8th January 2003, 23:11 | #41 | Link |
AC3 5.1 Addict
@FuPP
Thx for the reply. My experience is also exactly as you describe, just wanted to verify it.
Need AC3 & SPDIF setup info? |
9th January 2003, 22:26 | #42 | Link |
@neuron2
is it possible to let Dup write a log file which frames are replaced so you can easily check with vdub if there are frames that should not be replaced (for example the described situation with a guy walking far away)... Thank you... |
9th January 2003, 22:41 | #43 | Link | |
9th January 2003, 23:29 | #44 | Link |
@neuron2
Ohhh, Ok thank you. What about this idea: I don't know exactly how Dup is working but I as far as I know it's working on whole frame and if two (or more) frames have a difference less than a threshold the second frame is replaced by frame 1 (except for blend...). But in anime there are often parts of the picture that don't move (for example a person speaking and only its mouth is changing). So what is about partly "dupping" the frame. A simple way would be to divide the picture in submatrices, f.e. 3x5 or more, and use dup on each of them. A more complex method could require to detect motion, chroma and lumi changes and to mask the parts of the frame that are under a given threshold of a weight function f(motion[atPixel],chromachange[atPixel],lumichange[atPixel]), and then dup or blend-dup only these parts. Both of this would allow to go lower with the threshold values that have to be actually used and so perhaps our man on the horizon is walking again with a gain in compression in his pocket.... Thank you... P.S.: If Dup is working in this or a better way: don't hate me for asking silly questions.... Last edited by Ewi; 9th January 2003 at 23:32. |
10th January 2003, 00:05 | #45 | Link |
@Ewi
Thank you for your suggestion. The idea was already suggested on the main Dup thread. Search for "New duplicate detection filter". I am considering it but fear that it may fragment motion in an ugly way. @all I have released Dup 2.00, the first release version. It has several robustness fixes versus the last beta, and fixes a bug such that the blended frame wasn't used when show=true. It's a good idea for all Dup users to get this version. Please get it from my web site (the Avisynth 2.5 version). The source code is also available there. Thank you all for your valuable feedback during development. |
10th January 2003, 18:03 | #46 | Link |
XviD fan
lol, it'ld be a temporalsmoother ^^
>Now even MarcFD can't argue that Dup is useless. i still argue it's useless. your work is great, as always, don, it's all the fault of the dumb guy who had the idea ^_^. are you still using the same algo to detect movement, by searching the biggest mean difference in 32x32 windows ? because i've a new filter, with a similar approach, and i'd like to know the drawbacks ^^ Last edited by Marc FD; 10th January 2003 at 18:08. |
10th January 2003, 18:08 | #47 | Link | ||
13th January 2003, 23:37 | #51 | Link |
Retired AviSynth Dev ;)
@neuron: If you're interested, I've written a very fast ISSE routine that returns the largest accumulated sum of differences of a 32x32 pixel area on the entire image.
It processes 16 pixels in parallel, with less than 1 cycle per pixel, so it's probably maxed out at memory speed. It'll be committed to avisynth now, but it's not activated, because I'd like to reference test it, so it would be great if you could help there. It might actually not be useful for what I'm doing, but it's just an experiment. cvs sourceforge link see int TemporalSoften::isse_scenechange(const BYTE* c_plane, const BYTE* tplane, int height, int width, int pitch)
Regards, sh0dan // VoxPod Last edited by sh0dan; 13th January 2003 at 23:45. |
14th January 2003, 08:49 | #53 | Link |
Not entirely impossible - I can send you an offset x + (y*width/32) that should be enough. Pure luck I still have an mmx register, but I may need two to avoid memory reads, or stalls.
edit: cr*p I didn't have an mmx-register - not even a general purpose register. Couldn't you use the C-code, when show is true? I assume the C-code does exatly the same, so if you test the results, and see if they are the same, it would be pretty safe to use it. It could added to the code, but in real life there isn't anything time-critical, when show=true (ie. it's not an encode). Edit2: Wouldn't it make more sense, for it to be used as scene-change detector to add all the differences together and simply threshold-test this value. Edit 3: Just saw, that the code assumes that the pitch of both images is the same - not a good thing. I'll correct it.
Regards, sh0dan // VoxPod Last edited by sh0dan; 14th January 2003 at 14:44. |
15th January 2003, 18:18 | #54 | Link | |||
Thank you. |
24th January 2003, 14:16 | #55 | Link |
Good thing,
both protagonists are here ^^ (see below...) This code giving me avisynth error... It seems linked to cnr2() and dup() [edit : Cnr2 and not Dnr2, sorry for the typo ] I put the whole script cause it could come from other plugins used... Code:
source = avisource("...").killaudio() source = source.SwapUV() #used to correct somes frames before decomb fails on them... #note : frames 36 and 37 are KF but frame 36 is just baaaaad (mixing of 35 & 37) dest = source dest = dest.freezeFrame(36,37,37) #(...) some freezeframes too dest = dest.freezeFrame(36249,36250,36250) source = dest #ivcting cause raw is 29.76 fps (anime) Source = source.Telecide(chroma=true,dthreshold=13) source = source.Decimate(cycle=5,show=false,mode=2) #cropping evil baaaaad bar & resizing source = source.crop(0,2,628,478) source = source.BiLinearResize(640,480) #one of the two plugin alone works #but both together just won't work source = source.Cnr2("xxx",6,7,255) source = source.dup() #just to check the 1000 first frames in nandub ( or vdub) return source.trim(0,1000) dup() before cnr2() or cnr2() before dup() ...I m getting an "avisynth read error : AviSynth caught an access violation at 0x01651c17, attempting to write frame 0x00000000..." Any idea why, or how to avoid it, (I tried moving it before ivtc etc., but i haven't found a way to do not crash avisynth actually.) of course i can do cnr in vdub... But that just mean that cnr2 avs is useless for me in this case Versions I am using: AViSynth: 2.50 beta 22 jan. 2003 Decomb: Version 4.06 Dup: 2.00 ( took from the realm of Mordor ) Cnr2: Chroma Noise Reducer for AviSynth (v2.4) esby Last edited by esby; 26th January 2003 at 15:56. |
26th January 2003, 15:48 | #56 | Link |
@esby
You say dnr2() in one place and cnr2() in another. I assume you mean cnr2(). I put Dup() first in the script followed by a debug build of Cnr2(). It crashes in Cnr2(): Code:
PVideoFrame __stdcall Cnr2::GetFrame(int n, IScriptEnvironment* env) { if (n<1) return child->GetFrame(n, env); PVideoFrame src = child->GetFrame(n, env); if (lastn+1!=n || !pre) { pre = child->GetFrame(n-1, env); // CRASHES HERE !!! env->MakeWritable(&pre); } const uc *srcp = src->GetReadPtr(); uc *prep = pre->GetWritePtr(); ... So it appears to be a bug in the Avisynth core, maybe the cache. We need to get sh0dan involved. I will PM him to draw his attention to this thread. Last edited by Guest; 26th January 2003 at 15:56. |
26th January 2003, 20:31 | #58 | Link |
It's possible,
But as far i remember cnr2 alone or dup2 alone worked for the first frame processed. And both crashed together. I think i ended removing both, not satisfacted of the final result. (prolly cause dup blending mode not really good with some 'decombed' frames) esby |
26th January 2003, 20:56 | #59 | Link |
@sh0dan
I traced through Cnr's code and it crashes on the simple GetFrame() call for frame 0. I don't know how you can blame Cnr2. But by all means if you can think of a mechanism let me know and I'll look some more at it. Thank you. Last edited by Guest; 27th January 2003 at 18:24. |
27th January 2003, 17:21 | #60 | Link |
@neuron: Sorry - I thought you were listing the Dup-code (thus the crash would be in CNR2's GetFrame). I'll do a testsetup, and hopefully find it.
Regards, sh0dan // VoxPod |
