26th September 2013, 08:53 | #20121 | Link |
Kid for Today
Each time I made bug reports to the green force, it took them a while but they did get things done. I might as well buy an HD7950(same price as the 660 but with a 384bit memory bus) should they decide that it's not worth their time.
26th September 2013, 12:49 | #20122 | Link | |
It is time to move on. |
26th September 2013, 13:12 | #20123 | Link |
Kid for Today
Now that I think of it, a HD7950 seems a far better choice than the GTX660....384bit memory bus Vs 192. I think I remember madshi claiming that textures processing on AMD's was also quite a bit faster but this might have changed though.
The last 04/2013 XP drivers from AMD will work with anything up to the 7990 and resellers are currently getting rid of their outstanding 7000 boards as the R7/9 are bound to show up, a PNP 150€ 7950 sounds quite tempting No CUVID, though....but there's a bunch of highly efficient software decoders for AVC so all in all not a big worry. Anyway, it seems that whenever I mention XP in this thread things get emotional, I sincerely apologize to madshi for that. Last edited by leeperry; 26th September 2013 at 13:48. |
26th September 2013, 16:53 | #20124 | Link |
Trouble when using madVR in WPF application
I'm having some troubles when I use madVR as a renderer instead of EVR in my WPF application. The main problem being that when using madVR, it is somehow preventing the application to respond to mouse input (also keyboard input but not completely) This is how the whole thing is setup : a .Net 4 WPF application, with a main Window, in this window is a WindowsFormsHost control. This control does bridge WPF and Windows Form (so the message pump is provided by the WPF application) The WindowsFormsHost does host a Form whose only purpose is to provide the video window to the renderer (EVR or madVR) If I use madVR without taking care of threading issue, it totally locks the application and the directshow graph will never run (it builds though). So as I suspected a threading issue : I create a new thread (MTA) where all the graph building and handling is made (I have a thread dispatcher object to marshal call from the WPF UI thread to the directshow thread) So at this point the video window is on the WPF UI thread and the directshow graph is in its own thread. The directshow thread does not have an application message pump. This thread however is pumping events (and use ManualResetEvent.Wait(0)) so it should pump some events). At this point when using madVR, the directshow graph does start to playback but the application doesn't respond to input (keyboard / mouse) For the application to respond a little, I have to call a DoEvents() kind of code within my dispatcher loop (pushing a Dispatcher Frame). Then the application does respond to keyboard input (with some lag but not always) but mouse input is still dead... At this point I don't know what to do to make it work properly... Any ideas ? Thanks -- Stéphane. |
26th September 2013, 17:09 | #20125 | Link | |||
http://msdn.microsoft.com/en-us/library/windows/desktop/dd377323(v=vs.85).aspx |
26th September 2013, 23:50 | #20126 | Link |
Something I have noticed for a while, but never had the time to chase down the cause of, is that black level is always slightly raised when using madVR - it would never fade to black, and I had to reduce brightness by one or two steps further than should be necessary, sacrificing some shadow detail.
It turns out that the cause is madVR's dithering. Would it be possible to disable dithering for black, or maybe even the lowest 1% of the signal, rather than having to disable dithering entirely? Dither enabled: Dither disabled: I had to take some really long, high ISO exposures (30s, ISO 1,600) from the side of my TV for it to even show up in a photo, boosted to ISO 512,000 for clarity. Ignore the lights on the screen, that's just a reflection. |
26th September 2013, 23:56 | #20127 | Link |
Hi folks,
Do I need to restart the PC/notebook when changing levels using madNvLevelsTweaker? Has Nvidia addressed the RGB Full/Limited levels issue ( missing full-limited instant selection )? I dont have a Nvidia GPU to test it, sorry. Other question I need to get answer is - how much GPU intensive is 3D LUT processing on your GPU using madVR? Will this be a non issue on a Intel HD4400 and a i7 Haswell CPU? Thanks Peter
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
27th September 2013, 06:25 | #20128 | Link | |
Display Resolution Switcher
I update my OS (Windows 8.1 Pro), I have same problem again.
Intel Core i7-4790 CPU @ 3.60GHz, RAM 32 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24), Panasonic TX-P42G20E, NVIDIA GeForce GTX 970, Win 10 Pro x64, PotPlayer 1.7.16291 64-bit, madVR v0.92.17 |
27th September 2013, 10:02 | #20129 | Link | |
I can tell the LEDs at those zones are entirely turned off with the pitch-black dark zoom viewing condition -- if TV set's local dimming is turned on -- even with the strong backlight at 8 (of 10). I don't think this TV would turn off the backlit even there is only 1 slightly lighted pixel at any given local zone. |
27th September 2013, 12:21 | #20130 | Link | ||
So now with the message pump and a STA thread (sometimes a STA helps with some DirectShow filters) I'm still having the main window that is "frozen" at some time (will respond to keyboard / mouse input with delays or instantly...) I bet that the WindowsFormsHost is responsible but I can't see why it's happening neither what's madVR can be doing to eat the messages for keyboard / mouse input (and probably other) |
27th September 2013, 16:05 | #20131 | Link | |
When dither is enabled, a black signal is displayed as a mixture of 1 and 0, which activates the backlight at a very low level. It's still very dark, and was difficult to photograph at all, which is why I have the camera at a sharp angle to the TV like that. Any photos I took looking straight on at the TV were just black. If you're in a dark room and sit off to the side of the TV, you should be able to see it with the 920 as well, unless they have changed their local dimming algorithms, allowing it to clip the lowest signal levels. Or it may be that you have brightness set to a level which clips the lowest levels. |
27th September 2013, 17:33 | #20132 | Link | ||
I'm already using the madVR anti-ringing filter and it doesn't seem to reduce this problem. The issue also seems unrelated to the source as it's visible on all content. It seems that it isn't a madVR specific problem, but do you have any ideas what could be causing it? Last edited by Gagorian; 27th September 2013 at 17:36. |
27th September 2013, 19:34 | #20133 | Link | |
The anti-ringing filter can only reduce ringing caused by madVR's scaling algorithms. It will not remove ringing encoded in the source. You may want to try using some of the softer scaling algorithms such as SoftCubic (do not use the AR filter with it) or a player which has the option to crop the edges. (JRiver will do this) Last edited by 6233638; 27th September 2013 at 19:36. |
27th September 2013, 20:26 | #20134 | Link |
Hi guys,
a friend of mine cant get his madVR/MPC-HC/LAV/reclock setup right. He has an Core i7 desktop CPU, GTX780 GPU and gets this: http://img585.imageshack.us/img585/2907/0uxn.jpg We cant track down the reasons for the dropped frames. What else would you check? Thanks Pluto
27th September 2013, 20:41 | #20135 | Link |
If the number of dropped frames doesn't grow after it's first launched, it might simply be due to the switch to fullscreen. I always get a couple of dropped frames during the switch on my pc, but none whatsoever afterwards.
AMD Ryzen 9 5950X and EVGA RTX 3080 with G.skill 64Gb 3600 (2 16x2 kit) on Asrock X570 Taichi with Samsung 980 Pro 500Gb NVMe SSD running Win10 x64 on LG 34GN850-B 34.0" 3440 x 1440 160 Hz |
27th September 2013, 20:57 | #20136 | Link |
Its not windowed to exclusive switch. I think its something in the background that causes the frames go off, other apps maybe, because the playback should be fine according to the queues, they fill-up pretty well. The drops are slow but rather constant.
27th September 2013, 21:20 | #20138 | Link |
my friend copied these setting onto his setup:
http://www.mediafire.com/?y8x1s1u8et6s92w
27th September 2013, 21:34 | #20140 | Link |
Are you sure ReClock is actually doing its job properly?
Because it still says that it'll drop a frame every 30 seconds, if ReClock is functioning perfectly, that number should go way down to hours if not days.
