Old 16th August 2012, 02:45   #61  |  Link
Thank you for being cretindesalpes.
Old 29th September 2012, 15:53   #62  |  Link
Motenai Yoda
Motenai Yoda's Avatar
hi!
There is a way to change the seed on scenechange?
I want try to use a different fixed pattern for scene.
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 11th January 2013, 14:20   #63  |  Link
Tanbheer
I have a question can I use this version 1.6.1 or 1.7 with GradFun2DBmod? Will it work like same. Because the link of the original version of Tom barry's 1.4.0 is dead
Tanbheer is offline   Reply With Quote
Old 11th January 2013, 16:32   #64  |  Link
cretindesalpes
cretindesalpes's Avatar
Yes you can.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 20th March 2013, 02:51   #65  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
cretindesalpes and LaTo, you guys are awesome. I added you to the first post.
Motenai Yoda, maybe, but it would be better done by having another filter find the scenes first. I'd have to think about a good way to do it.
Old 20th March 2013, 05:28   #66  |  Link
filler56789
SuperVirus
filler56789's Avatar
@foxyshadis: Thanks for the update
filler56789 is offline   Reply With Quote
Old 20th March 2013, 23:50   #67  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
Good to see you back foxyshadis!
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 12th April 2013, 20:38   #68  |  Link
Motenai Yoda
Originally Posted by Motenai Yoda View Post
hi!
I came out with
global seed=0
scriptclip("""global seed = ydifferencefromprevious() < 50 ? seed : seed+1
addgrainc(last,50,0,0.2,0.2,seed,constant=true)
Old 25th November 2013, 23:32   #69  |  Link
cretindesalpes
AddGrainC 1.7.1:
  • Added a 64-bit version. Compiled with MSVC 2012 (requires the 2012 runtime libraries)
Old 2nd March 2014, 18:52   #70  |  Link
ultim
AVS+ Dev
ultim's Avatar
Hi cretindesalpes,
AddGrainC cannot tolerate negative frame indices. Here is the description of at least one occurance where this causes a crash: https://github.com/AviSynth/AviSynthPlus/issues/38
Can you please have a look at that?
AviSynth+
ultim is offline   Reply With Quote
Old 2nd March 2014, 21:58   #71  |  Link
cretindesalpes
OK, I will look at this issue.
Old 9th March 2021, 11:34   #72  |  Link
pinterf
New build with packed RGB fix (e.g. RGB32)
- 1.8.3  2021/03/09
  Fix: possible crash for packed RGB formats
https://github.com/pinterf/AddGrainC/releases/
pinterf is offline   Reply With Quote
Old 9th March 2021, 21:41   #73  |  Link
real.finder
- 1.8.3  2021/03/09
thanks, is it possible to add soft and maxts to AddGrainC from Dither_add_grain16?
See My Avisynth Stuff
Old 10th March 2021, 08:57   #74  |  Link
pinterf
Dither_add_grain16 is not a plugin filter but a script in dither.avsi.
It's using AddGrainC, TemporalSoften, mt_lut, SelectEven, ConvertFPS (see Dither_gen_grain_internal), I think there is no point to put this very same sequence into a binary plugin.
EDIT: that means that a Dither_add_grain_hbd is needed which is based on Dither_add_grain16 in order to avoid the lsb hack and/or use high bit depth clips when calling AddGrainC.
Old 10th March 2021, 19:06   #75  |  Link
real.finder
you right, I think I will make a clone of it to do HBD
Old 18th February 2022, 23:43   #76  |  Link
kedautinh12
1.8.4 was released
