10th December 2006, 13:15 | #41 | Link |
i realised what caused the button to not be clickable. it was placed on a wrong place!
when i click on it, it starts the movie as it should tough
10th December 2006, 19:50 | #42 | Link | ||
new version 0.1.1.8
mediainfo reads out the dimensions and the playtime of the video and if there is an video/audio track.
In this version you can choose if you want to use mediainfo or not (under "Tools/Standard Settings") Because I need some information of the video I use AviSyth, if mediainfo disabled, to get them and for long video it takes a lot of time. So be warned . Maybe I will find an other solution. Now it use a segmentDescriptor for every input. |
10th December 2006, 20:16 | #43 | Link |
thx, i will try it now
the best would be propably to fix mediainfo. i told zenitram about it here: http://forum.doom9.org/showthread.ph...951#post914951
10th December 2006, 20:18 | #44 | Link |
@Drachir: I'm not so familiar with BIFS so please post errors in the created script.
How many audio streams are useful? Is there also a way to define the track name. @bond: yes. thanks Last edited by IMOON; 10th December 2006 at 20:21. |
10th December 2006, 20:36 | #45 | Link |
ok, the button problem is fixed now
i set manually the world size in the project settings. i noticed that a custom dar is set automatically, why is that? when i set the dar to 1 (i think thats the default setting?) i noticed that the buttons are not placed correctly anymore (aka gone) i will try a more complicated menu now
10th December 2006, 21:45 | #46 | Link | ||
Teetrinker
Good question, I have some DVD which comes with about six audio language. As far as I know there is no way to set the handler name. May be you can ask Jean Le Feuvre to add this feature to MuxInfo http://gpac.sourceforge.net/doc_bt.php . For the handler name you will find this in 14496-12: Quote:
Play GO ( http://en.wikipedia.org/wiki/Go_(board_game)) |
10th December 2006, 23:07 | #47 | Link |
fantastic! i now tried everything (including switching subs (they are done as bifs text), switching audio, chapters, chaptermenu, languagemenu, subtitlemenu, small extra menu) but excluding intros/outros and everything worked fine in latest osmo4
actually i think using you gui is damn easy! to see the result try a sample yourself: http://www.megaupload.com/?d=TNU8SN6Z note that its obviously not the full movie, therefore only chapters 1-3 should work (meaning should seek in the movie) try latest osmo4 from here: http://home.wildit.net.au/celticdruid/mirror/gpac/dev/ note that when playing the sample in a normal directshow player with haali the normal movie is played next i will try intros/outros IMOON: - is it possible to make the menus selfrepeating, like in my old sample? - dunno if its easily doable, but when copying buttons it would be great if mp4menugui would remember that the buttons have been copied before and eg call them "buttonname_copy1", "buttonname_copy2" aso... that way people wouldnt need to rename every button when its copied more than once (very likely imho with chaptermenus) - also the option to keep the link action value when copying buttons might be useable (depends on the structure of the menu of course, eg if there are more 100% identical buttons or more different buttons at the same position) - osmo4 still seems to have the problem to seek exactly to a specified frame sometimes (not always!). i noticed this with my sample with the chaptermenus, which are single frames. i used to fix this problem in my old sample by adding 0.01secs to the position, so osmo4 seeks this 0.01 more than actually needed for the specified frame but therefore shows the wanted frame correctly. maybe you also want to consider to include this workaround (judging from the time gone since my first sample i dont think it will be fixed in osmo4 soon )?
11th December 2006, 14:13 | #48 | Link |
If you have a crash with MediaInfo.dll, please contact me at zen@mediaarea.net, we will work on it together.
Zen, developper of MediaInfo
Want to know all about your media files? http://mediaarea.net/MediaInfo |
11th December 2006, 15:22 | #49 | Link | ||
Teetrinker
PROTO TextAppearance [ exposedField SFVec2f position 0 0 exposedField SFNode text NULL ] Code:
TextAppearance { text DEF TXT Text { fontStyle DEF FONT FontStyle { size 12.0 family "SANS" style "PLAIN" justify ["MIDDLE"] } } } A sample can be found in the regression tests: http://gpac.cvs.sourceforge.net/gpac...bt?view=markup You can use a ttxt file instead of a srt file. There is a newer version of the 3GP timed text authorhing format ttxt out, to avoid problems with apostrophe. Code:
<?xml version="1.0" encoding="UTF-8" ?> <!-- GPAC 3GPP Text Stream --> <TextStream version="1.1"> <TextStreamHeader width="720" height="400" layer="0" translation_x="0" translation_y="0"> <TextSampleDescription horizontalJustification="center" verticalJustification="bottom" backColor="0 0 0 0" verticalText="no" fillTextRegion="no" continuousKaraoke="no" scroll="None"> <FontTable> <FontTableEntry fontName="Sans-Serif" fontID="1"/> </FontTable> <TextBox top="0" left="0" bottom="395" right="720"/> <Style styles="Normal" fontID="1" fontSize="30" color="ff ff ff ff"/> </TextSampleDescription> </TextStreamHeader> <TextSample sampleTime="00:00:00.000" xml:space="preserve"></TextSample> <TextSample sampleTime="00:00:00.914" xml:space="preserve">Studio Ghibli presents A FILM BY MIYAZAKI HAYAO</TextSample> <TextSample sampleTime="00:00:06.580" xml:space="preserve"></TextSample> <TextSample sampleTime="00:00:15.262" xml:space="preserve">In ancient times the land lay covered in forest...</TextSample> <TextSample sampleTime="00:00:19.130" xml:space="preserve"></TextSample> <TextSample sampleTime="00:00:19.232" xml:space="preserve">...where from ages long past dwell the spirits of the gods.</TextSample> <TextSample sampleTime="00:00:27.401" xml:space="preserve"></TextSample> <TextSample sampleTime="00:01:29.569" xml:space="preserve">Yakul!</TextSample>
11th December 2006, 18:36 | #50 | Link |
i dont think its supported. enviviotv should support asp and aac, but no avc (there used to be a h264 version on the net, but it doesnt seem to work/be compliant)
11th December 2006, 23:37 | #51 | Link | ||||||
may be it is better to make it like your old sample. Quote:
OK, I will post a future request |
13th December 2006, 23:47 | #52 | Link |
new version 0.1.1.8
Hello,
Changelog: Code:
- Fix seeking bug in Osmo by adding 0.01secs to the start position - Added option: keep the link action value when copying buttons of menus - Added basic language localization function for the program (language ISO Codes) - Added support LanguagesDiscriptor for audio and sub - Fix: Copy Button use unique name |
16th December 2006, 15:10 | #53 | Link |
when i try to store the global settings i get the following error:
System.InvalidCastException: Das Objekt des Typs MP4MenuGui.MP4MGSettings kann nicht in Typ MP4MenuGui.MP4MGGlobalSettings umgewandelt werden. bei MP4MenuGui.MainForm.mnuToolsStandardSettings_Click(Object sender, EventArgs e) bei System.Windows.Forms.MenuItem.OnClick(EventArgs e) bei System.Windows.Forms.MenuItem.MenuItemData.Execute() bei System.Windows.Forms.Command.Invoke() bei System.Windows.Forms.Command.DispatchID(Int32 id) bei System.Windows.Forms.Control.WmCommand(Message& m) bei System.Windows.Forms.Control.WndProc(Message& m) bei System.Windows.Forms.ScrollableControl.WndProc(Message& m) bei System.Windows.Forms.ContainerControl.WndProc(Message& m) bei System.Windows.Forms.Form.WndProc(Message& m) bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
17th December 2006, 17:58 | #56 | Link |
new version 0.1.2.0
Changelog:
- Bugfix save standard settings doesn't work - Include Movie Buttons (bugy) The buttons Change Audio and Subtitle work OK. The next and previous chapter buttons have a bug. The other buttons doesn't work for me, but it seems to be an generally problem on my system with the script function. See https://sourceforge.net/forum/forum....orum_id=327349 for more information. |
20th December 2006, 17:09 | #57 | Link | |
stupid
When I use the "normal" build from 23īth of July I can play my xvid mp4, but all x264 directly crashes. Does someone have an idea why this happens? thank you
cu Joe ------------------------ freedom is just another word for nothing left to loose |
23rd December 2006, 21:10 | #59 | Link |
0.1.2.2 - Change: Use up to 5 audio streams |
3rd February 2007, 11:52 | #60 | Link |
any news on this great tool? where is the crowd wanting to create menus? ^^
