15th July 2007, 20:18 | #382 | Link | |
15th July 2007, 20:46 | #383 | Link |
[QUOTE=eas4uk;1024784]I've just tried 4.3 but that wont work either
There is a link for 4.3 below - but just a warning: I didnt post that so I cant verify the source (i just googled it and came across it) *link removed* This version seems to have helped my problem, but I think it's against the rules to post links like that. graphedit was very happy with this version. the only problem now is I have to use haali instead of the sonic hd demuxer to play in MPC because sonic demuxer breaks video and gives me green blocks all over. edit:sorry removed Last edited by SBeaver; 15th July 2007 at 21:03. |
15th July 2007, 21:12 | #385 | Link | ||
16th July 2007, 18:13 | #386 | Link |
Ok so im sure its my Sonic set up now as installed everything onto my laptop last night and tried it and it worked fine on there...
So why wont it work on the PC after I uninstall and reinstall - is there some registry settings that I need to delete after the uninstall to completely wipe it from the system??? |
18th July 2007, 22:18 | #391 | Link | |
The problem is still here! So, after some head scratching, I deregistered the dtsac3source.ax file I'd previously registered when installing everything, and presto! Sonic is working again! Edit: spoke to soon - D'oh forgot I need that filter to convert eac3 to ac3 - Anybody know why this filter is giving me grief then - Sonic wont work after I reinstall so its definitely this Last edited by eas4uk; 18th July 2007 at 22:36. |
19th July 2007, 02:37 | #392 | Link |
Hi Madshi,
I'm glad that I have found this tool from here. I tried it by using command line "eac3to source.eac3 target.ac3", but got error message "Parsing of Dolby Digital headers failed". I'm a newbie, I don't know what the problem is and how to solve it. The eac3 file was extracted from a mkv video using mkvextract.exe ("mkvextract tracks xxxx.mkv --raw 2:xxxx.eac3"). I'm using Windows XP Sp2, and have "Sonic HD Demuxer", "Sonic Audio Decoder 4.2" and "Dump" filter installed. Thank you! |
20th July 2007, 16:39 | #394 | Link | |
Madshi - How would I go about using Orbitlee opposed to Sonic btw? |
21st July 2007, 10:15 | #396 | Link | |
WVC1 Video, FLAC Audio...Perhaps EAC3 cant be used anymore too, after demuxing I will try it EDIT I found a working Way how to demux EAC3 from mkv. Use Avimux 1.17.7 Select "extarct Binary" and you will get a full working EAC3 Last edited by ACrowley; 21st July 2007 at 10:23. |
21st July 2007, 14:37 | #397 | Link | |
Thank you for the information. I'm newbie in this area and learning. I will try Avimux. Last edited by topace1; 21st July 2007 at 15:09. |
22nd July 2007, 08:55 | #399 | Link |
can somebody just summarize all the above?
like: 5.1 TrueHD track -> nero filters(all version?) -> DRC applied, not recommended 5.1 TrueHD track -> sonic filters(version?) -> noise, only 2.0, not recommended 5.1 TrueHD track -> no possible conversion without DRC 5.1 DD+ track -> nero filters(all version?) -> DRC applied, not recommended 5.1 DD+ track -> sonic filters(version?) -> perfect output 5.1 DD+ track -> sonic filters(version?) are highly recommended ? or at least can somebody pls correct/finish my example? Thank you! |
22nd July 2007, 10:14 | #400 | Link | |
- Nero Audio Decoder 2 (NeAudio2.ax) - Nero File Source Async. (NeFileSourceAsync.ax) - Nero Splitter Filter (NeSplitter.ax) all 3 files from the same Nero version has same versions: 1) 4.9.4.1 (Nero version 7.8.5.0) 2) 4.10.5.0 (Nero version 7.9.6.0) 3) 4.11.3.1 (Nero version 7.10.1.0) all versions of Nero filters, behave exactly the same with MLP and TrueHD tracks Sonic filters: - Sonic HD Audio Decoder (CinemasterAudio.dll) - Sonic HD Demuxer (SonicHDDemuxer.dll) 0) CinemasterAudio.dll v4.2.0.102, SonicHDDemuxer.dll v4.2.0.61 1) CinemasterAudio.dll v4.2.0.840, SonicHDDemuxer.dll v4.2.0.59 2) CinemasterAudio.dll v4.3.0.151, SonicHDDemuxer.dll v4.3.0.73 3) CinemasterAudio.dll v4.3.0.169, SonicHDDemuxer.dll v4.3.0.89 0) is from "Sonic CinePlayer HD-DVD Decoder v4.2" and as far as i know is the first version capable of DD+ decoding, but can't decode MLP and TrueHD tracks 1) is from "Sonic CineVision v1.2" 2) is from "Sonic CineVision 2.0.2beta" 3) is from "Sonic CineVision 2.0.2final" all 1)-3) can decode MLP and TrueHD tracks 5.1 TrueHD track -> Nero filters, all versions -> DRC applied, not recommended MLP track in EVOB -> Nero filters, all versions -> perfect output raw MLP track -> Nero filters, all versions -> doesn't work 5.1 TrueHD track -> Sonic filters, versions 1)-3) -> noise, only 2.0, not recommended MLP track in EVOB -> Sonic filters, versions 1)-3) -> perfect output raw MLP track -> Sonic filters, versions 1)-3) -> perfect output 5.1 TrueHD track -> no possible conversion without DRC MLP track in EVOB and raw MLP track -> perfect output is possible i don't have experience with DD+, so someone else should tell. Last edited by xkodi; 22nd July 2007 at 10:16. |
eac3to |
