5th September 2010, 08:58 | #9401 | Link |
Programmer (or just 教务长)
I think the solution is simple. In this case BD Rebuilder tries to re-encode the menu m2ts for title 13. It is one frame and just 500KB with IGS stream muxed with the video-frame.
I'm not sure if the hidden option "MIN_M2TS_SIZE=n" can help in that case. It is interesting that BD Rebuilder left menu m2ts for titles 1 to 12 intact, but decided to re-encode the 13th. Dean I'm not sure what that means and what is 'original' authoring. Last edited by deank; 5th September 2010 at 09:03. |
5th September 2010, 10:12 | #9402 | Link |
Wrong length in movie only
Now i had 2 movies where the length was too short (03407): Love Guru 34 Minutes against 87 minutes in the selected playlist.
And Beyond a Reasonable Doubt, after 63 minutes it was cut (originally 108 minutes). Any idea? [Status] VERSION=v0.34.07 (beta) SOURCE_SIZE=20783192064 SOURCE_VIDEO_SIZE=20783192064 TARGET_SIZE=49178214400 REDUCTION=2.3662493349703 RESIZE_1080=0 AUDIO_TO_KEEP= SUBS_TO_KEEP= BACKUP_MODE=1 MOVIEONLY_TYPE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=2 REBUILD_COMPLETE=1 [00029] USE_ORIGINAL=1 AUDIO=10 PGS=110 M2TS_TARGET=49178156247 NSIZE=7348414464 FLINK=0 MLINK=0 [00007] USE_ORIGINAL=1 M2TS_TARGET=58153 AUDIO= NSIZE=18432 FLINK=0 MLINK=0 Last edited by longtom; 5th September 2010 at 10:56. |
5th September 2010, 14:22 | #9404 | Link | |
5th September 2010, 15:00 | #9405 | Link |
Ok, Thanks.
Im running it in Parallels 5 with Win 7(OSX). Now i ripped it to HD, than encoded, fine now. But normally it's working right from the BD-Disc. Sometimes i see a problem with x264 but this is only when i resize. In this cases Video is not resized, only Audio from HD to DTS or AC3. |
5th September 2010, 16:13 | #9406 | Link |
@ Capsbackup, (Quote) Why not just create the entire project with multiAVCHD
Sorry, I was just posting I quess to see if anyone else had a similar prob. I usually just use multiAVCD when I am compiling a multiple title disc. Because of the complexity of the different ways to create and finish making a disc, I usually just create it and feed it to BD_Rebuilder because I only use multiAVCHD occasionally and it has so many transcoding options that I get lost, lol. I like to see what the finished disc is like (only 20 minutes later I might add, great job deank!) so I can correct any of the errors I have usually made before recoding it for 8hrs. I am just more comfortable with BD_Rebuilder in compressing for size having used it for the last year of so. I think both programs are great and would like to see maybe a hybrid of some kind that will allow keeping the original menu structure sort of intact and just removing all the other fluff that is on these disks. I use both programs and would be lost without either of them, and would hate going back to the command prompt only tools, doh! @jdobbs, (Quote) Is that the real volume label? I'm not sure, but I think the "*'s" are illegal -- at least for creating a filename. -The volume label is just me editing and hiding the title. ("I wouldn't be so paranoid if everyone wasn't out to get me." (Frank Burns) *** (Quote) BD-RB can only be aware of a HAALI error if it is passed back through AVISYNTH. -I just thought that with verbose checked that it would show all errors from all tools. ***What version of HAALI are you using? If it isn't the recommended one from the first post of this thread -- fix it. I recently tried the most recent one and ran into issues. -It is the recommended version but I think I will uninstall and delete all the BD_Rebuilder and tools folders and defrag and reinstall again. The last time I started having problems I did this and everything was fixed. thanks for the help, worknstiff @deank, (Quote) I think the solution is simple. In this case BD Rebuilder tries to re-encode the menu m2ts for title 13. It is one frame and just 500KB with IGS stream muxed with the video-frame. I'm not sure if the hidden option "MIN_M2TS_SIZE=n" can help in that case. --I just put in the statement about the numbering scheme because it sort of bothers me that when I put in 13 titles it numbered them starting with "00000". Sorry, but when I count something I always start with "1", lol. Anyway, after I reinstall everything I will attempt the same process again and if it still exhibits problems, I will try the "MIN_M2TS_SIZE=n" and let you know what happens. thanks for the help, worknstiff |
5th September 2010, 16:59 | #9409 | Link |
BD Rebuilder v0.34.08 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.34.08). Changes for this release:
- Added an option to the SETUP dialog that instructs BD-RB to use X264's internal LAVF decoder wherever possible (bypassing usage of HAALI and FFDSHOW). Also added the 64 bit version of X264 tothe TOOLS folder. That version will be used when LAVF is in effect and a 64 bit O/S is detected. This has been reported to improve processing speed depending upon the source stream type and number and type of processor cores. Note that some streams cannot currently be processed by LAVF, such as interlaced VC-1 or when filtering is in effect. In those cases BD-RB will automatically revert to standard FFDSHOW and AVISYNTH processing. It's suggested that you try it and if you like it, keep it checked. This feature has been implemented in preparation for possible future versions of X264 that may enable complete processing of video sources without additional "helper apps". - Corrected an error in which ABR mode could be set incorrectly at startup. - Completely rewrote the ALTERNATE output code. I've changed it so the types of output are defined in a ALTERNATE.TXT file in the MISC folder. This makes it easier to add additional formats in the future and to allow format definitions created by the user. - Updated ALTERNATE output dialog so two-pass output with selectable bitrate can also be used. - Corrected an issue in which BD-RB might incorrectly use original video when outputting to an ALTERNATE movie-only output selection. - Added a new general option to the SETUP dialog. You can now select "Keep only BDMV/CERTIFICATE folders" and BD-RB will strip the extraneous file from the backup (e.g. PS3 zips). This is especially useful for those to rip to ISO or read directly from the disc when doing full backups. - Corrected an error in which video streams could be incorrectly kept intact on movie-only AVCHD backups even when the CODEC is illegal (non-AVC). - Added a check for zero filelength after encoding. In some cases X264 does not seem to return an error code and BD-RB continues thinking an encode was properly completed when it was not. - Updated the included version of NicAudio.dll to the latest release (v2.0.4). - Updated the included version of X264.EXE to the latest release (r1713). - Added the 64 bit version of X264.EXE, r1703, to the zip package (renamed to X264-64.EXE). - Other minor corrections and cosmetic fixes. |
5th September 2010, 17:07 | #9410 | Link | |
I'll try to load some structures in BD Rebuilder and do some tests. There is nothing wrong with the structure and it is AVCHD compliant so there is no need to reencode 1frame 1920x1080p AVC menu files, not to mention IG which will break after a reencode/remux. |
5th September 2010, 17:35 | #9413 | Link | |
5th September 2010, 18:08 | #9414 | Link | |
However, if BD25 is set for the output size, these same MIN_M2TS_SIZE=1,5, 100, or 500 changes make the total files to be reencoded by BD-RB change, they are reduced accordingly. |
5th September 2010, 19:05 | #9415 | Link | |
5th September 2010, 19:19 | #9416 | Link | |
5th September 2010, 22:16 | #9419 | Link | |
Still image for menu (as one video frame) with a 'pause' flag is not the same as a slideshow... It is just a video frame... It can be 14 or 777 frames. Last edited by deank; 5th September 2010 at 22:19. |
6th September 2010, 00:29 | #9420 | Link | |
