16th February 2008, 10:22 | #123 | Link |
the source is a japanese ntsc r2 anime dvd.here is my script
DGDecode_mpeg2source("E:\kor\VTS_01sample.d2v",info=3) ColorMatrix(hints=true) o = last ox = o.width() oy = o.height() crop_L = 4 area_L = 32 crop_T = 4 area_T = 32 crop_R = 4 area_R = 32 crop_B = 0 area_B = 0 stackvertical( \ stackhorizontal( \ o.spline16resize(area_L,area_T,crop_L, crop_T,area_L-crop_L,area_T-crop_T), \ o.spline16resize(ox-area_L-area_R,area_T, area_L,crop_T,ox-area_L-area_R,area_T-crop_T), \ o.spline16resize(area_R,area_T,ox-area_R,crop_T,area_R-crop_R,area_T-crop_T) ), \ stackhorizontal( \ o.spline16resize(area_L,oy-area_T-area_B, crop_L,area_T,area_L-crop_L,oy-area_T-area_B), \ o.crop(area_L,area_T,-area_R,-area_B), \ o.spline16resize(area_R,oy-area_T-area_B, ox-area_R,area_T,area_R-crop_R,oy-area_T-area_B) ) ) source = last backward_vec3 = source.MVAnalyse(isb = true, delta = 3, pel = 2, overlap=4, sharp=1, idx = 1) backward_vec2 = source.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) backward_vec1 = source.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec1 = source.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec2 = source.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec3 = source.MVAnalyse(isb = false, delta = 3, pel = 2, overlap=4, sharp=1, idx = 1) source.MVDegrain3(backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3,thSAD=400,idx=1) dfttest(sigma= 0.8) LimitedSharpenFaster(ss_x=1.1, ss_y=1.1, smode=4, strength=150,undershoot= 10) dup() |
16th February 2008, 23:03 | #124 | Link |
Angel of Night
That's a good place to put dup. You could put it before sharpening as well, as long as it's after deinterlacing and denoising.
Merlin, it's actually for both of the reasons you listed. |
17th February 2008, 00:18 | #125 | Link |
Fighting spam with a fish
I understood that, it's just that Kumo wanted to know about the reason for the lower bitrate, and bitrate specifically had to do with the noise, while overall size dealt with the duplicate frames.
And thanks. |
19th February 2008, 21:48 | #128 | Link |
i'm trying to use dup in a script to encode an '80s japanese anime dvd.i get jerky video ,specially in slow zoom or vertical scrolls(calling it with default settings).how could be an ultra-safe(to avoid jerkyness) setting?would it help in lowering wasted bitrate anyway?
2nd July 2008, 22:56 | #130 | Link |
Where to put DUP in this script + if i put something in wrong order tell me:
DGDecode_mpeg2source("D:\Work Hanbun no Tsuki ga Noboru Sora\Hanbun_no-Tsuki_ga_Noboru_Sora_01.DVD(MPEG2.WAV)[Misu]_Track1.d2v", cpu=0) setmtmode(2) dup() setmemorymax(1024) SmartFade(dgm=true) source = last backward_vec2 = source.MVAnalyse(isb = true, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) backward_vec1 = source.MVAnalyse(isb = true, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec1 = source.MVAnalyse(isb = false, delta = 1, pel = 2, overlap=4, sharp=1, idx = 1) forward_vec2 = source.MVAnalyse(isb = false, delta = 2, pel = 2, overlap=4, sharp=1, idx = 1) source.MVDegrain2(backward_vec1,forward_vec1,backward_vec2,forward_vec2,thSAD=400,idx=1) fluxsmoothST(5,5) fft3dfilter(sigma=0.8, bt=1, bw=32, bh=32, ow=16, oh=16, plane=4, dehalo=0, ncpu=2) ttempsmooth() #FastLineDarkenMOD(strength=16,thinning=0) #limitedsharpenfaster(Smode=4) #maa() gradfun2db(thr=1.2) crop (4,0,-4,0) Spline36resize(720,480) |
12th December 2008, 04:36 | #131 | Link |
Is Dup considered fairly dangerous to use? Like I want to use Dup(Threshold=2.1), does anyone see any problems this might cause with Anime? Like maybe rape mouths? Or is that unlikely to happen? Like for example I want to use Dup to fix frames like these: http://rapidshare.com/files/172566014/DupFix.rar.html 01 is the broken frame 02 is the next frame being dupped for 01. So 01 becomes 02 when using Dup. Thing I'm worried about is if Dup causes any problems with miscalculating mouth movement at a setting of 2.0 to 3.0.
12th December 2008, 17:30 | #132 | Link |
Sleepy overworked fellow
High threshold is more likely to introduce losses in motion fluidity (jerks (especially slow pans and zooms), small movements will disappear (mouth movement...), etc...)
There was an attempt at creating a motion adaptative dup function some time ago: Code:
# Dupped() by Corran # # This filter requires a YUV source. Use converttoyv12 if needed # before calling dupped() # # thresh = Used to determine when to delare a frame as new # Use stats=true to help determine the best value for your source # Lower number = more sensitive. (Default=16) # panthresh=1.7 This is used to determine when to consider a frame # part of a low motion scene. (Default=1.65) # stats = Enable/disable display of stats. (Default=false | Not shown) # (Last = last frame, this = this frame, next = next frame) # showme = Enable/disable display of video that most stats are # derived from. (Default=false | Not shown) # # Do not use with SetMTMode(). This function requires the frames to be # accessed sequentially. Instead, use MT() to mulit-thread on a per-filter basis. # # Example: # dupped(thresh=20,panthresh=1.7,stats=true,showme=true) function dupped(clip clip, int "thresh", float "panthresh", bool "stats", bool "showme") { global a = default(clip, last) global thresh = default(thresh, 16) global panthresh = default(panthresh, 1.65) global stats = default(stats, False) showme = default(showme, False) function replaceframe(clip clip, int oldframe, int newframe) { a = default(clip, last) trim(a,0,oldframe-1)++Trim(a,newframe,newframe)++trim(a,oldframe+1,Framecount(a)) } b = a #for later use with showme conditional (it isn't passed to scriptclip) global newframe = a a = scriptclip(a,""" b = a.duplicateframe(1) d = a.deleteframe(1) c = subtract(a,b) YMinMax = YPlaneMinMaxDifference(c) YAbvMed = YPlaneMax(c)-YPlaneMedian(c) YBelMed = YPlaneMedian(c)-YPlaneMin(c) YAbvBelMedDiff = Abs(YAbvMed - YBelMed) new = (YMinMax>=thresh || YAbvBelMedDiff>=10) YMinMax2 = !new ? YPlaneMinMaxDifference(subtract(a,d)) : 255 YMinMax3 = (YMinMax2<=thresh ) ? YPlaneMinMaxDifference(subtract(b,d)) : 255 pan = (YMinMax3 != 255 && YMinMax3!=0 && YMinMax3>=(YMinMax+YMinMax2)/2*panthresh) stats ? subtitle(a,"YMinMax(last,this) = "+string(YMinMax)).\ subtitle("YAbvBelMedDiff(last,this) = "+string(YAbvBelMedDiff),y=54) \ : a newframe = (current_frame<=1 || current_frame>=Framecount()-1) ? current_frame : newframe stats ? !new ? subtitle("YMinMax(this,next) = "+string(YMinMax2),y=18) : subtitle("YMinMax(this,next) = Null",y=18) : last stats ? (YMinMax3!=255) ? subtitle("YMinMax(last,next) = "+string(YMinMax3)+"|"+string(ceil((YMinMax+YMinMax2)/2*panthresh)),y=36) : subtitle("YMinMax(last,next) = Null",y=36) : last newframe = (new || pan) ? current_frame : newframe stats ? subtitle("Last New Frame = "+string(newframe),y=90) : last (stats && pan) ? subtitle("(Slow pan/zoom or action detected)",y=108) : last (current_frame != newFrame) ? replaceframe(current_frame,newFrame) : last return last """) a = showme ? stackvertical(a,subtract(b,b.duplicateframe(1))) \ : a return a }
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
12th December 2008, 19:01 | #133 | Link |
Insane Encoder
or if you want to not taking risk, use a low blksize (8 if possible)
so small movements are detected pretty well (a mouth move does about 4% IIRC) so you don't have any problem with the treshold = 3.0 and don't kill small movements
Only two things are infinite, the universe and human stupidity, and I’m not sure about the former. |
