8th November 2009, 15:07 | #9061 | Link | |
http://roundup.ffmpeg.org/roundup/ffmpeg/ |
8th November 2009, 16:32 | #9062 | Link | |
There is some kind of little 'hop' at the start but after that it's playing fine. Also the file is using variable frame rate mode, maybe that's the reason of the troubles ? Code:
Frame rate mode : Variable Frame rate : 29.212 fps Minimum frame rate : 7.442 fps Maximum frame rate : 31.120 fps That's on XP 32 bits Radeon 9800 Pro ffdshow-20050303-sse (the very latest SSE build from Milan Cutka! ) MPC-HC 1.2.1043 using the built-in splitter Last edited by Brazil2; 8th November 2009 at 16:37. |
8th November 2009, 17:05 | #9063 | Link |
Media Control author
new FFDShow HD bitstream beta build This new build adds the following feature : testing several subtypes if the official one fails. This should bring bitstream support to the xonar. I didn't change the bitstream code yet Damien |
8th November 2009, 17:25 | #9064 | Link | |
Kid for Today
PS: hah, live.com/gmail.com/lavache.com appear to never get any confirmation from their bots..oh well, it's open source but closed group I guess Last edited by leeperry; 8th November 2009 at 17:29. |
8th November 2009, 17:30 | #9065 | Link | |
8th November 2009, 18:06 | #9066 | Link | |
When you say bitstream, are you hoping for DTS-HD as well? Cheers |
8th November 2009, 18:18 | #9067 | Link | |
Could you explain what you use for bitstream ? If i use MPC-HC ffdshow Audio don't start. If i make GRF with graphstudio, i can play but no sound and no light comes on. Did we use MPC Audio Wasapi Renderer (i think yes lol). So this is the log and Screenshot of my Graphstudio : And Log Debugview release Beta29 Thanks for all Seb.
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. |
8th November 2009, 20:11 | #9069 | Link |
A.K.A Mangoat
Ok, so using the latest ffdshow bitstream pack & MPC Audio renderer, I get no sound on anything except regular ac3 which is fine.
The files don't play at all and the debugview logs keep going as long as MPC is active. Will pastebin the logs for each soon. |
8th November 2009, 20:47 | #9071 | Link |
For this one the goal is just to make the connection accepted by the audio driver for the xonar (not for 4xxx series yet).
There is a new "try mode" that will for bitstream formats try several media types. Maybe this will also make DTS-HD work You won't get more sound that with sebastii tests but I just need the logs (debugview) to confirm or not the connection. What's next : I have to analyze sebastii's last logs, and reproduce as much the bitstream, then the work will be finished on FFDShow's side. Then the last part : the MPC audio renderer implementation, which must not be correct (buffer size, buffer feeding) otherwise you would get some sound. Be patient, this takes a lot of time, and most of us have a job in parallel (besides I spent some time lately on Media Control) Last edited by albain; 8th November 2009 at 21:03. |
8th November 2009, 21:04 | #9072 | Link |
No problem on my side, albain, with the patience thing. You've put a remarkable amount of time and effort into this and it's very appreciated! Take your time. I'm sure it'll come. I'm hoping my work schedule slows down after tomorrow so I can do more testing. It's been crazy the past couple weeks. So, I fully get the real world stuff getting in the way concept. I hope others understand, as well.
8th November 2009, 21:08 | #9073 | Link |
Oh my....
@Sebastii : the audio renderer you got is buggy. Please use this one @Sebastii : can you also test a TrueHD stream with this audio renderer (the buffer has been resized) MPC audio renderer with TrueHD buffer size Thanks ! You should see the light again on your receiver Last edited by albain; 8th November 2009 at 21:24. |
8th November 2009, 21:23 | #9074 | Link |
A.K.A Mangoat
Albain, I have no issue with being patient at all either, I'm very grateful for your time and effort and will continue to help in any way I can. I've seen it exactly as you describe - an attempt to connect several times. Here are the logs for you:
TrueHD: http://pastebin.com/f4f0f2692 DTS-HD: http://pastebin.com/f5a30e648 DDplus: http://pastebin.com/f2d1bb3f0 LPCM: http://pastebin.com/mf03c6f5 AC3: http://pastebin.com/f2995de44 Thank you as always. |
8th November 2009, 21:26 | #9075 | Link | |
This explains why you guys don't get any light and sound. Sorry for that Please use the link in previous post |
8th November 2009, 21:36 | #9076 | Link |
MPC-HC Project Manager
May i suggest donations of cash or hardware to albain?
This would speedup this research a 100fold the Onkyo TX-SR607 is about 400 euros and supports all the formats we are testing Hdmi cable is about 10-20 euros 5xx0 card is about 120 euros Xonar is about 130 euros
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
8th November 2009, 21:37 | #9077 | Link | |
A.K.A Mangoat
I will try shortly and post back the traces for you. |
8th November 2009, 22:38 | #9078 | Link |
A.K.A Mangoat
TrueHD: http://pastebin.com/f773f1256 - Sound but in PCM, started to stutter about 70 seconds in.
DTS-HD HR: http://pastebin.com/f4dedbb2 - No Sound, file played fine LPCM: http://pastebin.com/f7b18c985 - played in PCM DDplus: http://pastebin.com/d6399a732 - played in PCM AC3: http://pastebin.com/f6ecf0699 - played video, no audio. Likely a setup issue, as changiong from Asus Speakers to Asus Spdif device in Windows audio mixer gave the following: AC3 2: http://pastebin.com/f4d374802 - played fine, DD showed up on avr. If albain sets up a Paypal or similar I will happily send something over. |
8th November 2009, 22:58 | #9079 | Link | |
Posts: n/a
The only route, and this is what Intel, nVidia and ATI engineers are doing, is to purchase and test several different receivers. In any case, the Denon 1610 (caveat from first paragraph still applies) could do the job and can be had for as low as 315 EUR. A quality HDMI cable can be purchased from Amazon for about 5 EUR. |
8th November 2009, 23:27 | #9080 | Link | |
@Skinleech : thanks, it is better with the new renderer, but your logs seem incomplete. Can you check ? Last edited by albain; 8th November 2009 at 23:31. |
