3rd January 2003, 21:12 | #22 | Link |
TotalEclipseOfTheBrain
@Donald+Shodan
hem, hem... Well, thanks a lot for your efforts, but I still have the problem both with avs 2.5 03/01 + dupyv12b2 or with Dupyv12b3. Here's my script (I could have start with that last time... ) LoadPlugin("C:\video\avsfilters\MPEG2DEC3yv12.dll") LoadPlugin("C:\video\avsfilters\dupyv12.dll") mpeg2source("f:\tests\vts_01.d2v",CPU=6,IDCT=2) Crop(8,4,704,568) Dup(threshold=5,maxcopies=10,chroma=false,show=true) BilinearResize(448,542) AddBorders(16,17,16,17) FuPP XP1800+, W2K |
3rd January 2003, 22:09 | #24 | Link |
Oh !
I've discovered that putting another filter (ex : convolution3d or... warpsharp ) after Dup make things works : it seems very similar to the problem I've reported to Sansgrip about fluxsmooth... Hope it can help. |
4th January 2003, 19:32 | #25 | Link |
@FuPP
Thank you for your results. I was indeed able to duplicate the problem using your script. Apparently the vi->IsWritable() is not reliable. I've temporarily removed the test of it in MakeWritable2(). The problem seems to go away. Please test with the attached beta 4 and let me know. @sh0dan Any comments about vi->IsWritable()? |
4th January 2003, 19:55 | #26 | Link | |||
4th January 2003, 22:03 | #28 | Link | |
5th January 2003, 10:39 | #29 | Link | |
Retired AviSynth Dev ;)
Another possible problem could be, that you read pitches _before_ making the image writable. Pitch might change when you make an image writeable. Could that be the cause?
Regards, sh0dan // VoxPod Last edited by sh0dan; 5th January 2003 at 10:49. |
8th January 2003, 19:23 | #31 | Link |
frame blending now supported
Here is Dup 2.00 beta 6.
It adds a requested feature: blend. When blend=true, the copy frame will be generated from an averaging of all the duplicate frames. This should give some noise reduction. Please read the help file for details. Of course, with blend=true, the filter will be slower. Now even MarcFD can't argue that Dup is useless. Feedback will be appreciated. Last edited by Guest; 8th January 2003 at 19:30. |
8th January 2003, 20:39 | #33 | Link |
You say that it should be fixed BOTH in the resizer and the application! How would we fix it in the application?
Also, I made the problem go away by removing the test for IsWritable() and its return in MakeWritable(), so that it always copies to a new frame. That doesn't seem to fit with the mechanism you are suggesting? Last edited by Guest; 8th January 2003 at 20:55. |
8th January 2003, 20:54 | #34 | Link |
What happends is that your filter returns frames with different pitches.
If you don't make all frames writable, but only some of them, it returns the source frame. If the source has been cropped right before your filter, it results in a pitch much larger than the image. When you make an image writable, a new frame is created, with a smaller pitch, and the image is copied to this frame. If you make all images writable the new pitch is consistent. But if you on some occations returns the same frame with a old pitch it causes an error in resize. I've corrected the error in resize. The easiest way for you to fix it is to create a new frame, and bitblit to it, if there are no changes - otherwise, just make _all_ frames writeable, no matter which frames are requested.
Regards, sh0dan // VoxPod Last edited by sh0dan; 8th January 2003 at 20:59. |
8th January 2003, 21:27 | #38 | Link |
I have tested b6, but only on a short clip (about 1700 frames). I will try to make more serious tests later in the week.
b6 is stable b6 without blend : gain in compressibility (mpeg2) : 4 % b6 with blend : gain = 5.5 % command : Dup(threshold=5,maxcopies=20,chroma=false,blend=true) Cheers, FuPP. Last edited by FuPP; 8th January 2003 at 21:31. |
8th January 2003, 21:47 | #39 | Link |
AC3 5.1 Addict
It's a free lunch so I couldn't resist
Has anyone been successful using Dup on clean progressive movies? Just curious more than anything.
Need AC3 & SPDIF setup info? |
8th January 2003, 23:01 | #40 | Link |
I've made some attempts a few weeks ago (with avs 2.0x compatible version); the filter did not detect subtle movements in still scenes (like a far character walking in the background), the movie got then jumpy.
But seems really efficient on animes ! Regards FuPP. |
