" - 480x272 : 2
x264 [error]: invalid argument: fps = 23,96
P:\temp\RipBot264temp\job1\job1.avs: 480x272, 10000000/417327 fps, 28493 frames
Output error: wrote only 185716 of 195840 bytes
P:\>"C:\Users\Michael\Desktop\Treiber\RipBot264v1.14.5\tools\mp4box\mp4box.exe" -tmp "P:\temp\RipBot264temp"  -add "P:\temp\RipBot264temp\video.264":name="videoklein" -fps 23.96 -add "P:\temp\RipBot264temp\audio.aac":lang=und -mpeg4  -new "C:\Temp\videoklein.mp4"
Cannot find file P:\temp\RipBot264temp\video.264
Error importing P:\temp\RipBot264temp\video.264:name=videoklein: Requested URL is not valid or cannot be found
Elapsed Time: 00h:00m:31s
Rumbah is offline   Reply With Quote
Old 20th October 2009, 18:36   #5977  |  Link
Preludee01
Hey. Ive got a problem. When i use ripbot to re-encode 1080p MKV to 720p MKV, it does not complete. (Worked before for a while). After like 3m to 1h, it say completed. And i dont have nothing in the forlder i saved in it. Usally it takes 6-7h, in 2Pass-Mode. Is their someting that can cause that> tks
Old 20th October 2009, 18:43   #5978  |  Link
Atak_Snajpera
is your CPU stable? Use LINX (link in first post)
Old 20th October 2009, 21:08   #5979  |  Link
MKVCrazy
HD-Fan
There's no way to change the default FFT3GPU parameters?
Old 20th October 2009, 22:00   #5980  |  Link
Atak_Snajpera
not yet. you are first who does not like my default settings.
