8th May 2006, 23:21 | #102 | Link | |
Software Developer
8th May 2006, 23:27 | #103 | Link |
Shaders are evaluated once for each destination pixel, so if you go fullscreen there is a lot more work to be done on the gpu. GPU drivers can wait for the gpu to complete rendering by spinning in a tight loop on a cpu, and this contributes to cpu use.
8th May 2006, 23:34 | #104 | Link | |
Software Developer
What about this: If playback was already started and I press stop and then play again, it will play immediately and *not* freeze. But once I open a new file, it will again freeze for about 15 sec. Seems like the Renderer needs to be re-initialized each time I open a new file. Is there a way to avoid that? Would be some improvement, because then I only had to wait 15 secs one time...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 8th May 2006 at 23:37. |
9th May 2006, 00:59 | #105 | Link |
i am still having a problem with playing dvd's with MPC + haali renderer. when i play the VOBs, or any file, it works fine. but when i open the dvd as a whole, mpc crashes after i try to seek
dscaler as the decoder. all is well when i change to overlay/vmr. this happens wit every dvd |
9th May 2006, 01:28 | #106 | Link | |
9th May 2006, 01:54 | #107 | Link |
retired developer
Works #1 on my X800XL 256MB. The more buffer I ask the more delay I get on start.
@flanger216 The decoder work at top speed to fill the buffer before the display start. @All Any way to get overlay video mirroring on ATI?
Detritus Software |
9th May 2006, 02:17 | #108 | Link | |
what's this for?
and of course use ffdshow for overlay...
latest mix sets: http://soundcloud.com/sill |
9th May 2006, 02:32 | #109 | Link | |
9th May 2006, 02:40 | #110 | Link |
retired developer
@sillKotscha
I don't have the .NET control panel. All I have is ATI Tray Tool. I did not find that option yet [edit] gonna get it
Detritus Software Last edited by Sirber; 9th May 2006 at 02:51. |
9th May 2006, 03:00 | #111 | Link |
retired developer
setting the same as you now, still no overlay
[edit] gonna extend desktop and fulslcreen manually then. no problem.
Detritus Software Last edited by Sirber; 9th May 2006 at 03:08. |
9th May 2006, 11:20 | #112 | Link |
Angel of Night
I have a little weirdness with Haali's. Half-D1 video (ye olde VHS) gets double-sized by the renderer, and then resized again when set to full screen. At least, I think it's resizing twice, because it looks aliased as hell, presumably the effect of bicubic's sharper resize. (Especially on low A values, almost looks like point sampling.)
(On the other hand, noticing finally got me to switch on ffdshow's resize. I don't suppose there's any way to do spline resize even partially in a shader...? So much better looking than normal kernel resizers.) |
10th May 2006, 08:07 | #116 | Link | |
Bored...
Bye |
10th May 2006, 08:40 | #117 | Link |
Angel of Night
That's referring to the chroma interpolation? No, this is on the luma channel also. I guess that A=0 actually is point sampling, so that kind of makes sense now, and once I thought about it I realized that two bicubic resizes would actually look a lot better than a single huge jump from 320x240 to 1280x1024 anyway (just try it in photoshop, the more resize steps the nicer it looks, although it thickens edges). It's that one huge leap that looks so nasty. So letting ffdshow resize partway under a certain resolution is probably the best way anyway, if you can spare the cpu power.
10th May 2006, 09:06 | #118 | Link | |
Bored...
Bye Last edited by Soulhunter; 10th May 2006 at 09:08. |
10th May 2006, 12:39 | #119 | Link |
Software Developer
@Haali:
I can playback verious files with only one time initializing the Haali Renderer. This is possible in Gaph Edit. Just keep the renderer on the graph, add new video and connect to existing Renderer. This way I have the "freezing effect", that happens when Haali Renderer is initialized, only one time, and *not* each time I play a new file. A great improvement for me. So I think this should be possible with Players like MPC too, eh? So is it the Renderer itself or a the player that needs to be updatet to support that feture? And if it's the renderer, did you ever think about adding this feature?
10th May 2006, 19:54 | #120 | Link |
I have the same problem with waiting time during starting playback. It's a period in which the CPU is used at 100%. I'd say the length of the wait time is proportional with the CPU one has and not anything else. My 2.4 GHz P4 shows signs of its age.
I have a Radeon 9700Pro (so, even older than the 9800Pro) and no matter what Catalyst driver I have used since the haali renderer appeared, this problem happened all the time. |
haali, haali renderer |
