27th March 2018, 16:42 | #22661 | Link | ||
It's default. Doesn't mean it will always be better than other renderers.
(*): Quote:
27th March 2018, 17:28 | #22662 | Link |
The main reason why EVR gives better performance than EVR-CP is because it uses DXVA scaling.
You could try this setting for EVR-CP: Options > Playback > Output > Resizer > Bilinear (PS 2.0) Then it will use the GPU for scaling instead of CPU. |
27th March 2018, 18:04 | #22663 | Link |
Bilinear (PS 2.0) makes no difference.
Nobody using a Skylake-S (HD 530)? The settings should be the same for everybody, shouldn't it? This is just a workstation and all i need is that the videos play smooth without to much CPU usage. Video quality (madVR) is not that important on this machine. Oh and it's a 1080p Dell monitor... Edit: I tried the "madVR low-end preset for low-end GPUs such as Intel built-in GPUs" settings from LAV Filters Megamix (https://anime.my/tutorials/watching-...uda/#checklist) - which should be madVR default anyway. Dropped frames all over the place... Even on 4K H.264-AVC MPEG-4 [29.970fps][19Mbps][8bits]... Last edited by MrGlasspoole; 27th March 2018 at 18:46. |
27th March 2018, 21:14 | #22664 | Link | |
https://forum.doom9.org/showthread.p...34#post1837634 |
27th March 2018, 23:28 | #22665 | Link | |
27th March 2018, 23:42 | #22668 | Link |
Your files do not conform to the H.264 standard, because x264 4:4:4 lossless encoding was buggy, so you have to re-encode them if you want it truely fixed.
27th March 2018, 23:47 | #22671 | Link |
Hi444PP is a lossless profile, but I suppose one could use it without using lossless coding? But all the same anyway, you need to re-encode them to fix it forever.
28th March 2018, 00:11 | #22674 | Link |
Try with tomorrows nightly build (in ~3 hours or so), maybe that helps. Although you're screwed if you mix old and new files in one timeline, but who would ever do that.
28th March 2018, 00:12 | #22675 | Link |
https://nofile.io/f/NbE7BTMX2ZY/New+folder.torrent
That has ordered chapters. The OP and ED play fine since they don't have chapters, and the main plays fine if you remove the chapters. Though I just noticed that attempting to split the mkvs ruins what comes after the split. So it works fine with no ordered chapters, it'll stay fine through a complete remux, but if you add ordered chapters or split it it's now screwed. Last edited by kuchikirukia; 28th March 2018 at 00:17. |
28th March 2018, 00:19 | #22676 | Link |
If you split the file using mkvtoolnix only the first part will have the information about the x264 encoder revision used because x264 stores it in the front. That's why only the first part will play fine if you attempt that.
The other thing should hopefully be fixed with the nightly as nevcairiel said. I could also reproduce the issue - it was a bug after all. |
28th March 2018, 00:33 | #22677 | Link | |
I don't think I've ever done that so I should be good there. |
28th March 2018, 00:35 | #22678 | Link |
No, as long as the very first mkv file has the x264 information even the splitted parts should work fine as a part of ordered chapters with the upcoming nightly. But if you try to play the splitted parts by themselves (without the very first part/without ordered chapters) then it will not work correctly because LAV has no way of knowing an old x264 version was used.
28th March 2018, 22:10 | #22680 | Link |
Hi, i've recently noticed when the sound I get when I play a movie back using plex on my TV through my reciever amp sound loads better than when I play the same movie through any app on my HTPC, this isnt strictly a LAV filter issue I dont think but all my players are using LAV.
The sound coming from my TV is PCM DOLBY 5.1 PCM, from my PC its full digital bitstreamed and all shows up correctly on my amp dialog. I'm using standard HDMI audio from my AMD RX card. To me the audio sounds thinner, has quite a bit less weight as it far less immersive, I can hear my rears much more through plex and my TV, it all just sounds loads better. Can anyone hazzard a guess whats going on here, is there anything i'm missing using standard audio renderers in MPC-BE / HC / KOD? i'm defo getting proper 7.1 as I have test files and each speaker calls out, its just the mix PLEX is providing seems fuller and better. |
