24th February 2003, 07:15 | #62 | Link |
Lurker in Training
So far I have had no trouble playing it in anything. The trouble is encoding it :P
I first ran into these kinds of files when I was doing Fansub encoding about a year and a half ago. Nowadays, to look cool, many shows have opening sequences which are in 29.97fps progressive, while the rest of the show is in 23.976fps telecined to 29.97. What raw encoders used to do was just decimate the opening sequence and keep it at 24 like the rest of the episode when they IVTC'ed their TV captures. But then someone came out with a tool (I don't have it, I just know it exists) that allowed the insertion of Drop frames to sync them up at 59.94fps by inserting 1 drop frame every other frame in the 30fps portion and alternating 1 and 2 frames in the 23.976fps portion. The problem was when I would open them up in VirtualDub, and would try to recompress them, it would recompress all the frames (all 59.94 per second of them) and thus the resulting file would be unplayable. I used AVISynth's SelectEvery to get around this problem, and fed the sections and encoded them separately, but I instead just tacked on the opening and ending sequences from previous episodes so I didn't have to decimate them myself, which is what I would've had to do anyways since I didn't have the tools to re-add the drop frames. This was back in the days when raw encoders were using MP42, MP43, or DIV3 (occaisionally). Their DShow playback filters dealt with the files fine - you would go to Media Player 6.4's Statistics and you would see Frame Rate: 59.94 and Actual Rate: 29.97 or 23.976 depending on the portion. I thought it was pretty ingenious - it's just a pain to deal with. Really the drop-frame insertion would only be useful for DirectShow playback, doing that with the VFW interface would be ugly unless VDubMod could be told "If there's a drop frame reported by the AVS file, insert a drop frame in the file being encoded" which I suppose wouldn't be too hard to do, we'd just have to ask them to implement said feature. Now I will completely acknowledge here that we are totally bastardizing the AVI standard and making it do things it really really was never meant to do - but you can say the same thing about Bi-directional Predicate Frames, too I can post a short sample of one of the Raw files that does this if you guys want to take a look at it. |
24th February 2003, 20:34 | #63 | Link |
Retired AviSynth Dev ;)
Can't really see any good way of putting in 100% variable bitrate. It is not a part of VFW-API - it has one framerate per AVI file. I don't see using "output_fps = fps1*fps2" with an extremely large amount of duplicate frames as a solution.
Could we move this OT discussion another place? Back on track: I have created an ISSE/MMX interlaced YV12 -> YUY2 converter from scratch, and put it in CVS. I hope to be able to do an interlaced YUY2 -> YV12 soon also. It is currently implemented as ConvertToYUY2(interlaced=true). This may be changed! My current priority list on needed conversions are: Interlaced YUY2 -> YV12. Cleanup of convert.cpp I just realized what a mess it is! Rewrite of non-interlaced YV12 <-> YUY2. Interlaced YV12 <-> RGB. (This will probably be implemented using a combination of existing filters - this is NOT easy code!) Hybrid Frametype detector. As proposed a routine that is capable of detecting interlacing in hybrid material (telecined material for instance).
Regards, sh0dan // VoxPod Last edited by sh0dan; 24th February 2003 at 20:37. |
24th February 2003, 22:42 | #65 | Link |
ok - these two points are done:
Or at least - the progressive YV12 -> YUY2 rewrite is finished and the cleanup has begun. I realized that the XviD routines doesn't interpolate chroma when doing YV12 -> YUY2 - this is also done now. The speed should be about the same as the XviD routines (a little give and take). Also the speed for non-mod8 resolutions should be up. I'll release a binary ASAP.
Regards, sh0dan // VoxPod |
24th February 2003, 23:44 | #66 | Link |
I can't guarantee the YV12->YUY2 interlaced conversion functions in MPEG2DEC2 are correct but I believe they are. But if so then comparing the results of MPEG2DEC2 vs (non-PP) MPEG2DEC3 converted to YUY2 should now give identical results for pure interlaced source.
But I haven't performed this test yet. - Tom |
25th February 2003, 09:02 | #67 | Link | ||
Avisynth Developer
Frustration::6_Foot_length_of_3x2_Hardwood(Head.object)
Just two quotes from the many to stress this point.....
to distinguish Progressive/Interlaced status. As originally implemented it is most definitly a clip attribute, it simply meant the clip had been SeparateFields()'ed. Quote:
AssumeFieldBased() should NEVER have been hijacked to mean Interlaced, it originally meant the clip has been SeparateFields()'ed and it should have stayed that way. Let me try and get this point across 1 more time. IsFieldBased() as originally defined simply meant the clip had been thru SeparateFields() It has been HIJACKED to try and mean the clip is Interlaced and this great cock-up has caused all the problems and confussion in this current thread and others. This is a programming attribute collision!! Where one piece of data means two different and distinct things. It is a software design BUG! Really simply solution
If the chosen implementation is deamed to involve IsFieldBased() then reference it IN ONLY ONE PLACE, in the IsInterlaced() implementation. Don't mix up these two concepts again. IanB P.S. If anything the frames of clip.AssumeFieldBased() are certainly NOT interlaced, they are the individual fields of a possibly interlaced, possible progressive clip and individual fields can never be interlaced (a 2nd time)! Last edited by IanB; 16th August 2008 at 09:35. Reason: fix [/list=1] no longer supported |
25th February 2003, 09:23 | #68 | Link |
@IanB: We DO know. And we are currently INVESTIGATING what method is worth pursuing - <g> relax, man!
IMO the original idea of adding i VideoInfo property called "Fieldbased", and using it for very filter specific purposes isn't a very clever design, but when there are only one developer, these things do easily happend. Using an "is_field_separated" property would be much more nice, if it is a good idea. IMO the original property is NOT a good idea to preserve, since it creates an unpredictable behaviour. IMO SeparateFields/Weave should always behave the same, no matter the Video! You could have been there shouting at me, when I asked if anybody knew how the Fieldbased/Parity stuff worked MONTHS ago! You are NOT being very constructive!
Regards, sh0dan // VoxPod Last edited by sh0dan; 25th February 2003 at 09:25. |
25th February 2003, 09:36 | #69 | Link | |
I'm my opinion the primary power of AviSynth is total user control - you have complete control over every aspect of your video. When AviSynth makes decisions for me, I get annoyed, because I always want a filter to produce the same results. So when AviSynth makes decisions on how to treat a video signal based on previous filters this is kinda annoying to me. This is why I want to get rid of this situation. The point of the new conversions, and the suggestions to Separatefields/Weave is to make them behave the same no matter what material they are fed with.
25th February 2003, 10:14 | #70 | Link | |
Simply me
The syntax ConvertToYUY2(interlaced=true) is excellent and the way to go in my opinion. Therefore SeparateFields and Weave should have optional parameters to force their behaviour instead of relying on the parity flag. regards Simon PS I don't think IanB is being aggressive just assertive
http://www.geocities.com/siwalters_uk/fnews.html |
25th February 2003, 14:06 | #71 | Link | ||||
Avisynth Developer
My most humble apology for being excessively assertive
forums and I haven't been getting acknowledgment I was on the right track or argument that I was wrong and completely off tangent. Quote:
name, what has that got to do with field order. Quote:
Weave() and Bob() have a little problem in needing Field Order information i.e. "Parity". This gets very complicated when Trim(), DeleteFrame() or DuplicateFrame() get involved. Think how you would handle deleting a single field in a clip, now the clip has 2 top or bottom fields adjacent. The current very obtuse code does handle this gracefully. Hence my suggestion 2. leave field.cpp alone until 3.0 Quote:
how Parity() abuses OO method overlay in "Dilema - Crop restriction - Fieldbased clips" Anyway how can I help? Revue code, suggest algorithms, Consolidate my current ravings into one post, just ask. IanB Last edited by IanB; 25th February 2003 at 14:11. |
25th February 2003, 14:22 | #72 | Link | ||||
Re: My most humble apology for being excessively assertive
EDIT: I see now there is ambiguity about what sh0dan is proposing regarding parity (tff/bff handling). Does he propose to remove its influence from Weave() and others, or does he just propose to change its syntax? shodan, can you please elaborate? On the field-based/frame-based property, no one has yet argued to keep it. Quote:
25th February 2003, 18:43 | #74 | Link |
I had to preceed Bob() with SwapFields().
My comment is that taking a hard look at how mpeg2dec works might be the only way to fix these problems. AviSynth and mpeg2dec have to come to an agreement. [edit] mpeg2dec must work the same way as DV captured material. You see? We want Avisynth to work the same betweem DVDs and Digital Video.[/edit] Stephen Last edited by scmccarthy; 25th February 2003 at 18:52. |
26th February 2003, 08:26 | #75 | Link |
But MPEG2DECx also gets to look at the progressive frame flag (whatever it's called) which is not currently being passed along.
On the good side, I've even got P4 optimized SSE2 code for the MPEG2DEC color conversions, though it is not included yet. - Tom |
26th February 2003, 16:53 | #77 | Link |
"GOP" to me is a Group Of Pictures, a I-frame and it's following P&B frames. I don't think any control block is passed to Avisynth for each of these so I'm not sure what you are asking.
- Tom |
27th February 2003, 01:51 | #78 | Link |
Avisynth Developer
For Reference Only - Transcript from developer forum
So as to keep all the relevant discussion in one place the following
is a transcript from the Developer Forum. By: IanB Posted: Fri, 21 Feb 2003 3:37 pm Post subject: Frame/Field Based vs Interlaced/Progressive Dear Richard Berg, TRBarry, Hakko504, Neuron2, Sh0dan, et el I have been trying to gently provoke some sane discussion about the contorted use of the IsFieldBased() flag with respect to the new YV12 implementation in avisynth 2.5 on the Doom9/Avisynth forum. Being somewhat unsuccessful I thought I might try a more direct approach to some of the key players here in this more quiet forum. My research into the original Avisynth source reveals that FrameBased and FieldBased concept derive from SeparateFields() and Weave() [field.cpp,h] implying the following definitions:- FrameBased :- Video samples are whole frames, either progressive or interlaced. FieldBased :- Video samples are individual fields. Alternate samples are top, bottom field. Usually the result of a SeparateFields() operation. The new YV12 codebase has subsumed these definition and is using FieldBased to imply Interlaced! Which is at odds with the original coding intent and is causing subtle changes in the beviour of unrelated verbs like Crop(). What is apparent is this needs to be clearly and concisely defined and rigidly adheared to in the core Avisynth code. I was proposing a new verb AssumeProgressive() to match with the current AssumeTFF() and AssumeBFF() both which imply a FrameBased interlaced source or indicate the parity with FieldBased (i.e field separated) samples. For background the following thread is a current example of the difficulty http://forum.doom9.org/showthread.php?s=&postid=263776 And the following post my original discussion of the problem http://forum.doom9.org/showthread.ph...550#post259273 Regards IanB By: Guest Posted: Fri, 21 Feb 2003 6:50 pm I wrote a "note to self" when I looked at GetParity. http://cvs.sourceforge.net/cgi-bin/v...viewcvs-markup IsFieldBased is unfortunately used in the complete opposite way as it would be expected. AssumeProgressive() actually makes nice enough sense. But the field-based code needs reworking. By: sh0dan Posted: Fri, 21 Feb 2003 6:58 pm Oh "Guest appear cortesy of sh0dan Records" Quote: > AssumeFrameBased throws away the existing information and assumes > that the clip is frame-based, with the bottom (even) field dominant > in each frame. (This happens to be what the source filters guess.) > If you want the top field dominant, use ComplementParity afterwards. > > AssumeFieldBased throws away the existing information and assumes > that the clip is field-based, with the even-numbered fields being > bottom fields and the odd-numbered fields being top fields. If you > want it the other way around, use ComplementParity afterwards. This is a stretch in my opinion. Framebased - makes AviSynth think that both fields are present in the same frame - completely backwards to me. AssumeFieldBased makes AviSynth assume that fields have been separated. The above distinguishment doesn't make any sense to me. For now, I have flipped (most) functionality around, so that: Fieldbased: Video is asummed to be interlaced. Framebased: Video is assumed to be progressive. We could add a separate property for video that has been split, but IMO it would be much better if the SeparateFields and Weave/DoubleWeave didn't act on this property, but always performed the same action on the video. Does this make any sense? _________________ Regards sh0dan // Klaus Post. By: IanB Posted: Fri, 21 Feb 2003 9:47 pm Sh0dan wrote: > AssumeFrameBased() throws away the existing information and assumes > that the clip is frame-based, with the bottom (even) field dominant > in each frame. (This happens to be what the source filters guess.) > If you want the top field dominant, use ComplementParity afterwards. > > AssumeFieldBased() throws away the existing information and assumes > that the clip is field-based, with the even-numbered fields being > bottom fields and the odd-numbered fields being top fields. If you > want it the other way around, use ComplementParity afterwards. Apart for the effects of the new AssumeTFF() and AssumeBFF() verbs. > This is a stretch in my opinion. > > Framebased - makes AviSynth think that both fields are present in > the same frame - completely backwards to me. > > AssumeFieldBased makes AviSynth assume that fields have been separated. This is a very eloquent and succinct explanation of how we both appear to understand how the original Avisynth works. > The above distinguishment doesn't make any sense to me. For now, > I have flipped (most) functionality around, so that: > Fieldbased: Video is asummed to be interlaced. > Framebased: Video is assumed to be progressive. Although I agree with your sentiment, I have to say it is a little bit unfortunate that you are redefining script behaviour with these changes. Old Avisynth users know and expect the current behaviour and redefining it just ends up confusing everybody and losing any hope of backwards script compatibility. > We could add a separate property for video that has been split, but IMO > it would be much better if the SeparateFields and Weave/DoubleWeave > didn't act on this property, but always performed the same action on > the video. > > Does this make any sense? > _________________ > Regards sh0dan // Klaus Post. I would urge you in the most strongest terms to leave the current definitions of AssumeFrameBased() and AssumeFieldBased() and their interaction with SeparatedFields() and Weave() alone. For better or worse that is the way they work and the way peoples existing scripts expect them to work. In order to move forward I would propose that the old verbs AssumeFrameBased() and AssumeFieldBased() simply be declared depreciated and brand new script verbs be declared that accuratly describe the state of play. i.e Code:
Verbs ===== AssumeCompleteFrames() depreciates AssumeFrameBased() AssumeSeparatedFields() depreciates AssumeFieldBased() AssumeUnknownPI() declares Progressive/Interlaced unknown state AssumeTFF() declares Interlaced source, top field dominant AssumeBFF() declares Interlaced source, bottom field dominant AssumeProgressive() declares Progressive source Properties ========== IsCompleteFrames() depreciates IsFrameBased() IsSeparatedFields() depreciates IsFieldBased() IsUnknownPI() Test for Progressive/Interlaced state unknown IsInterlaced() Test for Interlaced source IsTFF() depreciates/extends Getparity() IsBFF() depreciates/extends Getparity() IsProgressive() Test for Progressive source have all the even height protection of interlaced clips and doing things that need the P/I status like YV12 -> YUY2 or RGB conversion throw a script exception. For completness internal methods like isFieldbased() should only be used in field.cpp/h and be replaced with new isProgressive() and isInterlaced() methods in the new YV12 code that need this information. A search of a good Thesaurus may yield better terms than I have used but I hope the idea and sentiment is clear. IanB By: neuron2 Posted: Sat, 22 Feb 2003 3:26 am What a contorted mess we are creating. And why!? I am going to propose a simple solution. Remove all notion of parity! For filters that want to disassemble/reassemble frames, just give them a parameter to specify the order of splitting/reassembling. Leave it totally up to the user to determine whether his actions make sense for the source material and task he is trying to accomplish. For example, instead of SeparateFields(), which makes an unnecessary assumption that the source is composed of fields, just have: Separate(first=) You could use it on a progressive clip (indeed on any clip) if you like. Why not? For example this would be a reduce by two vertically for a progressive frame: Separate(first=even).SelectEven() It sounds radical but why do we really need this whole idea of parity? It doesn't work correctly anyway for all the known reasons. And there seems no reason for having the frame-based/field-based distinction either (at the scripting level, per-frame flags such as progressive/interlaced carried in the clip itself is another matter entirely). Think of how this would simplify the bizarre code we have today and make everything consistent for all kinds of source material. We are creating all these issues for ourselves for nothing, IMHO. IanB proposed these properties: IsUnknownPI() Test for Progressive/Interlaced state unknown IsInterlaced() Test for Interlaced source IsTFF() depreciates/extends Getparity() IsBFF() depreciates/extends Getparity() IsProgressive() Test for Progressive source Every one of them can change during a single clip! That is the bottom line. All of this per-clip flag business is useless. I humbly wait to be refuted. I am willing to table a complete and consistent scheme if people are willing to consider it. _________________ Donald Graft Filters for Avisynth and VirtualDub http://shelob.mordor.net/dgraft/ By: sh0dan Posted: Sat, 22 Feb 2003 6:19 am Followup: http://forum.doom9.org/showthread.ph...410#post266410 _________________ Regards sh0dan // Klaus Post. Last edited by IanB; 27th February 2003 at 01:57. |
27th February 2003, 05:38 | #79 | Link |
Well, we've gone round and round and mostly proved that most of us (including me) had it backwards on the first cut. But I still lean towards keeping it compatible with the way it used to be and just adding some extra flags later.
I'm not sure. Did anything get decided? - Tom |
27th February 2003, 05:41 | #80 | Link |
Avisynth Developer
Anyway how can I help? (Part 1)
Okay, I have had yet another read thru the source. The following is
a list by functional entity that currently uses the .IsFieldBased() method and what I have found about it with respect to nuking the Field Separated Attribute. SeparateFields() In SeparateFields() the use of IsFieldBased() is a protectionist restriction to prevent the lose of top field/bottom field state information from an already field separated clip by the user. --- It can probably be derestricted right now without problem. Weave() Weave() is implemented internally as a DoubleWeave().SelectEven() hence the apparent transparency (see below) on IsFrameBased() clips. --- Refer to DoubleWeave() DoubleWeave() In DoubleWeave() the use of IsFieldBased() causes 2 different and distinct behaviours. (This is what sh0dan so rightly loaths) For IsFieldBased() clips it produces a unique weaving of each field with both adjacent fields. It uses the internal primitive DoubleWeaveFields() i.e. input 0b 1t 2b 3t 4b 5t output 0b1t 2b1t 2b3t 4b3t 4b5t 4b5t Note :- the last 2 frames are 4b5t (Boundary condition in GetFrame()) For IsFrameBased() clips it does an implicit SeparateFields() and then produces a unique weaving of each field with both adjacent fields only with much greater efficiency. It uses the internal primitive DoubleWeaveFrames() i.e. input 0b1t 2b3t 4b5t output 0b1t 2b1t 2b3t 4b3t 4b5t 4b5t Having the following piece of script do a 1 field phase shift with high internal efficient I find a very great boon. . DoubleWeave().SelectOdd() --- Removing the Field Separated property will break legacy script support for DoubleWeave(). Bob() In Bob() the use of IsFieldBased() causes 2 different and distinct behaviours. (This is what sh0dan so rightly loaths) For IsFrameBased() clips it adds a SeparateFields() to the front of the GetFrame() chain and proceeds as per the IsFieldBased() case. For IsFieldBased() clips it produces a double rate, IsFrameBased(), Vertically resized clip with the top fields moved up 0.5 lines and the bottom fields moved down 0.5 lines. --- Removing the Field Separated property will break legacy script support for Bob(). GetParity() This basic GetParity() method chain holds the Top field/Bottom field information for a clip. inline bool __stdcall GetParity(int n) { return parity ^ (vi.IsFieldBased() && (n & 1)); } (parity is a private bool) Each child that does something to effect that information overlays this method with a new piece of code that possible chains to it's parents original method. i.e. For ComplementParity() the following code is overlayed inline bool __stdcall GetParity(int n) { return !child->GetParity(n); } After unwinding the murkey mire of this "parity" code I have to respect the ease with which it tracks top field/bottom field state thru an AviSynth session. ---Removing the Field Separated property will require the design of a new top field/bottom field state tracking algorithm. ConvertFPS() The algorithm used in ConvertFPS() doesn't appear quite right when used with field separated content. It needs some help from Bob(). It hacks with the GetParity() method when IsFieldBased() ---It currently does not make correct use of the information ShowFrameNumber() For IsFieldBased() clips the odd numbers are offset to the left of the display area, this is a useful diagnostic feature. ---Cosmetic effect only The rest (new YV12 code) This code is basicly treating IsFieldBased() to mean IsInterlaced() and enforcing 2**n height restrictions. ---Should be using Progressive/Interlaced determination YV12 progressive/interlaced chroma sampling Progressive YV12 is easy to understand each 2x2 Luminance group has single corresponding chroma samples. i.e. Progressive Frame ================= Y_Y.Y_Y Line 1 C__.C__ Lines (0.5)*1 & (0.5)*2 Y_Y.Y_Y Line 2 ___.___ Y_Y.Y_Y Line 3 C__.C__ Lines (0.5)*3 & (0.5)*4 Y_Y.Y_Y Line 4 Interlaced YV12 has a bit of a twist, the samples of each field go together and just to add some spice there is an alternating 1 line vertical spacial displacement of the chroma data. Interlaced Frame ================ Y_Y.Y_Y Line 1t C__.C__ Lines (0.75)*1t + (0.25)*3t Y_Y.Y_Y Line 2b ___.___ Y_Y.Y_Y Line 3t C__.C__ Lines (0.25)*2b + (0.75)*4b Y_Y.Y_Y Line 4b In one of my earlier posts I suggested Field Separated video samples could be considered as Progressive, this is very clearly wrong. Field Seperated YV12 Interlaced samples are a completely different animal to Vanilla Progressive samples and (forced) Field Separated YV12 Progressive are just a really viscious little animal. Top Seperated Field (Note (0.5) line up weighting) =============== Y_Y.Y_Y Line 1t C__.C__ Lines (0.75)*1t + (0.25)*3t Y_Y.Y_Y Line 3t ___.___ Y_Y.Y_Y Line 5t C__.C__ Lines (0.75)*5t + (0.25)*7t Y_Y.Y_Y Line 7t Bottom Seperated Field (Note (0.5) line down weighting) ================= Y_Y.Y_Y Line 2b C__.C__ Lines (0.25)*2b + (0.75)*4b Y_Y.Y_Y Line 4b ___.___ Y_Y.Y_Y Line 6b C__.C__ Lines (0.25)*6b + (0.75)*8b Y_Y.Y_Y Line 8b Top Progressive Separated Frame (Note the chroma samples are (0.5) from another frame) ========================= Y_Y.Y_Y Line 1 C__.C__ Lines (0.5)*1 & (0.5)*2 Y_Y.Y_Y Line 3 ___.___ Y_Y.Y_Y Line 5 C__.C__ Lines (0.5)*5 & (0.5)*6 Y_Y.Y_Y Line 7 Bottom Progressive Separated Frame =========================== Y_Y.Y_Y Line 2 C__.C__ Lines (0.5)*3 & (0.5)*4 Y_Y.Y_Y Line 4 ___.___ Y_Y.Y_Y Line 6 C__.C__ Lines (0.5)*7 & (0.5)*8 Y_Y.Y_Y Line 8 ---Truely accurate YV12 rendering is going to need to be aware of Field Separated clips I'll continue this discussion further in the next post. (I need a break) IanB [EDIT]Fix Dyslexia with Top/Bottom in ascii art for siwalters[/EDIT] [EDIT^2]Fix Horiziontal chroma siteing in ascii art for siwalters[/EDIT] Last edited by IanB; 1st March 2003 at 01:01. |
