11th July 2007, 13:48 | #2581 | Link | |
11th July 2007, 14:14 | #2584 | Link |
HDConvertToX author
that's right!
tell me when finished about quality BHH P.S. the same profile in next update will lead to more quality!
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
11th July 2007, 17:22 | #2586 | Link |
Quality is excellent now but problem is that AVI file is now 2.25 Gb in size and according to my media player it can not process files over 2 Gb filesize becouse AVI files are not supposed to be bigger then 2 GBs. Is there an option while have unlimited size to cut those into CD size chunks?
11th July 2007, 19:30 | #2587 | Link | |
HDConvertToX author
the unlimited is ulimited...
but i take your suggestion for a future approach BHH
12th July 2007, 03:30 | #2589 | Link |
Here my 4.1 HP level (should be ready for the PS3. I never had trouble running them with theses settings.. )
<?xml version="1.0"?> <VideoProfile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <Name>PS3</Name> <Settings xsi:type="x264Settings"> <EncodingMode>4</EncodingMode> <BitrateQuantizer>1000</BitrateQuantizer> <KeyframeInterval>300</KeyframeInterval> <NbBframes>3</NbBframes> <MinQuantizer>10</MinQuantizer> <MaxQuantizer>51</MaxQuantizer> <Turbo>false</Turbo> <V4MV>false</V4MV> <QPel>false</QPel> <Trellis>1</Trellis> <CreditsQuantizer>40</CreditsQuantizer> <Logfile>.stats</Logfile> <CustomEncoderOptions /> <FourCC>1</FourCC> <Zones /> <MaxNumberOfPasses>3</MaxNumberOfPasses> <NbThreads>1</NbThreads> <NoDCTDecimate>false</NoDCTDecimate> <PSNRCalculation>false</PSNRCalculation> <noFastPSkip>false</noFastPSkip> <NoiseReduction>0</NoiseReduction> <MixedRefs>false</MixedRefs> <X264Trellis>0</X264Trellis> <NbRefFrames>3</NbRefFrames> <AlphaDeblock>0</AlphaDeblock> <BetaDeblock>0</BetaDeblock> <SubPelRefinement>5</SubPelRefinement> <MaxQuantDelta>4</MaxQuantDelta> <TempQuantBlur>0</TempQuantBlur> <BframePredictionMode>3</BframePredictionMode> <VBVBufferSize>-1</VBVBufferSize> <VBVMaxBitrate>14000</VBVMaxBitrate> <METype>2</METype> <MERange>16</MERange> <MinGOPSize>25</MinGOPSize> <Profile>1</Profile> <Level>4.1</Level> <IPFactor>1.4</IPFactor> <PBFactor>1.3</PBFactor> <ChromaQPOffset>0</ChromaQPOffset> <VBVInitialBuffer>0.9</VBVInitialBuffer> <BitrateVariance>1.0</BitrateVariance> <QuantCompression>0.6</QuantCompression> <TempComplexityBlur>20</TempComplexityBlur> <TempQuanBlurCC>0.5</TempQuanBlurCC> <SCDSensitivity>40</SCDSensitivity> <BframeBias>0</BframeBias> <Deblock>true</Deblock> <Cabac>true</Cabac> <WeightedBPrediction>true</WeightedBPrediction> <AdaptiveBFrames>true</AdaptiveBFrames> <BFramePyramid>false</BFramePyramid> <BRDO>true</BRDO> <biME>true</biME> <ChromaME>true</ChromaME> <P8x8mv>true</P8x8mv> <B8x8mv>true</B8x8mv> <I4x4mv>true</I4x4mv> <I8x8mv>true</I8x8mv> <P4x4mv>false</P4x4mv> <AdaptiveDCT>true</AdaptiveDCT> <Width>false</Width> <Sar>false</Sar> <aqtcplx>false</aqtcplx> <deadzone-inter>false<deadzone-inter> <deadzone-intra>false<deadzone-intra> <SSIMCalculation>false</SSIMCalculation> <Interlaced>false</Interlaced> <Lossless>false</Lossless> <QuantizerMatrix /> <QuantizerMatrixType>0</QuantizerMatrixType> </Settings> </VideoProfile> |
12th July 2007, 12:15 | #2590 | Link |
HDConvertToX author
@survivant
no need for 3 pass, 2 pass is enough (and automkv support 2 pass ... no more) BHH
12th July 2007, 13:10 | #2591 | Link |
@buzzqw I know that 2 passes is enough just want to know is the tag was used.
a new suggestiona. #1 You have the option :AVS check and FFMPEG. you should set check AVS by default. That don't make sense to encode a movie if there are errors. The popup is OK. If the guy selected FFMPEg : using when x286 failed.. You have an error.. the guy could encode with ffmpeg because he choose it. In my case, I don't want to.. so stop there. #2 The option Prepare only and pause before encoding. If you selected prepare only.. the pause before encoding should be disabled. |
12th July 2007, 23:43 | #2592 | Link |
Learning To Fly
@buzzqw
Could a multiple filters option be added in the future? It would be very useful to me coz sometimes i want to pass more then one plugin in some dvds. Btw, excellent work with AUTOMKV!!!
AutoMKV - The New Alternative to AutoGK with X264 and MP4/MKV Last edited by Unrealbr; 13th July 2007 at 00:12. |
13th July 2007, 03:17 | #2595 | Link |
Brazilian Anime Ripper
I am trying to convert a avs with xvid in AutoMKV with default profile. The first step (audio part) is OK but when video encoding start automkv load x264 instead xvid_encraw.
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
13th July 2007, 06:35 | #2596 | Link | |
warpsharpened
Yes thats true.
If you wanted to chain it, it would be like this: Code:
degrainmedian(mode=1).LimitedSharpenFaster().anotherfilter().anotherfilter().etc() If you wanted to really use multiple filters. Break out the base.avs file present in your automkv/exe/filters folder. Just throw them under #test5 like this: Code:
#test5 a=last b=a.degrainmedian(blah) #please don't use blah SeeSaw(a,b, blah...) As of now, those are the only two ways to use multiple filters. I use the second one so much I just keep a shortcut of base.avs on my desktop . Code:
--QMLF1_3_motions Quote:
Cya |
13th July 2007, 09:19 | #2597 | Link |
There is something really wrong with NicMP4Box.exe. When it's launched it's just fills up HDD untill it's empty. See log below and screenshot showing NicMP4box.exe is not stopping at 100% and continuing past 100 for whatever reasonhttp://www.divshare.com/download/1246166-ce3
08:32:50 0.86 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 08:32:50 Selected Input file: C:\the.lake.house.2006.1080p.bluray.x264-gold.mkv 08:32:50 Selected Output dir: C:\temp\ 08:32:50 Selected Final Name: the.lake.house.2006.1080p.bluray.x264-gold 08:32:50 Selected Container type: MP4 08:32:50 Selected Encoder: XviD 08:32:50 Selected Size: 1 CD 08:32:50 Selected Slice: 1 08:32:50 Selected Profile: Constant_Quality.xml 08:32:50 Selected Width: Original 08:32:50 Selected Resizer: NONE 08:32:50 Selected Filters: RemoveGrain(mode=2) 08:32:50 Selected Deinterlacer: AUTO 08:32:50 Selected Field Order: AUTO 08:32:50 Enabled CRF/CQ AutoRes at 2.5 value 08:32:50 Using Matrix: Sharktooth's EQM v3LR.cqm 08:32:50 Track Language 1: the.lake.house.2006.1080p.bluray.x264-gold.mkv 08:32:50 Audio Codec 1: Lame 08:32:50 Audio Quality 1: 192 08:32:50 Audio Channel 1: Stereo 08:32:50 Advanced Audio Settings DUMP Track 1 08:32:50 Nero Option Profiles: AUTO --- Encoding Mode: Quality 08:32:50 CCT Option Profiles: AUTO --- Channel Options: AUTO 08:32:50 Lame Settings: ABR 08:32:50 Audio Normalization: 1 08:32:50 Frequency: AUTO --- Tempo : NONE 08:32:50 Pitch: NONE --- Other Add : 08:32:50 Advanced Audio Settings DUMP Track 2 08:32:50 Nero Option Profiles: AUTO --- Encoding Mode: Quality 08:32:50 CCT Option Profiles: AUTO --- Channel Options: AUTO 08:32:50 Lame Settings: ABR 08:32:50 Audio Normalization: 1 08:32:50 Frequency: AUTO --- Tempo : NONE 08:32:50 Pitch: NONE --- Other Add : 08:32:50 Selected Unlimited media size 08:37:32 Checking script...time.avs 08:41:58 Script checked. All OK!!! 08:41:58 Number of Frames: 141784 08:41:58 Framerate: 23.976044 08:41:58 Movie length in Seconds: 5914 08:41:58 Movie Width/Height: 1920/800 08:42:01 Encoding C:\temp\ To Mp3 with 192 ABR Preset 09:05:47 Encoded 1' Audio Track: 135872112 bytes 09:05:47 CQ encoding XviD: C:\Program Files\automkv\exe\encoder\xvid_encraw.exe -cq 2.5 -progress -threads 0 -max_bframes 2 -imax 31 -quality 6 -vhqmode 1 -qtype 0 -pmax 31 -bmax 31 -framerate 23.976 -bquant_ratio 100 -bquant_offset 0 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "C:\Program Files\automkv\profiles\XviD-profiles\matrix\Sharktooth's EQM v3LR.cqm" -i "C:\temp\movie.avs" -type 2 -o "C:\temp\movie.m4v" 01:58:14 Accepted values are between 697303040 and 741343232 bytes (movie+audio) 01:58:14 Got a file of size: 462549677 bytes + audio size -1 bytes (4757516800) 01:58:14 Only Movie Size: 462549677 bytes 01:58:14 "C:\Program Files\automkv\exe\matroska\NicMP4Box.exe" -normal-mode -add "C:\temp\movie.m4v"ar=1.000000 -add "C:\temp\audio.mp3:lang=und" -fps 23.976044 "C:\temp\the.lake.house.2006.1080p.bluray.x264-gold.mp4" Last edited by artisticcheese; 13th July 2007 at 09:22. |
13th July 2007, 09:23 | #2598 | Link |
HDConvertToX author
http://www.64k.it/andres/data/a/AutoMKV087.rar
http://www.64k.it/andres/data/a/AutoMKV087_NORIP.rar 0.87 Full Package 13/07/2007 ADDED: FFmpeg command line added to Log ADDED: Check if avs input file is yv12 ADDED: aq-strength, aq-sensitivity to X264 profile ADDED: Possibility to extract audio (Copy Original) for AVI/MP4/MKV/OGM/MOV.. container. The extraction is done by ffmpeg, or if present in \exe\BeSweet folder mplayer.exe. I cannot guarantee the correct extraction (for example aac extraction with mplayer is broken...) ADDED: QMTrim 0.6b1 support ADDED: Warning message when selecting QMTrim or HG AVS (suggestion by survivant) ADDED: Aften support FIXED: "Don't Care about Size" will change width only if with is "Automatic" FIXED: When input is ifo AutoMKV will try to demux audio even if not requested FIXED: When changing audio codec the downmixing will not change. It will be set to Stereo for Lame FIXED: Deinterlace test results now is always reported FIXED: When working with interlaced source, ColorMatrix is used in interlaced mode FIXED: Readded Deinterlace Status Analysis Window(beta) FIXED: ChapterXtractor should work on long path FIXED: FFDshow will remain invoked even if script is closed (2) FIXED: Computing movie parameters is now hidden FIXED: ColorMatrix slowdown, moved as last parameter. This little move will gain up to 15% of speed encoding FIXED: Removed -fps from xvid_encraw command line. Even if value passed was correct FIXED: In command line interface the movie name wasn't set (thanks to g_aleph_r) FIXED: After several test the thread parameter is now set to "--threads 0 --thread-input" FIXED: Some bugs on QMTrim (thanks to survivant) FIXED: Update PS3 4.1 profile (thanks to survivant) FIXED: Save configuration will now save in automkv folder (suggestion by zacoz) FIXED: Is no more possible to apply both MVDegrain AND MVDenoise (suggestion to survivant) FIXED: Changed the Status bar... more professional now (1kb less of exe size! ) FIXED: Some little layout change FIXED: Using queue in multiple sessions (beta) (thanks to zacoz) FIXED: When Disk Settings is "Don't care about size" and codec XviD the matrix will be set to "Didees SixOfNine-HVS.cqm" FIXED: Some Matrix in XviD Profiles FIXED: Totally reworked CRF/CQ Profile. Should be more clear and understable. Note that will be used as quantitizer the value in this window NOT in profile UPDATE: X264 rev.663, all XviD profiles (compatibility with VirtualDub), all X264 profiles (for aq patch),MediaInfo 0.7.5.0, Aften 0.7 BHH
13th July 2007, 10:37 | #2599 | Link |
Posts: n/a
Great time for a suggestion I know, but...
When "Don't care about size" is selected it changes the "Set Width Resolution" to Original, however the "Resize filters" is left untouched. For aesthetics maybe have this change to NONE. That would also help to draw attention to the change to original width if "Don't care about size" had been accidentally selected and then changed. Also, is there a configuration setting somewhere I can change to have the Audio Track language always default to English? That way I don't have to go into it every time, or is it saved as part of the Save Configuration in Advanced Settings? EDIT: Just noticed in the wiki that the setting will be remembered. Is it remembered after AutoMKV is closed and then re-opened? Last edited by zacoz; 13th July 2007 at 10:52. |
13th July 2007, 11:40 | #2600 | Link | |
Posts: n/a
While on the subject what does the FFmpeg encoding dropdown affect anyway. Mines defaulted to NONE but have had encoding fall back to FFmpeg anyway. Can't find anything about it in the wiki. |
