28th August 2014, 23:35 | #27161 | Link |
I did reset all the settings and now its working again. Maybe after some years and a view updates that was needed.
But there is another thing i wonder. I have one file that is progressive but madVR says and handles it as interlaced. I thought only interlaced files can be treated wrong? So how to handle that? Turning of automatic interlacing in madVR and set a flac in every interlaced movie file name? But what happens then to discs? The other file that is funny is interlaced and madVR sees it as that, but MediaInfo says it is progressive. Does that mean that no software can tell you for sure what it is? |
28th August 2014, 23:36 | #27162 | Link | |
the HD 4000 can do smooth motion without a problem just check the rendertimes and make sure you use smooth motion with the highest possible refresh rate. there are a lot of "powerful" passive cooled GPUs these need a case fan: r9 270 (I got one of these) gtx 750 ti gtx 750 these may work without a case fan: r7 250 r7 240 gt 640 everything below this is normally slow for it's money but should work totally fine with basic scaling and SM. the gtx 750 ti and 750 are all easily available in germany but you need an active case cooler to be save. the 3770 can be cooled passive I did this my self a year ago. http://geizhals.at/de/palit-geforce-...-a1140063.html http://geizhals.at/de/palit-geforce-...-a1145866.html if you really need infos about hardware think about a new thread. |
28th August 2014, 23:40 | #27163 | Link | |
the decoder is giving this information to madVR. just make sure your deinterlacing settings are "if in doubt, deactivate deinterlacing" |
29th August 2014, 00:28 | #27164 | Link |
I made a test. If i change aggressive to auto in LAV then the video is handled progressive by madVR.
I uploaded it: http://skulltronics.de/uploads/DivX5...Madagascar.avi Nowhere i can find an answer what the right setting in LAV is in combination with madVR. |
29th August 2014, 00:54 | #27165 | Link | |
the most changed setting that make sense to change is the choice of a hardware decoder or no hardware decoder. |
29th August 2014, 01:53 | #27166 | Link |
What aggressive deinterlacing does is:
If any frame is flagged as interlaced, then assume that the rest of the video that follows is also interlaced (even if flagged as progressive). This option is mainly intended for dealing with incorrectly flagged streams. Better leave if at Auto like huhn said. Those two videos of yours might have some frames that were flagged as interlaced. That could explain the behavior. MediaInfo only analyzes a small part of the video, so it can't be accurate on mixed content.
MPC-HC 2.2.1 |
29th August 2014, 03:33 | #27167 | Link | |
But well, maybe with todays CPUs that can handle Hi10p or 4K-h264... I never locked at it this way - then madVR can use more from the GPU? Last time i locked at this stuff CPUs did not have the power to decode VC1, H.264, 1080pMPEG... But now this: If i set LAV to auto then another file shows the saw tooth edges (deinterlacing not working). But madVR says "deinterlacing on (says upstream)" Last edited by MrGlasspoole; 29th August 2014 at 03:58. |
29th August 2014, 04:46 | #27168 | Link | ||
no hardware decoder can decode 10 bit no amd GPU can do UHD. UHD is disabled by default in lavfilter. GPU can do only very little codecs and even if they can do them they only up to a level like h264 4.1 for AMD. Quote:
29th August 2014, 06:14 | #27169 | Link | ||
GPU driver? You mean Catalyst Control Center? Yes, i tried it with enabled and disabled. Another thing: The workload on CPU/GPU is linked to the total pixels of a video - right? 2048×1152 = 2.359.296px 1792×1344 = 2.408.448px Different width and high but almost the same amount of pixels. So the workload is the same? If thats the case it would be easier to make a script based on resolution if it would be possible to do math in the script. Something like: Code:
if (srcWidth * srcHeight > 2000000px) "FHD" The problem is that there are resolutions that are for example below "1920 width" but have a higher height. If i have for example a 3D 1920p movie, then the height is 2160... Also looking for >=1280 and >=720 does not really work cause if the movie is not 16:9 then the height is less. |
29th August 2014, 07:29 | #27171 | Link | ||
for gpu. a 720p video need a lot more processing on a 1080p screen than a 1080p file on the same screen. it depends on how much scaling is needed and the frame rate. useless for madVR. madVR can read all colorspaces lavfilter can output so this not used. |
29th August 2014, 16:05 | #27172 | Link | |||
if madVR says "interlacing on". But if i use aggressive then my other progressive file is recognized as interlaced by madVR. And then there is one file that works in EVR with aggressive and auto but not in madVR. So where is the bug - LAV, madVR or is it me? Behaviour: Quote:
http://skulltronics.de/uploads/Anixe-HD[1080i].ts http://skulltronics.de/uploads/Koreans[1080i].tp http://skulltronics.de/uploads/Madagascar[720p].avi Quote:
So the question is how to make the script intelligent enough to differentiate SD, HD, FHD... Thats the last thing i came up with: Code:
if (srcWidth < 1280) and (deintFps <= 30) "SD 24fps" else if ((srcWidth >= 1280) and (srcWidth <= 1919)) and (deintFps <= 30) "HD 24fps" else if ((srcWidth >= 1280) and (srcWidth <= 1919)) and ((deintFps >= 31) and (deintFps <= 60)) "HD 60fps" else if ((srcWidth >= 1920) and (srcWidth <= 2559)) and (deintFps <= 30) "FHD 24fps" else if ((srcWidth >= 1920) and (srcWidth <= 2559)) and ((deintFps >= 31) and (deintFps <= 60)) "FHD 60fps" else if ((srcWidth >= 1920) and (srcWidth <= 2559)) and (deintFps >= 61) "FHD 120fps" else if ((srcWidth >= 2560) and (srcWidth <= 3839)) and (deintFps <= 30) "QHD 24fps" else if ((srcWidth >= 2560) and (srcWidth <= 3839)) and ((deintFps >= 31) and (deintFps <= 60)) "QHD 60fps" else if ((srcWidth >= 2560) and (srcWidth <= 3839)) and (deintFps >= 61) "FHD 120fps" else if (srcWidth >= 3840) and (deintFps <= 30) "UHD 24fps" else if (srcWidth >= 3840) and ((deintFps >= 31) and (deintFps <= 60)) "UHD 60fps" else if (srcWidth >= 3840) and (deintFps >= 61) "UHD 120fps" I was looking on doing it with scrHeight rules. But there are so many variables... And sure, it is questionable if it is needed to differentiate on all that - but hey, if it can be done and who does use madVR if he not wants perfection |
29th August 2014, 17:30 | #27173 | Link | |
If a file needs even aggressive to deinterlace properly, then it is already broken. Any properly encoded file should deinterlace perfectly in Auto mode.
29th August 2014, 18:19 | #27174 | Link | |
I mean, you use profiles since you want to max out your GPU and image quality, but a lot of the low res combinations will have the same "maximum quality" settings and the high res combinations will have the same "maximum performance" settings with only a few different profiles between them, so it seems pointless to list all possibilities. Creating profile groups is also something to think over and set different rules for different settings. Chroma upscaling for example IMHO isn't that performance-heavy and I have it set based on resolution only - soft chroma upscaling (to hide artifacts) on SD and sharp chroma on HD and it works, unless you add highly compressed sources, like YouTube into the mix, but then filename/ext rules might come in handy. My rules are really minimalistic, to give an example with debanding: Code:
if (srcWidth>1920) or (srcHeight>1080) "deband off" elsif (fileName="*YouTube*") or (srcHeight<600) "deband high" else "deband low" As you can see I don't have >= and <= in one rule to make them less complicated and it works the same if the rules are in correct order. I also like to have the profiles named like the settings and not source quality/parameters, so a completely different approach to yours. So what I recommend is to create 2/3 (or more?) sets of profiles for different settings with the setting on/off or at low/med/high respectively and check the performance with the clips you have at hand - you can always add more rules, but why bother to later realize half of your rules point to exactly the same settings? That's how I've gone about it and I'm quite happy with the results. It did take me a while until I've finally set them and at some point I got so creative that I needed comments to mark what is what |
29th August 2014, 19:08 | #27175 | Link | ||||
I can do "Chroma up Jinc 3 (AR)" below 30fps but only "Lanczos 3 (AR)" above 30fps. Quote:
First you need to go through 100th of movies on your server. Second i like clean names "Jaws (1975).mkv" and not "Jaws (1975)[some][else].mkv" Third it does not work with iso's and disc's. Debanding is the cue. Is it normal that with low the rendering time is higher then with high. I also thought i use high only on SD and it takes more resources on FHD stuff. But if i set debanding to high on movies (no matter if SD, HD, FHD) i always have less rending time. And another question. I see people using Catmull-Rom+AR+LL most of the time for downscaling. Why not Bicubic 60+AR? Sharper, less aliasing, same ringing... I also think that SoftCubic 50/60+AR works better for SD (especially my old cartoon DVDs). But most of the time in tutorials its all about Jinc. Sorry for maybe stupid questions that are maybe already answered somewhere. But this thread is so long and often i don't find an answer. |
29th August 2014, 20:16 | #27176 | Link |
No video after installng madvr
I have installed latest mpc x86 and madvr. Everything seems all right, all filters run. But if i play movie only sound plays, no video. I have a win7 x64 with internal nvidia gpu and Pci Nvidia GT 610. is that a problem? Can't deactivate the internal gpu, allthough I dont use it. Windows wont start up properly. Thx, Novalis |
29th August 2014, 21:17 | #27178 | Link | ||||
Or your GPU might be entering power-saving mode, reducing clock speeds, hence increasing render times. Quote:
SoftCubic is nice for "old" sources, but be sure to check out the image doubling (NNEDI3) which is pure magic for low resolution sources, especially cartoons. Quote:
Get DirectX End-User Runtime Web Installer from Microsoft here. By no video do you mean black window or only a small seekbar, like you get when playing an audio file? Is madVR in the filters list in View->Filters menu? Can you see madVR's OSD (press CTRL+J to show/hide)? If yes, OSD's screenshot will help. Does it work with EVR or any other video renderer? If not, please move to correct/create new thread. |
29th August 2014, 21:50 | #27179 | Link | |
But now it's even worse. it runs a couple of seconds and then the complete system crashes an reboots. audio sounds ugly, choppy, thats all I can register before crash. That whole thing seems pretty unstable to me. Never had such a bad experience with other filters/decoders. |
29th August 2014, 21:57 | #27180 | Link | |||
I did set [deint=video] on the "Koreans" and it worked. Then i removed/disabled video mode and now it still works But the beach babes don't work - they only workout :-) Quote:
Would be nice if things like artifact removal and dithering where in one place with luma/chroma. The way it is now you need to make extra profiles in the categories where they are. Quote:
What about that Catmull-Rom+AR+LL vs Bicubic 60+AR? Why is Catmull preferred? Did you had codec packs on your system, did you experiment allot with other filters/codecs before on that system. Last edited by MrGlasspoole; 29th August 2014 at 22:02. |
