Old 3rd January 2010, 14:03   #3981  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
There is a serious problem with the encoding quality of the X264 encoder (x264.exe) included in the latest full download.
Please download this one (400kb ZIP) and unzip it in multiAVCHD\tools folder.
Old 3rd January 2010, 20:36   #3982  |  Link
deank
deank's Avatar
Build 723:
* Reverted x264.exe to r1336M
* Fixed rc-lookahead in HD-DVD transcoding mode
* Fixed all transcoding profiles (no weightp, no mbtree, etc.)
* Importing of AVCHD or Blu-ray structures is now much faster
* Added Czech translation (mlf file) by Radek Kříž - 2010 - "Any mistakes reserved"
* Fixed Romanian language id to "ron"
* Fixed a crash when importing structures, which have improper/added files in certain locations (like PLAYLIST folder)
* Fixed a crash when importing (network/USB) folders/files which don't exist (media disconnected)
* A lot of other small fixes and improvements
Transcoding profiles fixes are also applied to uncropMKV. You can get the .exe here, but make sure to update your x264.exe with the one from the post above (or download and unzip it to tools folder).
Dean
Old 3rd January 2010, 20:43   #3983  |  Link
Mtz
Mtz's Avatar
Thank you for all explanations. Long time not used multiavchd and many things changed in a good way. I found something interesing on my TVIX 6500. BR made with multiavchd have menu played in the same way like tvix is doing for avchd.
Mtz
Mtz is offline   Reply With Quote
Old 3rd January 2010, 23:12   #3984  |  Link
setarip_old
setarip_old's Avatar
@deank
Hi!
In which build was this problem first introduced?
setarip_old is offline   Reply With Quote
Old 4th January 2010, 00:23   #3985  |  Link
deank
deank's Avatar
It think it has something to do with 2passHQ not working as you remember. For some reason x264 would use rc-lookahead of 19 frames when only 14 are in a GOP... I believe it is caused by a bad x264 build (patched). Probably doesn't affect the playback quality in any way, but I wanted it to be correctly set to 14 frames.
Also all one and two- pass modes now work for HD-DVD transcoding. I checked them before the fix (some wouldn't work - just grey, green blocks and stuttering) and after the fix (all okay).
Weight prediction for P frames is disabled now and also mbtree is set to "no" for 2 pass modes. This eliminates all problems which I knew of. It is important to use the version of x264 which I posted in the previous post. Probably the problem appeared after build 716-717 with the change of x264.
Old 4th January 2010, 03:38   #3986  |  Link
setarip_old
Thank you for the information.
Don't worry, I won't ask you about HDDVD chaptering - OOPS ;>}
Old 4th January 2010, 15:34   #3987  |  Link
hoju3508
Thank you for a very nice program.
While watching the movie, I wanted to return to the main menu by hitting the menu button on my Sony's BDP-S350, but it doesn't do anything. Is this normal? I only get the menu when I load the BD-R for the first time.
-Hoju
hoju3508 is offline   Reply With Quote
Old 4th January 2010, 15:42   #3988  |  Link
deank
deank's Avatar
Do you have other buttons like 'return' or 'options'... It should go to the main menu.
Old 4th January 2010, 16:48   #3989  |  Link
Music Fan
Maybe "top menu" (like the Panasonic players) ?
Music Fan is offline   Reply With Quote
Old 4th January 2010, 17:19   #3990  |  Link
drelin
-Hoju
With "Top menu" button, you can access to the last menu page.
If you press 2sd time to "top menu" button, you come back on the last access movie read.
tested on my Sony's BDP-S350.
drelin is offline   Reply With Quote
Old 4th January 2010, 19:45   #3991  |  Link
hoju3508
it worked with "Top menu".
Old 4th January 2010, 23:46   #3992  |  Link
rotty
b723
Originally Posted by deank View Post
Build 723:
* New "Sub path" tab in "Title properties"
Dean
Hi Dean
Just tried this build, replaced x264 exe with the one here, still takes longer than b717 to transcode 2 pass HQ. Here is the difference on the 2 passes, Pass 1, about 5% longer, Pass 2, 4 times longer.
rotty is offline   Reply With Quote
Old 5th January 2010, 09:14   #3993  |  Link
deank
deank's Avatar
What kind of content were you testing with? 1920x1080 or 1280x720?
Old 5th January 2010, 14:59   #3994  |  Link
rotty
content
Hi Dean
It was 14 seconds of blu ray movie only 1920 x 1080p.
Old 5th January 2010, 15:45   #3995  |  Link
defender
Hallo,
by *.ts or *.m2ts not supportly from 4.0 to 4.1
by *.mkv its okay.
Sorry, I'm can't speak english.
defender is offline   Reply With Quote
Old 5th January 2010, 16:43   #3996  |  Link
deank
deank's Avatar
Level (4.0 or 4.1) is just a flag in the stream. It doesn't actually make a stream compliant, although PS3 sometimes would accept 5.0 flagged as 4.1.
I'm not sure what your question is, but during remuxing the flag is set to 4.1 if user set that in Video group-box.
Old 5th January 2010, 17:53   #3997  |  Link
defender
Okay, I have a dvb stream with Level 4.0 like *.ts-file and would like to make a AVCHD-Disc (Level 4.1).
The problem is that the program multi-AVCHD, "Force AVC/H.264 level 4.1 flag" is not functionally like *.ts-files. (after making AVCHD-Disc the Disc-Menu is in level 4.1 and the film is in level 4.0 and not in 4.1!)
Old 5th January 2010, 21:45   #3998  |  Link
rotty
video-group
Hi Dean
Ive seen the "force 4.1 flag" option but where is the "video-group" box
Old 6th January 2010, 01:14   #3999  |  Link
deank
deank's Avatar
Author TAB, 4th option in the VIDEO&CHAPTERS box @ left bottom.
Old 6th January 2010, 15:21   #4000  |  Link
rotty
Video group
Hi Dean
Had seen that but was confused by the term "video group box" you spoke of in reply before.
So am I right in saying that the force 4.1 flag option is what you meant as option in "video group box"
